Old 11-01-2008, 02:49 PM   #391
firelizard
firelizard has a reputation beyond reputefirelizard has a reputation beyond reputefirelizard has a reputation beyond reputefirelizard has a reputation beyond reputefirelizard has a reputation beyond reputefirelizard has a reputation beyond reputefirelizard has a reputation beyond reputefirelizard has a reputation beyond reputefirelizard has a reputation beyond reputefirelizard has a reputation beyond reputefirelizard has a reputation beyond repute
This is sweet.
I remember standing at SCN staring at this car with the Expands, and red/gold scheme.
One of my bigger inspirations to grab a 240 fastback.
Nice to see a high level Canadian 240, but then again, cars repping Speedtech tend to be on the bonkers side anyways,
Speaking of which... I don't think I saw this at DTP this year... didn't make it?
firelizard is offline   Reply With Quote
Old 11-01-2008, 03:22 PM   #392
kuruptR
kuruptR's Avatar
kuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfection
Send a message via MSN to kuruptR
I was sponsored by BFgoodrich, which required me to goto shows to receive free tires. Fuck shows.
Energy Subframe bushings.
First impressions.
- Little to no extra vibrations, there is a minor one but I cant tell if its the exhaust or the drive shaft causing vibration on down shift... It happens once in a while.
- The car is very responsive at lower speeds and controllable at higher speeds 160+.
- eliminates that floaty feeling at high speeds.
- The car was raised about 1/2 an inch on my car by installing these and on my buddies they raised his car about 1".
- You get a snappy feel when manji'ing(sp?)
I was scared these were gonna ruin the ride quality, but in actuality it did not add much vibration at all. The response it adds is amazing. It was a fairly long install, about 5 - 6 hours with 2 people, may take longer if you want to clean everything up like I did. I wire brushed(rotary) all the bolts and plates, cleaning up all the rust off them. Changed diff fluid and reseal the diff as it was leaking.
kuruptR is offline   Reply With Quote
Old 11-01-2008, 03:27 PM   #393
kuruptR
kuruptR's Avatar
Originally Posted by ken.bryle21 View Post
where did you get your paint job done? im from calgary too and im thinking about getting my car repainted...
and how much did the painted job cost you including painting the engine bay?
National Collision, I got hookup. I know the owner.
About the break lines... I got lazy, what can I say?
Old 11-01-2008, 07:48 PM   #394
firelizard
Darn, so you won't be coming to Winnipeg with Speedtech just for fun?
Old 11-02-2008, 03:40 AM   #395
SpuGen
SpuGen is making a name for him/her selfSpuGen is making a name for him/her selfSpuGen is making a name for him/her self
Hot car.
You wont see stuff like this come out of Vancouver.
Calgary = Nothing to do but work and cars. NO NIGHTLIFE hah (joking)
Makes me wish I kept with my hatch instead of picking up a coupe.
Also makes me want to move to Calgary and make tons more than here.
How are the girls in Calgary?
Vancouver's full of LA-posers with their Metrosexual Christian Audiger sponsored BF's.
SpuGen is offline   Reply With Quote
Old 11-04-2008, 11:20 AM   #396
derk
derk is making a name for him/her selfderk is making a name for him/her self
kinda flash backing here but...
the aluminum steering colum bushing thing that you had such a hard time with.. took me about 20 minutes to install haha..
theres a bolt on the lower half of the shaft that clamps down on the splines. once you loosen that you can slide it down and slip the aluminum bushing in easily.
derk is offline   Reply With Quote
Old 11-04-2008, 11:42 AM   #397
lflkajfj12123
^ hahaha that sucks
i hate it when i find out an easier way to do things... after i already did it
Old 11-04-2008, 12:17 PM   #398
kuruptR
kuruptR's Avatar
so you didnt have to remove the entire assembly? hmm maybe you had a looser column.
Old 11-04-2008, 12:42 PM   #399
derk
nopes, didnt have to take out the column, just had to loosen that one bolt that clamps onto the splines, on the lower half of the column, close to the joint where it meets the rack, then the shaft will slide in and out for easy access to that bushing.
now you know for next time
super duper nice car btw, makes me miss my 180
Old 11-04-2008, 01:28 PM   #400
kuruptR
kuruptR's Avatar
yeah thought so, we tried that in 2 cars. It wasnt possible there was no slack in the column to let it do that.
Old 11-21-2008, 03:15 PM   #401
alex70val
alex70val's Avatar
alex70val is a glorious beacon of lightalex70val is a glorious beacon of lightalex70val is a glorious beacon of lightalex70val is a glorious beacon of lightalex70val is a glorious beacon of lightalex70val is a glorious beacon of lightalex70val is a glorious beacon of lightalex70val is a glorious beacon of lightalex70val is a glorious beacon of lightalex70val is a glorious beacon of lightalex70val is a glorious beacon of light
Send a message via AIM to alex70val
cleanest hatch build up!
alex70val is offline   Reply With Quote
Old 11-22-2008, 01:27 AM   #402
ser20det
ser20det's Avatar
ser20det is an unknown quantity at this point
First impressions.
From where did you get them from ? Did you do any mod or cutting to it ?
