![]() im selling my white 93 s13 hatchback SE. 212k it was going to be a light wieght NA project but like most people i need to sell my projects. interior has been stripped but has dash, seats, center consol, door panels. rear wiring has been stipped so only the wires needed are still there. most of the sound deadning is gone some still left.dash was removed and all the climate control stuff was removed.
now for the good stuff. car has KW double adjustable coilover suspension Ichiban 5 lug conversion that was cryo treated 300zx brakes all the way around with stoptech Slotted rotors, and a custom brake pad compound. similar to a axxis metal master but with higher intial torque holding. rotors, calipers and brake pads were cryo treated. spl stailess steel brake lines Nissan R200 6bolt 4.38:1 gear ratio with Viscous lsd. lsd was rebuilt before installation. grips good and has accelerates much better. ring and pinion were cryo treated. Advan AVS 17" 6 spoke wheels painted black i dont know the model or what the original color was i got them black and just touched them up. fronts are 30mm offset and rears are 35mm offset. wheels are flush with body. Tires are dunlop direzza Z1 with less then 100miles on them. 215/45/17 on the front and 235/40/17 in the rear. i do not want to part it out so dont ask. i would like $4000 for the car as is. but i will take everything off and put it back to stock with agx shocks and rsr race springs for $2000 ![]() ![]() ![]() those seat covers came with the car it has a sparco 5point harness in the passanger seat. ![]() ![]() ![]() before ![]() ![]()
Final Speed Garage- Auto repair and Performance 951-698-8161 Murrieta,CA Last edited by macidcrook; 11-13-2009 at 07:01 PM.. |
Tags |
coilover, s13, z32 brakes |
