11-23-2009, 06:03 PM | #1 |
my s14 2jzgte build
I don't know if it is the right section ,if is not I apologized and moderator please move ..........Thanks....Omar
Here are some pictures of the lenght of the shifter. I am posting them cause I look everywhere and could'nt find them anywhere and I might help somebody and I know for a fact that tech 2 won't share that info extension of 3.250" according to a person who bought the shifter from tech 2 1jz bellhousing r154 tranny reinforced with first gear trusth washer and bearing carrier both parts from marlin crawler also extended shifter everything made by me yonaka racing intercooler misc parts tranny closed and ready with shifter extension here the custom made clutch here is mines done by me also here is mines closed with marling crawling forged first gear thrust washer and bearring carrier installed also everything done by me if you want to buy the 1jz bellhousing buy it from champion toyota in texas they sell it for $300 plus shipping is way cheaper than driftmotion and tech 2 . here is the phone # 1-713-943-7010 ask for Jeff , he will hook you up hope this help......................Omar |
11-23-2009, 06:08 PM | #2 |
here are some more pictures of my modified oil pump
and here is my work bench at home figure out the wiring motor ready to be droped in motor in This image has been resized. Click this bar to view the full image. The original image is sized 800x600 and weights 133KB. I fabricated the mounts here are the clearance tranny mount |
11-23-2009, 06:13 PM | #3 |
here is what I did today
tb welded and polished in the inside custom made power steering hose coolant fan switch to make fans runs with car temperature not all the time tonight after the kids goes to sleep I will try to finish the harness and tomorrow rear battery box installed and finish the mounts they are 1/8" off and I don't like it I am picky after that make a jig to probably mass production..Omar |
11-23-2009, 06:15 PM | #5 |
today I redid the mounts cause I did'nt like the other ones (I am waiting for the supra ones to do the motor mounts again )
old one new one in the making almost done done and painted installed (you can see a glimse of the exhaust I am making the magnaflow pipe be here monday ) where the sifter sits |
11-23-2009, 06:17 PM | #6 |
flex pipe installed and bung for the wideband( it can't be seen in this angle)
exhaust the way I want it as closed to the chassis as possible with out touching it |
11-23-2009, 06:19 PM | #7 |
I re did the cross memberr mounts this time I used the supra mounts instead of the 240
the first one I did the second version first version of tranny mount second version fan clearance with new set up crossmember clearance finish the exhaust also installing the cooler |
11-23-2009, 06:20 PM | #8 |
today I had some time to finish the intercooler piping amd started working on the fuel supply
here is the first time I let it go to the floor since I put the 2j on it it sits so low that I think I got to put stock spring for now while I gather some more money for the coilovers also I am installing a supra (denso) fuel pump but when I pulled out the one on the car Is as big as the denso , does anybody got a picture of the stock s14 fuel pump? cause the one on the car the only marking I saw it said jecs made in japan .I want to see is that is the stock one or an aftermarket |
11-23-2009, 06:21 PM | #9 |
today I finished the coolant system
fuel pump denso supra fuel pump fuel lines transfer from passenger side to driver side (this is temporal cause I am planning to upgrade the fuel system,turbo and intake on couple of months) |
11-23-2009, 06:22 PM | #10 |
today I had sometime to work on the car
modified 2j acelerator cable to work with s14 cable and cruise control cruise control server installed in the opossite side of engine bay fuel line system done (it will be temporary till I convert to single turbo and update fuel lines fuel filter relocated I did'nt take pictures of it but I by passed the heater core till I conver to single no room for the hoses tomorrow I gonna work on the fuel pump relay and hopefully order the drive shaft |
11-23-2009, 06:23 PM | #11 |
yesterday I wnt I pick up some prosport gauges and today I made the console for the gauges
hopefully this weekend if I have time I will be starting the car and by mid next week the driveshaft will be done (waiting on the tranny yoke coming from california) |
11-23-2009, 06:24 PM | #12 |
today I finished the engine harness and make a board for the ecu ,power distribution,relays and dakota box (still waiting on the dakota box and drive shaft)
spagetti board |
11-23-2009, 06:33 PM | #17 |
as of today 11-23 . I installed energy suspension bushings and replaced front and rear lower control arm ball joints .Now I am shopping for rear adjustable arms (rucas,toe,traction arms) I have'nt decide on the brand (spl or powered by max) and after that buying fortune auto drag coilovers...........................
12-04-2009, 10:25 AM | #20 |
good stuff!
how do you plan on keeping the cruise control? can't say i've seen that done on many JZ swpped cars.
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo |
12-04-2009, 11:12 AM | #21 |
Thanks man ,no dyno time yet . I am waiting for next year . when I will be upgrading to a single turbo bw s370 . But I think I am around 400whp at 18 psi cause I was cruising with my friend (built sr 450whp) and he decide to give it a try and I pulled on him bad
618 whp tuned by alpha |
12-04-2009, 11:14 AM | #22 |
Nah I just put it there and Sean (Tech2) started making fun of me and i took it out.On another note that is mees up what happened to him , he was a cool dude
03-10-2010, 05:24 PM | #27 |
Sorry guys I haven been on the site latelly
Thanks man they works vs-xx front 17 x 9 16 offset rear 17 x 10 20 offset
03-10-2010, 05:25 PM | #28 |
man that was a year ago ,iirc it was the stock s14 sock but I will be upgrading to twin densos next month I let you know for sure .........
618 whp tuned by alpha Last edited by babillaracing; 03-10-2010 at 05:55 PM.. |
03-10-2010, 05:26 PM | #29 | |
and is all right. Next month I gonna make it a little quick
03-10-2010, 05:27 PM | #30 |
thanks you sir
