Old 01-22-2010, 02:03 PM   #391
tootall4la
tootall4la's Avatar
tootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to all
Originally Posted by future240 View Post
If there is no panel in the car telling you which fuses are what, then your next option is to consult the Factory Service Manual
Thanks 4 the help..
So my Cig Lighter isnt working..
My cluster is so dim..The brightness control dosent function..
im guessing i might replace some fuses..
My cluster works just that the hud is so dim!!
any help on the brightness control??
as i will be going over the manual
tootall4la is offline   Reply With Quote
Old 01-22-2010, 03:04 PM   #392
kouki fanatic
kouki fanatic's Avatar
kouki fanatic is an unknown quantity at this point
i have a few. the car i want to get has no windshild wiper lever, but the motor works. how much would the cost of this be and how long would it take?
and also it needs a pcv pipe replacement and o2 sensor replacement. how much would that cost with labor?
kouki fanatic is offline   Reply With Quote
Old 01-22-2010, 03:54 PM   #393
jonnybonds84
jonnybonds84's Avatar
jonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to all
I got one, Im looking into buying 17x9 +15 rims and I got AGXs and lowering springs. Will I have fitment trouble with the stock "shaped" strut hitting the rim in the fronts? I figured that i can always get the fender rolled since they would stick out. Also the same question for the rear, they are going to be 17x10 +12.
SPENCER DOUGHERTY RIP ME OFF. SEARCH HIS REVIEW THREAD.
jonnybonds84 is offline   Reply With Quote
Old 01-22-2010, 04:03 PM   #394
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
Cool Small Questions (THAT NEVER GET ANSWERED) Thread
Originally Posted by stinky_180 View Post
what is the bolt size for the SOHC KA camshaft gear? also the crankshaft bolt?
anybody???????
WheelsDirty
Old 01-22-2010, 04:19 PM   #395
sdterrible1
sdterrible1's Avatar
sdterrible1 is an unknown quantity at this point
What style bulb is used for the high beams on s14a?
sdterrible1 is offline   Reply With Quote
Old 01-23-2010, 03:18 AM   #396
NINJASPY
NINJASPY is on a distinguished road
what does burnt clutch smell like? (i smell burnt wire around front right engine bay area)where would the smell resonate from? under hood or under car?
NINJASPY is offline   Reply With Quote
Old 01-23-2010, 01:02 PM   #397
I LUV MY S13
I LUV MY S13's Avatar
anybody???????
i believe 17m, not sure though
smells a little funky, cant explain it
now my questions:
1) whats that tool to pull out the pilot bearing called?
2)anybody have one that i may borrow?
3)engine and tranny got a little wet in the rain, should i worry?
-Jorge
I LUV MY S13 is offline   Reply With Quote
Old 01-23-2010, 01:57 PM   #398
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Originally Posted by I LUV MY S13 View Post
now my questions:
1. pilor bearing puller
2. buy at kragen, use, clean, return (what i did)
3. out of the car? were all the 'holes' plugged and sealed? totally exposed in the rain?
WheelsDirty
Old 01-23-2010, 02:03 PM   #399
I LUV MY S13
haha thanks
not total exposure it was wrapped pretty good, but when i unwrapped it this morning it was wet..out of the car and everything is sealed up except throttle body, rad hoses, and ...thats it hehe
-Jorge
Old 01-23-2010, 03:37 PM   #400
Future240
Future Moderator
Future240's Avatar
anybody???????
Not sure if this will help but here goes
Technical Articles: SOHC KA24E Timing chain replacement
Originally Posted by ThatGuy
Old 01-23-2010, 04:09 PM   #401
Teddy
Teddy's Avatar
Trader Rating: (44)
Feedback Score: 44 reviews
NO. Do NOT get a pilot bearing puller. You'll be at it for days.
Get a BLIND HOLE PULLER. And the slide hammer of course. With a blind hole puller, it should come out within the first 5 tries.
www.realize-jp.net
Old 01-24-2010, 08:31 AM   #402
JAKracing
JAKracing's Avatar
JAKracing is an unknown quantity at this point
i wrecked my car the other day, and since then when i hit a bump the ass end seems to sway. what could that be? FYI, i jumped a ditch and hit a tree.
JAKracing is offline   Reply With Quote
Old 01-24-2010, 10:41 AM   #403
Otto347
Otto347's Avatar
Otto347 is an unknown quantity at this point
Have you even looked under the car to see if anything is broken/bent?
Originally Posted by atutt View Post
Or you could have stopped being a lazy asshat and done some research.
Otto347 is offline   Reply With Quote
Old 01-24-2010, 10:41 AM   #404
irritatedmax
irritatedmax's Avatar
irritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enough
have you checked your alignment since the wreck?
BRICKHOUSE PRODUCTS
IG @brickhouse_products
irritatedmax is offline   Reply With Quote
Old 01-24-2010, 11:13 AM   #405
JAKracing
JAKracing's Avatar
yea i looked, nothing seems broken, and the alignment is straight. idk, maybe some bushings are just worn and i haven't noticed it until now. i need to replace the suspension parts and subframe bushing, maybe that is what it is
Old 01-24-2010, 12:41 PM   #406
irritatedmax
usually after accidents like that, you "notice" more whether it is real or not.
have you actually gotten an alignment? it might be worth the money. just because it looks straight and drives straight doesn't mean it is.
