Old 10-10-2009, 04:30 PM   #1
Nibras
Nibras's Avatar
Nibras is an unknown quantity at this point
Send a message via AIM to Nibras
s14 Wierd Timing Chain Rattle Inside Motor Head
I can feel the chain hitting the head and hear it . it was not loud but slowly is getting worse and is affecting performance i believe.
is it a loose timing chain or a broken link? what do i need to do to fix it
i think its the timing chain correct? its right in the front of the motor
thanks nibras
Nibras is offline   Reply With Quote
Old 10-10-2009, 04:43 PM   #2
ms!3
remove the top and right chain guide. not needed.
ms!3 is offline   Reply With Quote
Old 10-10-2009, 06:34 PM   #3
brian3676
brian3676 is an unknown quantity at this point
well come to nissan timing chains, replace or deal with it
brian3676 is offline   Reply With Quote
Old 10-10-2009, 06:43 PM   #4
pinky121388
pinky121388's Avatar
pinky121388 is making a name for him/her selfpinky121388 is making a name for him/her self
its mainly the top guide.. Take valve cover off, and you'll see that its broken.. Take it out, and unbolt the other half of it, then put bolts back.
Nissan "Omitted" this guide, so you wont find another one..
pinky121388 is offline   Reply With Quote
Old 10-14-2009, 09:10 AM   #5
T-Money
T-Money is an unknown quantity at this point
You also need to check that the chain tensioner is not seized. If you remove the valve cover you can see it on the left side of the chain, you should be able to move it in and out freely. If not, you need to get it unstuck. Check this thread out for some good details and pics.
HOW-TO: Fix Your Timing Chain Rattle: Nissan Articles: Nissan Forums / Infiniti Forums - NICOclub
NOTE: I did not have to remove the lower timing chain guard in order to un-seize the tensioner.
T-Money is offline   Reply With Quote
Old 10-14-2009, 09:56 AM   #6
jspaeth
jspaeth's Avatar
I don't get it......my car has all of the timing chain guides in place, and no noises at all, so why do some people have this problems, and others don't?
You would think that all of the dimensions of all of the parts are the same.
I bet people with rattling timing chains have insufficient oil pressure to the tensioner or have worn/crappy tensioners.
Daily driven
Old 10-14-2009, 11:56 AM   #7
projectRDM
projectRDM's Avatar
Almost. Do NOT put the bolts back in. If they decide to back out down the road there's nothing stopping them from trashing the entire engine.
FORMERLY R240NA
chain, loud, odd, rattle, timing
