Old 11-23-2009, 11:38 PM   #91
shogun!
shogun!'s Avatar
shogun! is on a distinguished road
LOL
No new pictures atm matey but a short status repport:
* I have adjusted and fastened the front WB fenders in their final position.
* The hood has been adjusted aswell and has now hood dampers (the support rod is no longer in use).
* The Hood latch has been glass blasted and repainted and mounted
* Some of the gauges has been replaced (- AEM wideband lambda, + Autometer dito). Autometer Pyrometer (EGT 2000F).
I did not need to use solid bushings in the sub frame (and I am happy about that because of the nasty work burning out the old ones). The original shitty silicone filled ones are not damaged so I am satisfied with the function the spacers give. They reduce the play by 99% and still give some little vibration damping (as if some added/reduced noise should be of any importance hahaha!)
Oh! ... almost fotgott. I have moved the beast to a new nice garage without cardboard walls
Originally Posted by Soooshi View Post
Dearest Shogun.
We demand updates.
Question. When doing your rear, why didn't you opt for Solid aluminum replacement bushings?
you seem to be going balls out anyways.
Do you need me to circle them?
shogun! is offline   Reply With Quote
Old 11-26-2009, 01:38 PM   #92
shogun!
shogun!'s Avatar
Today I picked up the new turbo from .
Without doubt they are skilled experts in the world of turbos. Dick has made an excellent job. There is nothing about this SX700S that is standard. Top Class Dick! 1000 cheers!
Old 11-26-2009, 11:46 PM   #93
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
I think i just exploded on myself...
SochBAT is offline   Reply With Quote
Old 11-30-2009, 12:11 AM   #94
shogun!
shogun!'s Avatar
Tomei MHG for big power output.
The listing show approximate CR vs thickness and bore.
Old 11-30-2009, 11:30 AM   #95
Ceepo
Ceepo's Avatar
Ceepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enough
I am enjoying this build!!! car is gonna be awesome
Ceepo is offline   Reply With Quote
Old 11-30-2009, 07:49 PM   #96
Dominic Axelson
Dominic Axelson's Avatar
Dominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfection
Send a message via AIM to Dominic Axelson
That turbos prolly bigger then that CA. haha
Dominic Axelson is offline   Reply With Quote
Old 12-01-2009, 08:34 AM   #97
shogun!
shogun!'s Avatar
Some funny christmas candles of grade 8.
Old 12-01-2009, 09:03 AM   #98
rb25_s13*CHUKI
rb25_s13*CHUKI's Avatar
One of the best documented and well put together build I've seen In a long time!
Obliterate
rb25_s13*CHUKI is offline   Reply With Quote
Old 12-04-2009, 12:49 PM   #99
shogun!
shogun!'s Avatar
Slightly modified plans. Will go for dual Tial with a bit of my own touch
Old 12-05-2009, 08:07 AM   #100
datboibrad
datboibrad can only hope to improve
glad to see this car is going to get some aero improvement. great build and quite an impressive CA
datboibrad is offline   Reply With Quote
Old 12-06-2009, 10:13 AM   #101
shogun!
shogun!'s Avatar
Completed the gauge installation with a couple of useful meters from Autometer.
Old 12-06-2009, 11:44 AM   #102
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
hahaha indeed
blu808 is offline   Reply With Quote
Old 12-07-2009, 02:09 PM   #103
shogun!
shogun!'s Avatar
Don't feed the animal
Old 12-07-2009, 03:15 PM   #104
nissansrbetter16
nissansrbetter16's Avatar
nissansrbetter16 is making a name for him/her selfnissansrbetter16 is making a name for him/her self
Great build have always wanted to see the CA done right, And damn that turbo is huge will it still fit the manifold you already have ?
nissansrbetter16 is offline   Reply With Quote
Old 12-07-2009, 03:29 PM   #105
godzillarb
godzillarb's Avatar
godzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to all
Definitely looking forward to seeing some dynos of this beast.
There's a lot easier way to make 700hp, but props for doing it the hard way
INTENSE POWER RIPPED ME OFF
godzillarb is offline   Reply With Quote
Old 12-07-2009, 11:30 PM   #106
shogun!
shogun!'s Avatar
Thanks mate!
Unfortunately not. I will build a new one with split entry to the turbo and split exit for dual WG valves.
Old 12-07-2009, 11:32 PM   #107
shogun!
shogun!'s Avatar
700 hp in an S13 is hard work either way. There are not many ways to do it and none of them are easy
Old 12-17-2009, 08:28 AM   #108
shogun!
shogun!'s Avatar
Some additional chassis parts to lift handling one more step
Old 12-17-2009, 04:36 PM   #109
HouseElf
HouseElf's Avatar
HouseElf is an unknown quantity at this point
Originally Posted by blu808 View Post
hahaha indeed
its good i read through this because i was soooo close to doing that! hahahaha
HouseElf is offline   Reply With Quote
Old 12-21-2009, 06:48 PM   #110
longdy
longdy's Avatar
longdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud of
Send a message via AIM to longdy
good shit so far buddy!!! lol
Summer project: Rx-7 Vert
longdy is offline   Reply With Quote
Old 12-25-2009, 09:19 AM   #111
Slammed Assassin
Slammed Assassin's Avatar
Trader Rating: (34)
Slammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud of
Feedback Score: 34 reviews
Send a message via AIM to Slammed Assassin
sick build.. glad to see a CA done right.
Slammed Assassin is offline   Reply With Quote
Old 12-30-2009, 01:45 AM   #112
shogun!
shogun!'s Avatar
The digital climate control DCC with power on.
Old 12-30-2009, 03:01 AM   #113
NismoDriverS13
NismoDriverS13 is an unknown quantity at this point
this thread is ultimately AWESOME!!! i had no idea there are nissan 240 fans in Sweden.
awesome build, and keep doing good work.
NismoDriverS13 is offline   Reply With Quote
Old 01-09-2010, 05:55 PM   #114
cain817
cain817 is an unknown quantity at this point
Any new updates?
cain817 is offline   Reply With Quote
Old 01-10-2010, 05:52 AM   #115
shogun!
shogun!'s Avatar
Some Christmas gifts
Old 01-10-2010, 10:01 AM   #116
Slammed180
Slammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of light
oooooooo, someone is ballin hard.
Clearcorner kouki lamps.
Blow me, bitches.
Slammed180 is offline   Reply With Quote
Old 01-10-2010, 11:01 AM   #117
shogun!
shogun!'s Avatar
Old 01-10-2010, 12:02 PM   #118
kingyogi
kingyogi is just really nicekingyogi is just really nicekingyogi is just really nicekingyogi is just really nicekingyogi is just really nicekingyogi is just really nicekingyogi is just really nicekingyogi is just really nicekingyogi is just really nicekingyogi is just really nice
so sick man i love it
1
kingyogi is offline   Reply With Quote
Old 01-10-2010, 07:04 PM   #119
kalypso123
(ノಠ益ಠ)ノ彡
front bumper fails terribly, but nice looking car.
Old 01-12-2010, 08:50 AM   #120
shogun!
shogun!'s Avatar
Nothing wrong with the Works9 front bumper. I like it a lot