I just looked and didn't see anything about Energy subframe bushing for s13 !
ser20det is offline   Reply With Quote
Old 11-22-2008, 08:36 AM   #403
upSLIDEdown
upSLIDEdown's Avatar
Location: VA.. And for those that keep PMing me asking what kit I have, it's Origin Stream.
upSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfection
Check the image location next time.
http://i25.photobucket.com/albums/c7...23_2098415.jpg
How about try Phase 2. Under drivetrain. $65.
upSLIDEdown is offline   Reply With Quote
Old 11-22-2008, 09:22 AM   #404
jdm 240sx
jdm 240sx's Avatar
jdm 240sx is an unknown quantity at this point
Looks sick great job on it man. Keep it up.
jdm 240sx is offline   Reply With Quote
Old 11-23-2008, 02:18 AM   #405
ser20det
ser20det's Avatar
Ok then ... what about the fitting ?
Old 11-23-2008, 02:31 AM   #406
1989rps13
1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute
Send a message via AIM to 1989rps13
kuruptR you are my inspiration! i bought the kouki bumper already and coils i hope to in a couple years get to where your at ! wooo i look at your car and it just makes me happy. I love kouki 180 aero its the shizznits!!!
1989rps13 is offline   Reply With Quote
Old 11-23-2008, 03:22 AM   #407
Jodan
Jodan's Avatar
Jodan is a jewel in the roughJodan is a jewel in the roughJodan is a jewel in the roughJodan is a jewel in the roughJodan is a jewel in the roughJodan is a jewel in the roughJodan is a jewel in the roughJodan is a jewel in the rough
Send a message via AIM to Jodan
gangsta gangsta at the top of the list!
http://i6.photobucket.com/albums/y244/stealthtrueno/FB_daft_mix_1.jpg
Jodan is offline   Reply With Quote
Old 11-24-2008, 08:13 AM   #408
SoSideways
SoSideways's Avatar
What fitting?
The metal insert piece?
Those come with the bushings mate...
indeed.
Old 11-24-2008, 11:31 AM   #409
kuruptR
kuruptR's Avatar
So finally got rid of them all. Trying to get a new set of wheels for next season, but having trouble sourcing a set for decent price. Canadian dollar is poop right now, have to wait till it raises to order a set. suck.
Some last pics of my T/A's
Its parked for winter, gonna be working on the interior (refurbishing the electronics, ie heater control)
Old 11-24-2008, 11:40 AM   #410
Z33dori
Z33dori's Avatar
why.. it was so hot
maybe you should hit up on some of the new SSR Type F
Old 11-24-2008, 11:47 AM   #411
lukebaumstark
lukebaumstark's Avatar
Location: inland empire, land of the lifted trucks, rancho cucamonga
lukebaumstark is an unknown quantity at this point
damn did it right...
lukebaumstark is offline   Reply With Quote
Old 11-24-2008, 01:16 PM   #412
kyles1988
kyles1988's Avatar
kyles1988 is an unknown quantity at this point
SSR Type F's would definitely be sick
kyles1988 is offline   Reply With Quote
Old 11-25-2008, 02:31 AM   #413
1989rps13
Originally Posted by Z33dori View Post
why.. it was so hot
why it WAS so hot
this car is hot and the hottest on zilvia period!!!!
kouki 180sx FTW !
lets keep this on the top and have the OP post more pics ive been saving all of them to my photoucket lol
Old 11-25-2008, 10:20 PM   #414
RPS13-604
RPS13-604's Avatar
RPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really nice
I know what you mean man my work meister that i had on my car i paid 18x10 $745.00 and 18x9 $725.00 now i just ordered another set of work meisters for the widebody its costing me $1055.00 for 18x11.5 and $955.00 for 18x9.5 (thats EACH) so im paying about $1000 more
RPS13-604 is offline   Reply With Quote
Old 12-22-2008, 02:33 PM   #415
kyles1988
kyles1988's Avatar
any updates?
Old 12-22-2008, 04:36 PM   #416
kuruptR
kuruptR's Avatar
Originally Posted by kyles1988 View Post
any updates?
my suggestion, wait till the op bumps his thread. Canada has evil winters which means its out of commission for for 6 months of the year. Cant even go in the garage its -27 degrees Celsius in there..
Old 12-22-2008, 04:36 PM   #417
lflkajfj12123
any updates?
more updates yes?
Old 12-22-2008, 11:37 PM   #418
firelizard
Kranze man, Kranze.
Old 12-23-2008, 12:49 AM   #419
Adrian_180
Adrian_180's Avatar
Adrian_180 is an unknown quantity at this point
Send a message via AIM to Adrian_180
just went through the whole build from red to black lol this car is pure HOTTNESS
Adrian_180 is offline   Reply With Quote
Old 12-23-2008, 12:53 AM   #420
cc4usmc
cc4usmc's Avatar
Why are you talking in the 3rd person? You ARE the op lol.
This forum requires that you wait 120 seconds between reporting posts. Please try again in 115 seconds.
Originally Posted by s141996 View Post
is this exhaust california friendly? thnx lmk
cc4usmc is offline   Reply With Quote
