Off Topic Chat All non related chat goes here. |
11-08-2008, 10:49 PM | #32 |
11-08-2008, 10:53 PM | #33 | |
11-08-2008, 11:02 PM | #34 | |
11-08-2008, 11:04 PM | #35 |
You don't just get energy for free. To keep a car moving you have to overcome frictional losses from the tires as well as air. To generate energy to compress air, you have to take it from the moving car. You'd be converting kinetic energy into potential energy of a sort. The point is, you don't do anything for free, and each step has losses from friction (heat). So no, you can't just fill your car with compressed air and drive off at 30mph, turning an alternator to power a compressor that compresses more air to keep you moving.
11-08-2008, 11:05 PM | #37 |
Im not sure if you understand how a car works. But the compressor isnt powered by air it is electric, electricity comes from the battery, the battery is being recharged by the alternator, the pully on the alternator is being turned by the motor? Get it?
11-08-2008, 11:09 PM | #38 | |
11-08-2008, 11:16 PM | #39 |
lol you crack me up. I was reading the thread all serious like and you come outta nowhere with the lulz. It's like being kicked in the balls for no reason.
11-08-2008, 11:20 PM | #40 | |
I just read up on this for a few minutes and you guys are going way beyond what even the inventors are claiming. The farthest an air powered car has traveled is 7.2 km. The goal is 200 km.
You can't use an air motor to power a compressor that will compress enough air to sustain a constant speed. Think about it- that initial filled air tank has a certain amount of energy in it. Some of this is used to turn the motor, while some will be wasted (internal friction, for one). Then, some of THAT energy will be used to keep the car moving against air resistance and rolling resistance, while some will (in your plan) turn an alternator to generate electricity. Energy will be lost in the alternator, and energy will be lost once you run a compressor with it. Sure, you'd be able to compress some air with a scheme like this, but I really doubt it would significantly add to the range. The added weight would also reduce the benefit. Quote:
11-08-2008, 11:27 PM | #41 |
irt b love
Having a battery powered electric motor to compress air to turn an engine which moves both the car and the alternator which charges the battery makes sense to you? It's a compressed air tank supplemented by a flexible internal combustion engine for when you run out of air. What would be cool is a valve system that allowed regenerative braking - have the exhaust air be captured...but since i doubt it would get near 4500 psi i don't think it would work without a separate compressor with a higher compression ratio, which would add weight and complexity you don't need in a car like this.
11-08-2008, 11:42 PM | #42 |
11-08-2008, 11:46 PM | #43 |
11-08-2008, 11:46 PM | #44 |
This thread is killing me. For whoever was talking about only needing enough electric to run a small compressor, instead of a large electric car motor, your wrong.
The size of the electric compressor motor you would have to have would be LARGER than the size of an electric car motor. This is because using electric to compress air is LESS EFFICIENT than using electric to power the car. You are wasting tons of energy, not even just a little wee bit. I can't even imagine this kind of car working because of the massive amount of air flow it would need (500 gallon tanks would likely be drained almost instantly) but to be efficient it would have to compress air without electric being involved, maybe some type of turbo or supercharger to refill the tanks? If you could get something like this to work it would end up being more of a toy than an energy saver I'm sure. I wonder what a car like this could do full throttle with some 4500psi nitrogen tanks |
11-09-2008, 12:41 AM | #45 | ||
Simply put, perpetual motion, is impossible.
Machines cannot be 100% efficient. This is because friction causes energy to be converted into heat and effectively lost from the system. To make this explicit: this loss of energy, no matter how small, will ultimately drain all of the energy from the system and cause it to stop unless extra energy is added. Keep in mind that I'm not knocking the idea of a car that runs on compressed air. Personally, I think that it seems like a good, cheap, low-tech way to get around. The thought that you could somehow make this into a perpetual motion machine, however, is naive and stupid. Sorry for not explaining this in detail previously. I should've known that someone arguing that a perpetual motion machine knew nothing about physics. Quote:
Engrish is funny in Japan. In America, it's for stupid fanboys. |
11-09-2008, 10:32 AM | #48 | |
11-09-2008, 11:35 AM | #49 |
While were at it Fuck You - Wikipedia, the free encyclopedia
11-09-2008, 12:14 PM | #50 |
Bleh I dun wanna read all the replies..but like few have said you can't have a perpetual energy car like that. The compressed air can't power the motor that powers a compressor that fills the tanks and makes the car run forever. It's impossible. Like other people have said there is wind resistance blah blah blah....either way though if it really does take 3 minutes to fill the tanks to go 200 miles that is a fraction of the cost of gas. The amount of electricity that my compressor uses in 10 minutes doesn't even come close to 8 gallons of gas. (I figure 200 miles/25 miles per gallon)...hell even if I had a car that got 50 mpg meaning 4 gallons of fuel. My compressor doesn't cost that much.
It's an interesting idea...I'd like to look at one of these cars..I don't see how they can travel 200 miles in a trip before needing to repressurize. EDIT: And yeah lol whoever said you're just moving the energy from one tank to another was correct. You can't get something from nothing. THOUGH they could have the motor running a small compressor that does fill another tank, BUT it wouldn't put out enough air to completely make the car never need air again, it would just make the range better. It's similar to EV's regenerative braking or w/e it's called where the braking even stores some energy for the car. It doesn't make the car go forever though.. |
