![]() today i noticed that my windows had alot of moisture on them from the inside. i got into my car and noticed my carpet was completly soaked!. it has been raining alot lately so im guessing i have a pretty bad leak somwere. where would be good place to start lookin? i dont want it 2 start smelling bad or rust away at my floorboards.. thanks guys
![]() Join Date: Sep 2006
Did you drive in the rain at all?
cause it could have came through the floor. Like if you have removed rear seatbelts or something. Sunroof? did the sunroof leak? or the hoses that drain the sunroof through your interior panels behind your seats? did it come through the firewall area? Are all the plugs in place. Is it a convertable and did you leave the top down? Basically, no one here can help you. Your question is so broad with no clues, it could be anything. Your gonna have to do a little investigation yourself. |
![]() Join Date: Dec 2002
Exactly. There's a hundred places water can intrude into the cabin, without knowing the model, options, modifications, etc. we're all guessing in the dark.
![]() Join Date: Aug 2008
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 5 reviews
I had a leak that turned out to be the rubber around the tail lights. water runs down the channels for the hatch and gets between the tail light housing and the body. silicone fixed it right up.
![]() Join Date: Dec 2005
Or you can get one of those bug bombs and set it off inside your car. To find the leak, just get around your car and sniff. When you start coughing, you've found your leak.
And you know this how? Heater core leaks coolant, not plain water. It's highly unlikely that the OP doesn't know the difference between the two.
What you're gonna have to do is take off a lot of interior panels and get up in your dash to look...while you're hosing your car off with water (or someone else).
If the carpet was mostly wet in the front of the car, start with the corners of the windshield...good luck. |
#14 |
im gonna vote for.... leaving the windows down
or heater core... since the OP did say the carpet was soaked, and to me that means a lot of fluid... more than could have got in from it rainning
No... no one stole my interior... its safely in my garage... ![]() |
#17 |
All of the firewall grommets are culprits too, especially in the fender wells where the hood cable and ASCD harness go through. My engine harness is out right now and water trickles in through that big ass hole every time it rains.
#19 |
While we're somewhat in the topic, is it typical for the seat brackets and other steel pieces(like the area under the shift knob for example) in the cabin to have some surface rust?
Almost there. |
#21 |
Some light surface corrosion is typical since they're not coated with anything. The dash crossbar and rear seat brackets do it too, along with the pedal brackets. I powdercoated all my parts while the interior was out because it bothered me but a coat of rustoleum works fine.
#22 | |
OK that's what originally had me wondering about this. I'll look into powder coating then as well. Thanks.
Almost there. |
Tags |
carpet, moisture, rain problems, water, windows |
