Old 10-28-2010, 10:05 PM   #1
Subaru2.5RSTI
Subaru2.5RSTI's Avatar
Subaru2.5RSTI is an unknown quantity at this point
Exclamation WTT !Brand New Greddy Profec B spec II and AEM UEGO Wideband BRAND NEW PACKAGE DEAL!!
I have a brand new Greddy profec b spec II and an AEM eugo The best boost controller and wideband out there. I want to trade for some front ichiba or circuit or peak performance 5 lug hubs or some brand new front and rear brake pads for z32 brakes or some s13 suspension parts or an apexi exhaust for an s13 or some cool shit
i might sell but would see if i get any trades thanks frsport!
BRAND NEW IN BOX! Greddy Profec B SPEC 2
Greddy's Profec B-SPEC2 boost controller is based on the very popular B-Spec. The B-SPEC 2's basic function is to increase boost as easy as the original boost controller, but with an added built in boost pressure display and optional features like real-time, peak, or last boost display. This unit can read measurements in kPA or PSI. There are also optional warning and boost limiter functions that can be programmed to offer better control and monitoring. Two preset values can be stored and are executed by a larger capacity inline solenoid valve. This unit does not require extensive programming and is ideal for low to high boost levels for single or twin turbo vehicles using actuators or wastegates.
AEM UEGO GAUGE TYPE WIDEBAND
AEM Wideband UEGO controller monitors air/fuel ratios during tuning to prevent lean fuel mixtures that can lead to engine damage. This unit combines AEM's single-channel wideband UEGO controller and gauge display into one compact unit. This gauge type controller features a digital LED display and sweeping LED needle that changes colors as the AFR changes from rich to lean. The gauge fits in any 52mm (2 1/16") housing and can be mounted virtually anywhere in the cabin. Some of the key features are:
  • AFR monitoring tool for EFI and carbureted applications and engine dynometers.
  • No laptop required for monitoring
  • Includes Bosch O2 Sensor
  • Accurate to 0.1 AFR
  • Capable of reading in AFR or Lambda with a flick of a switch
  • 24 Color Coded LED display lights for immediate reference to engine's AFR or Lambda ratio
  • Integrated three-digit display shows AFR or Lambda in real time
  • Serial data stream included for output of AFR (RS 232)
  • User programmable 0-5v analog output included for use with data loggers or any engine management system
Subaru2.5RSTI is offline   Reply With Quote
Old 10-31-2010, 03:43 PM   #2
Subaru2.5RSTI
bump it to the top
Old 10-31-2010, 11:32 PM   #3
hamsterb0i
hamsterb0i is an unknown quantity at this point
any trades? http://zilvia.net/f/sale-items/35069...il-yakima.html
hamsterb0i is offline   Reply With Quote
Old 11-04-2010, 03:15 PM   #4
Jimbo_Moone
Jimbo_Moone's Avatar
Jimbo_Moone is an unknown quantity at this point
willing to sell the wideband?
Jimbo_Moone is offline   Reply With Quote
Old 11-06-2010, 03:29 PM   #5
Subaru2.5RSTI
Bump to the top
aem, boost controller, greddy, spec b, wideband
