Old 01-20-2009, 04:09 PM   #1
alesserfate
alesserfate is an unknown quantity at this point
Xcessive SR20 to VG Transmission Adapter
Holler,
I've searched but haven't found exactly what I need so here goes:
I'm looking to upgrade from stock SR tranny on my drift car to Z32 tranny for obvious reasons. Now, I know quite a few people who run the mazworx kit. Has anybody out there tried this kit ?
Xcessive SR20 to VG Transmission Adapter Xcessive Manufacturing
Any opinions on Xcessive and/or this kit ?
alesserfate is offline   Reply With Quote
Old 01-20-2009, 07:55 PM   #2
jim1234664
jim1234664's Avatar
jim1234664 is an unknown quantity at this point
never heard of it, but thats not saying much
jim1234664 is offline   Reply With Quote
Old 01-20-2009, 09:01 PM   #3
Monooxide
Monooxide's Avatar
Monooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to behold
At one point I had a KA24DE manifold and Top Mount Mani from them, but EXCELLENT quality parts.
Monooxide is offline   Reply With Quote
Old 01-20-2009, 09:16 PM   #4
Charlie
Charlie is on the path to ruinCharlie is on the path to ruin
Link doesn't work
Charlie is offline   Reply With Quote
Old 01-20-2009, 09:18 PM   #5
S14DB
AFC #1
S14DB's Avatar
Does this space the input shaft out of the crank?
Old 01-21-2009, 07:00 AM   #6
Howlermonkey
Howlermonkey is an unknown quantity at this point
Austin Hoke of the hybridz pages makes one to adapt the z32 tranny to a L series engine so it might not be much to convince him to consider what you need.
Z32 Install Version 2. - HybridZ
Howlermonkey is offline   Reply With Quote
Old 01-21-2009, 07:26 AM   #7
smelly240
smelly240's Avatar
The input shaft will only go into the flywheel's hole from the look of it - that spacer is there tho to move the flywheel out (i assume the spacer will replace the crank to hold the pilot???)
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
smelly240 is offline   Reply With Quote
Old 01-21-2009, 07:38 AM   #8
turbo2nr
turbo2nr's Avatar
turbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enough
Send a message via AIM to turbo2nr
alot of the ka-t guys run it when making over 500whp. seems to be good try searching on ka-t.org im sure you'll find something.
yes i know you are goging to use it for a sr..
s14 kouki ka-t
turbo2nr is offline   Reply With Quote
Old 01-21-2009, 02:01 PM   #9
S14DB
AFC #1
S14DB's Avatar
Install the flywheel spacer and flywheel with the new 12mm bolts. Some crankshafts have an additional pilot sleeve that will interfere with the new spacer. These are typical on crankshafts that came from automatic transmissions. You will need to remove or grind this sleeve to accommodate the flywheel spacer. Use the 6 supplied 12mm washers with the new flywheel bolts. Be sure to check that the bolts do not bottom out, if they bottom out you will need to grind the bolts to allow proper seating. Use thread locker on the flywheel bolts and torque to factory specs. Hold the clutch disc on the flywheel using a clutch pilot tool and check the springs in the hub for clearance to the new flywheel bolts by rotating the clutch 360 degrees while holding it tight to the flywheel. If contact exists, clearance the bolt heads as needed.
The flywheel spacer comes with a new pilot bushing installed. The clutch can now be reinstalled. Follow factory or clutch manufacturer specs for clutch installation.
I hope that that spacer taps into the crank and not centers on the flywheel bolts. Then there is a ring on the crank to center the flywheel. Whole think looks like a clutch or flywheel launch scenario. But I won't pass judgment till I see the install of this kit.
Old 01-22-2009, 01:53 AM   #10
alesserfate
That is, precisely, why I made this thread. I don't wanna lose my ankles.
Old 01-22-2009, 06:26 AM   #11
S14DB
AFC #1
S14DB's Avatar
yeah, I know a guy with some flexplate in his leg. Those 12mm "washers" scare the hell out of me.
Old 01-22-2009, 06:32 AM   #12
smelly240
smelly240's Avatar
I agree - but if its got a weiner than goes into the crank it might be ok.
Old 01-22-2009, 12:21 PM   #13
Brian W.
Brian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfection
Send a message via AIM to Brian W.
i dont like the spacing the flywheel out idea.
Id stick with my mazworx over that one.
www.ma-motorsports.com
-Fab work, builds, swaps, dyno tuning
Brian W. is offline   Reply With Quote
Old 02-06-2009, 06:30 PM   #14
SuperiorS14
SuperiorS14's Avatar
SuperiorS14 is making his/her stupidity well-knownSuperiorS14 is making his/her stupidity well-knownSuperiorS14 is making his/her stupidity well-knownSuperiorS14 is making his/her stupidity well-knownSuperiorS14 is making his/her stupidity well-known
my buddy is using that kit on his drag s13.....
P2M/G-DIMENSION S13 Drag Coupe
SuperiorS14 is offline   Reply With Quote
Old 02-06-2009, 07:02 PM   #15
1989rps13
1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute
Send a message via AIM to 1989rps13
That looks like a sweet setup
1989rps13 is offline   Reply With Quote
Old 02-07-2009, 04:29 PM   #16
2000gtx
2000gtx's Avatar
2000gtx is an unknown quantity at this point
we use the mazworx set up in our drag 510 with sr20det and so far has worked flawlessly..the fit is good...we are currently installing one in a s13 for drag use also...
2000gtx is offline   Reply With Quote
Old 06-08-2009, 04:15 PM   #17
kognition
kognition's Avatar
kognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfection
Any updates on this? Did you buy the kit?
kognition is offline   Reply With Quote
Old 10-16-2010, 11:30 AM   #18
Slidin' Sam
Slidin' Sam's Avatar
Slidin' Sam is an unknown quantity at this point
Has anybody used this kit? I have been searching for the past two hours (and it's not the first time i have looked either) trying to gather information on this kit/other z32 transmission swaps and haven't found much of anything, except for "What do you guy's think of this?". Thanks!
Slidin' Sam is offline   Reply With Quote
Old 10-16-2010, 02:19 PM   #19
!Zar!
!Zar!'s Avatar
That site doesn't know the difference between your and you're.
Reason enough not to buy.
Old 12-18-2011, 03:05 PM   #20
alesserfate
I ended up not buying it, simply because I don't know how well that flywheel spacer will last with aggressive clutch and prolonged street abuse.
Old 12-21-2011, 08:47 AM   #21
surfpac
surfpac's Avatar
surfpac is an unknown quantity at this point
Look for a Mazworx setup. I just purchased one including Z32 tranny from a Zilvia member who was parting his car out. Look out for used ones on here, or save up for brand new from Mazworx. Those guys are knowledgeable and have experience.
surfpac is offline   Reply With Quote
Old 12-22-2011, 11:49 AM   #22
Slidin' Sam
I bought the mazworx kit and it works great! I too was concerned with the flywheel spacer so I went with this kit instead. Everything bolted up fine...some stuff required a little fab/extra love, but it all works smooth. z32 trans on a sr is the way it was meant to be! lol
Old 03-09-2019, 06:13 PM   #23
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
Old as fuck thead, but tell me about this mazoworks kit?
supersayianjim is offline   Reply With Quote
Old 03-11-2019, 07:48 AM   #24
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
you've been here wayyyyyyy too long for this
http://lmgtfy.com/?q=mazworx
