![]() Join Date: Sep 2006
Trader Rating: (30)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 30 reviews
No it is not. You can make it work, but have to switch some wiring around. The only reason people would switch the wiring to make it work is because the max speed on the single cam tach is I believe 125, as the dual cam one is only 120. Otherwise, just swap the tachs with the correct motor...
![]() Join Date: May 2005
![]() ![]() ![]() ![]() Feedback Score: 10 reviews
What? I'm pretty sure they work, dudeson. It's just that the tachometer on the two are different.
I've done this with Digital clusters and non digital clusters. Speed cuts have nothing to do with gauge clusters |
G6civic x is right, I just swapped the digital on my 93 for a analog from a 89, took out my tach that still worked... my digital speedom was dead... and installed the dohc tach in the sohc analog cluster, and it works... have to swap the sub harness too tho, it plugs in behind the middle vents, left the original sub harness incase I ever find a cheap digital and want to go back to that...
![]() Join Date: Apr 2004
If it's analog to analog, it' plug and play.
Instead of running around in circle, tell me what year your car is. Is the speedo original? Then tell me the year of the donor speedo. Is that original to the donor car? |
#8 | |
![]() Join Date: Sep 2003
Mine is from a 91 and the one Im about to buy is from a SOHC.Dont really have much info on the sohc one. Its analog. |
240sx, dohc, kas4de, sohc, speedometer |
