09-05-2008, 01:08 AM | #1 |
s14 oil feed line banjo bolt
hey guys im going to swap in my sr20det this sunday and im missing this banjo bolt for my oil feed line for the turbo. ive went everywhere but nobodys selling any banjo bolt. so my question is is there any options or fitting that i can use? or if any of you guys have it just pm me asap..
heres some pics where the banjo bolt goes.. |
09-05-2008, 08:23 AM | #2 |
you can use this but iirc the stock banjo bolt has a restrictor, so you would need to get a restrictor
Pegasus -Male 12 x 1.25mm Metric Convex Seat to 3AN Male, Steel
09-05-2008, 08:45 AM | #3 |
nice !!! pretent +1 for you!! i was wondering the same thing i needed the size for that thing cuz the one i put on mine is leaking. i might have put the wrong one in.
i fully de-volved |
09-05-2008, 08:55 AM | #4 | |
if you put that wrong one in chances are that you may have stripped the block i hear they are really easy to strip, i would carefully take the fitting out and inspect the threads it they arent all galled or damaged you may want to pick up a thread chaser. DO NOT USE A TAP TO CLEAN threads always use a chaser.. if they are stripped you will need to get a heli-coil to repair it, search someone posted a like to a really good heli-coil for this same problem
