![]() 1993 s13 coupe with sr20det
![]() Sr20det redtop with jdm cluster reads 55k Fmic hks bov full 3inch turboback exhaust t28 turbo unknown cams put in by previus owner ![]() No rust watsoever, pretty straight body apart from a few dents, the front bumper is pretty beat its crackd in the middle ![]() Z32 brake swap all around with cross drilled rotors megan coilovers new tein tie rods 1 peice drive shaft ![]() short shifter clean interior apart from cracks on dash which every s13 has practically pillar mounted gauges etc. i might be leaving some things out but the cars had alot of work done to it and is solid now to wat it needs windsheilds cracked e brake never hooked up from z32 swap it needs a new ecu, the car runs really rich and i already checked the maf and 02...etc., ecu reads code 55 which means everythings ok but i took it to a local mecanic that works on sr's and he pinpointed it to be the ecu im pretty firm about the price 3400 cash, im taking a hit on this car at this price but i need it gone asap. not really intereed in trades but if you have something clean than go for it |
I'm interested in the car, could you send me some additional picture?? too [email protected]
I have cash in hand. |
Cars currentaly getting worked on, ecu going in along with a couple other things......deciding to fix car before i sell, i will post a new thread when everythings running right........Close this thread
Tags |
240sx, sr20det, z32 brakes |
