Old 08-06-2008, 09:31 AM   #61
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
Yeah, isn't any swap going to cost more than the gas you save for 5-10yrs?
For real. People are so stupid about this gas mileage shit. Like the lady who spent $7,000 on a '96 Geo Metro to get an extra 10mpg over her Honda Element. Congratulations, you'll break even in about 300 years.
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 08-06-2008, 12:32 PM   #62
eek
Trader Rating: (29)
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
Feedback Score: 29 reviews
If money isn't an issue why are you worried about gas and mpg? Best swap, keep it stock. Go buy a scooter and and get like 80-100 per gal. Join the next trend and sport a Honda Ruckus.
eek is offline   Reply With Quote
Old 08-10-2008, 11:36 PM   #63
zil40
zil40 is an unknown quantity at this point
i have a ca and its not the greatest on the milleage even just cruising down the freeway thestock t25 is always in boost so its not that great for milleage but thats not why i did the swap
zil40 is offline   Reply With Quote
Old 08-11-2008, 12:22 AM   #64
CKAMC
CKAMC's Avatar
CKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfection
gearing makes a difference as mentioned earlier with the q45 diff.
followed by people learning how to drive.
SLOW DOWN
slow acceleration + low revs + overall low speed + coasting a lot + correct gearing = MPG
I averaged in my DD (06 sentra spec v) 33mpg on the highway because I took my time at 70mph instead of going 75~80
I can imagine a lightly moded VQ with the 6 speed trans and 3.7 or lower rear gear and the correct driving can pull off some amazing numbers.
CKAMC is offline   Reply With Quote
Old 08-15-2008, 10:47 PM   #65
jmauld
jmauld is making a name for him/her selfjmauld is making a name for him/her self
Send a message via AIM to jmauld
I think you would have the best luck if you go to a 3.5 rear end, and a small 200hp turbo setup to compensate for the gearing change. Tune it correctly and you should come out with more power and better gas mileage.
Is there a six speed transmission that will fit the KA or an alternative 5th gear for the KA trans?
Jason
'95 240sx SE
jmauld is offline   Reply With Quote
Old 08-16-2008, 09:04 AM   #66
S14DB
AFC #1
S14DB's Avatar
CA tranny with the KA/SR rear end? 5th gear in the CA tranny is shorter then the KA/SR. Keeps it at a higher rpm for drivability. Swap your CA bell housing on a KS/SR tranny and you'll cruse at a lower RPM.
Old 08-29-2008, 01:19 AM   #67
bboyswoosh87
bboyswoosh87's Avatar
bboyswoosh87 will become famous soon enoughbboyswoosh87 will become famous soon enoughbboyswoosh87 will become famous soon enoughbboyswoosh87 will become famous soon enough
I'm newbie here whats a Ls1
bboyswoosh87 is offline   Reply With Quote
Old 08-29-2008, 01:31 AM   #68
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
its a 5.7 liter Pushrod v8 that can be found in 98 and up camaros, c5 corvettes, firebirds, and stuff.
350hp 350tq stock.
I have built a few. My last one a fc with a turbo ls1 made around 500 whp and got like 30 mpg.
blu808 is offline   Reply With Quote
Old 08-29-2008, 04:44 AM   #69
S14roundi
S14roundi is an unknown quantity at this point
Go with the SR DET. Factory tunes run rich to avoid detonation so just get a better tune to lean it out and you will have instant increase in MPG and more horsepower than your KA all in one reliable package.
S14roundi is offline   Reply With Quote
Old 08-31-2008, 09:00 AM   #70
Colorado S14
Colorado S14 is on the path to ruinColorado S14 is on the path to ruin
I get 26-28 on my turbo KA, the key is a big turbo.
Colorado S14 is offline   Reply With Quote
