#121 |
![]() Join Date: Nov 2008
Sure, Andy does installs all the time and that would be a simple install fee from us.
I personally dont do the soldering and chipping, just the tuning and tech support on the program, however my question to you is why? They are the same ecu arnt they? |
#123 | |
If i were to send out the daughter board and the ECU that came with my SR you would be able to solder in the 20+20 way header for me? Also would you be able to flash it to the specs i have no so i can at least drive it around? Or would it be possible to not even have the chip installed in the ECU so it still acts like a stock ECU and when I'm ready to get it tuned just pop that bad boy in? Sorry if I'm not making sense. Would you be able to PM me with the price! Thanks a million! Nope, i don't mind at all. I paid $350 for this ECU. |
#125 |
i just wanna throw in some positive feedback, i love my nistune, its wonderful. when they say its hondata for nissan they are 100% right except i find it to be a lot easier to work with than any of my friends hondata systems
NO HANDS IN PANTS!! |
#126 |
To be honest i want to use the ECU that came with the clip.
#128 |
![]() Join Date: Jan 2007
hey we're a little late on our local forum in hearing about this and
trial trial it says is expired, can you provide an updated login so we can check it out for the week thx Dave
#129 |
so I'm reading up on this thread as I need a system that I can tune my s14. Basically, I have a s14 SR engine zenki with WC ecu, z32 MAF, and everything else is stock engine.
What do I need to buy for the nistune set up? If I want to send in my ECU for nistun to mount a new board on the ECU, where do I send it to? Is there a US headquarter of nistune that I can call and buy stuffs rather than having to contact Australia? Thanks |
#130 | ||
Is there any way you can try it on a different computer? This method of opening the trial version is still the correct one. Quote:
As far as what board you need can you give me the part number on your ecu? It would be either a type 3 or type 4. I believe the s14 had 2 different types of ecus out if Im not mistaken. I personally dont do the board programming or installs so Im not the best person to ask but Andy (co owner with me) does that stuff. I mostly offer the online and phone support for the software itself and I do the tuning for the cars we have come through. What you will need is the correct type board for your ecu, the software license, a consult cable, and installation. Check out our site for some details on package deals. AutoVaughnPerformance.com |
#131 |
I have recently installed NIStune on my 240 with redtop sr swap but I cannot connect with the consult port. I checked all the connections and they are getting power, Ive tried it on different base images, the drivers are installed correctly I have no idea why it isnt connecting.
Any ideas? Thanx |
#132 |
are you able to connect to the ecu but not the board? If so it sounds as if the jumper was not moved. Who did the install?
I really need more info. What cable are you using? Your consult port has to be properly wired in too. You say all of the connections have power, but not ALL of them are supposed to have power. Please be very specific and I can help. |
#133 |
I had my friends dad do the board install. Its a type 3 board with PLMS consult cable. I dont think I am connecting to ecu at all.
He tried moving the jumper but it was lost somehow so he soldered in a wire to cj2. could this be the problem? Also I only get power to all wires when key is on and the consult cable is plugged in. Thanx for the help |
#134 |
Have you had any issues with stalling? Either on idle or coming down off load?
www.illgarage.com |
#135 |
I just got there type 3 board package. Great customer service. Went out of his way to get my board back to me quickly as well. Wish I was close enough to them to get a tune
#136 |
![]() Join Date: Jun 2007
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
I have a enthalpy tuned ECU and consult cable from BLAZT, can I just buy this software and tune my ECU.
And what is this BS about user license and stuff LOL. I can only tune 3 different ECU's What's the price of the software? |
#137 | |||
Another possibility is you need to tell nistune which com port your using your cable on, or you need to have auto detect selected. Quote:
How the license works: You can tune 5 different ecus and up to 3 different address files. So for instance you could do 2 s13 sr's, 1 ca18det, 1 sohc ka24, and a vq30dett and that would max out your license. Or you could do 5 vq30dett's and that would max out your license. See what I mean? Chances are your not going to go over your usage and if you legitamatly do they will work with you (NIStune) or you are making money off your tunes and you can afford to upgrade to the tuner version which is unlimited. |
#138 |
not giving a fuck
![]() Join Date: Apr 2007
Trader Rating: (104)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 104 reviews
OP - i havent had a chance to visit Nistune forums in forever... just wondering if theres any updates t othe software i should know...i got my software bout last yr february-ish...
Type 1 board for a CA18det...
![]() ![]() PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r ![]() |
#139 | |
I put a z32 MAF in while getting nistune installed and it doesnt run at all. it tries to but cant keep the revs up and i am throwing a MAF code. i double checked all the wires they seem correct Im thinking of putting my old MAF back in and trying that. And 4x4le I did the driver installation as the paper said it seems to work i will try selecting auto detect and try it again. |
#141 | |
not giving a fuck
#142 |
^^ I did, :P
www.illgarage.com |
#143 |
I couldnt adjust because I never got nistune to connect with my ecu, but i did throw my old one back on an it got me to work and back that way and ran fine so Ill play with it more tomorrow when theres daylight.
#146 | |||
no |
#147 | |
not giving a fuck
#148 |
and just so you know, its not going to lock you out the first few times. It will remind you, but you can hit ok and still tune away. I think it will let you do that like 5 times or so before not allowing you.
This is mostly for people that illegally download it, and for people that share their registrations with everyone. You will get caught and your software will no longer work. Even the person that paid for it and gave it to everyone and their brother. |
#149 |
not giving a fuck
no worries...i just havent had time ot use it...so technically theres like 3 or so updates ive missed out on, are the updates going ot dowload in one time, or each on its own?
#150 |
you can select any of them that are newer than the one your currently using. I always just grab the newest one.
I havent noticed any bugs in the past year or so. It was different though when this was brand new. |
