#5 | |
![]() Join Date: Dec 2006
Trader Rating: (28)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 28 reviews
this coming from the guy with 40 posts.
![]() Quote:
for the OP, try here http://www.apexi-usa.com/pdfWiring/18.pdf. the search button is a great tool to use on zilvia to avoid flaming.
AFC #1
![]() Join Date: Oct 2003
It really fucks up your timing maps as they are load dependent. SAFC fakes out your ecu to think there is more load to get more fuel.
#7 | |
Trader Rating: (28)
in other words, for instance, the mafs sees a certain amount of load at 5000 rpms and 50% throttle, which Cell A of the fuel and spark map will be effective, but with the safc, the same cell (A) will kick in at 3000rpms for richer conditions at a given correction setting. so what im trying to say is that the fuel/spark are essentially untouched and "factory", but just shifted (assuming that the fuel/ spark maps are excel format). right?
Here it is. (and its spelled "Write")
Were trying to educate people here not confuse them and make them dumber. http://zilvia.net/f/tech-talk/196800...all-guide.html
#9 | |
Trader Rating: (28)
#11 | |
AFC #1
I will usually manifest it self in dang my manifold is glowing red. Kool I must be making power. Then 6 months down the road they wonder why they melted a piston. Greddy is a little better cause it clamps the Timing too. But you are still faking the ecu. AEM FIC. Handles it differently it leaves the ecu alone to operate like nothing has changed. it takes the ecu's output as a trigger then puts out it's own signal to the injectors/coils. FIC is running the show but the ECU thinks everything is kosher to run the Emissions/OBD, TCU, AC, TC/ABS, ect..
lol. so the more posts you have on zilvia, the smarter you are? I need more posts!!!!
#13 | |
#16 |