BRICKHOUSE PRODUCTS
Old 01-24-2010, 12:51 PM   #407
devnull
devnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymore
Autozone has a loan-a-tool program. Unless you utterly break the tool, you get your full deposit back when you return it. No need to risk not being able to return a tool at Kragen.
devnull is offline   Reply With Quote
Old 01-24-2010, 11:18 PM   #408
dopplganger1
dopplganger1 is an unknown quantity at this point
Originally Posted by dopplganger1 View Post
what is the size of the turbo coolant line for an s13 sr20det? also what size AN fitting would i need for the s14 water neck?
anyone????
dopplganger1 is offline   Reply With Quote
Old 01-25-2010, 12:15 AM   #409
jonnybonds84
Can anyone shine some light on this.
Old 01-25-2010, 12:41 AM   #410
j6250
j6250's Avatar
j6250 is making a name for him/her selfj6250 is making a name for him/her selfj6250 is making a name for him/her self
Does anyone know of a good product to shine up weather stripping?(Plastic Moulding around the windows, looks smoky gray) Tire shine will collect dust and I've read that some products need to be re-applied several times a month and/or will run leaving streaks. Just wondering if anyone has used something that were happy with. Thanks!
Canvas killer
j6250 is offline   Reply With Quote
Old 01-25-2010, 02:08 AM   #411
mothon
mothon's Avatar
mothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond repute
The rear clears for sure, and the front should clear by 3mm or so if anything you could always use a small spacer.
instagram: madness_garages14
mothon is offline   Reply With Quote
Old 01-25-2010, 04:01 PM   #412
sdterrible1
Lame question
I know the boot is ripped, but should oil be coming out? Would a new boot solve the problem or is there a part missing in the tyranny to seal it??
Old 01-25-2010, 05:43 PM   #413
JDM Sil4ty
JDM Sil4ty's Avatar
JDM Sil4ty is an unknown quantity at this point
im trying to convert my car to 5 lug so i gota question 4 u ..
i gota 95 s14 how do i know which rotors to buy? abs or non-abs ?
alpha kenny body.
JDM Sil4ty is offline   Reply With Quote
Old 01-25-2010, 06:08 PM   #414
udon!
udon! is an unknown quantity at this point
Originally Posted by sdterrible1 View Post
Lame question
this happened on my 13 im pretty sure that its the seal.
udon! is offline   Reply With Quote
Old 01-25-2010, 06:52 PM   #415
driven_
driven_'s Avatar
driven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to beholddriven_ is a splendid one to behold
my s14 does that, but my s14 has...
1. broken rear sway bar end links.
2. alignment is off
3. driver side suspension is blown.
Find me on MR2oc!
driven_ is offline   Reply With Quote
Old 01-25-2010, 06:56 PM   #416
driven_
driven_'s Avatar
iirc, it doesnt matter, as long as you have a pair of rears, and a pair of fronts.
Find me on MR2oc!
Old 01-25-2010, 11:59 PM   #417
NINJASPY
Back to black by mothers(in a red bottle)
needs very little product, but lots of rubbing. Difficult to get off paint(oily). May need 2-3 applications, heavy application does not help.
Old 01-26-2010, 11:56 AM   #418
Slammed180
Slammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of light
Originally Posted by udon! View Post
hi.
what are the specs of socal s130's ssr's? and what size overfenders does he have?
i swear if that car had a vagina, i would do very naughty things.
oh god, just look at how the lip tucks PERFECTLY in the fender.
ugh.
what parts are needed to do a s14 zenki to kouki conversion?
can someone tell me all the steps required for install/give me a link to wallthrough
when i see BN sports over fenders on cars the are never rivited on, how do they put on bn sports overfenders?
what are the wheels for under my username?
will a 18x9.5 +12 fit on a stock bodied s13 with fender roll but no pull?
what would be the perfect sized 18" wheel for a stock bodied s13 with just rolled fenders where the lip sticks out a couple mm outside the fender?
im bored lol.
can a title of a car become salvaged if the odometer does not work for a period of time?
what is the point of frame rails besides using them to lift a car.
Seriously. Some of the most retarded questions you could ask. Take 5 mins and search google for fucks sake.
Blow me, bitches.
Slammed180 is offline   Reply With Quote
Old 01-26-2010, 12:12 PM   #419
TurboSE
TurboSE's Avatar
TurboSE is an unknown quantity at this point
Anybody have an OEM part number for the little white plastic clips/separators that hold the brake lines in place on an S13?
I don't really feel like fabbing my own, but the old ones are so brittle, they crack like glass.
WTB: PAIR 18x10 0 to -25, less than $1500 shipped please.
TurboSE is offline   Reply With Quote
Old 01-26-2010, 01:07 PM   #420
Slammed180
This one?
Nissan OEM Brake/Fuel Line Clip - Dual Pipe - Nissan performance parts
Blow me, bitches.
