#61 |
![]() Join Date: Oct 2006
Dear Mr. Smog Tech,
My S13 failed NOx last week. Is it likely that it failed because of my 3" exhaust? I have heard that the lack of backpressure doesnt let the EGR operate properly. Any insight into this? |
#62 |
![]() Join Date: Aug 2006
i have a ?. im putting my ka24de s14 back into my s14 its a 95. i want to know if i can pass smog with some header i have. i believe they are obdx headers they have the egr value connectors and so if i install before i drop it in will it pass smog, or would it be better to just put on the regular exhaust manifold and pass smog and then change it?
#63 |
![]() Join Date: Jan 2007
When you plug into an OBD2 motor, does it give you information on what type of motor it is?
I'm just wondering if i swap for another obd2 motor and i get it running properly and not throwing codes if they'd even notice.
#65 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
if you get the guy that doesnt really care, as long as he sees that the headers have the egr valve connectiors and all the vacuum lines and shit are connected, he probably wont give you grief. i would just throw on the normal exhaust manifold just to be sure, since your already throwing a whole new engine into the KA, then just swap it later. |
#66 |
some obd 2 pcm's will tell you the VIN number of the car they originally came in. but the only thing the smog machine checks for is readiness monitor status and diagnostic trouble codes.
#67 |
![]() Join Date: May 2006
+a shit ton for this thread. Thanks a bunch man
#70 |
![]() Join Date: Jan 2008
Dear smog tech
i justa had a smog but failed heres the list of wat i failed........... fuel evaporative control funtional MIL/check engine light everything else is good. how can i fix that? i know its a leak but how would i go by finding it, i tracked it down to the rear end of the car but no luck finding it. HELP!! need smog ASAP |
#71 | |
however, alotta smog techs are lazy as fuck, or if the smog joint is busy, they will not even bother to give the engine a second glance and will just pass everything on the visual. but generally, you'll have Mr. 'merican performance chevy 350 master, who generally doesnt know what and SR looks like. and if he doesnt bother looking at the engine because "its a goddamn piece of shit rice burner," and "all these 4 bangers are the same" |
#74 | |
i would check all the rubber hoses connecting from the gas tank up front to the charcoal canister, then the filler neck on your gas tank. the check engine light on a pre-obd2 car is an insta fail. so try pulling the code off the ecu and go from there. |
#76 |
mr. smog tech, I think you should pull the info of where you work off this thread or other threads, and your location.
I would hate to see this thread get into the wrong hands. Never learned half this info from anywhere else. +1 for you. |
#78 |
![]() from what i read earlier it said that if i remove the light bulb for the check engine light then my car can pass smog? im not getting it exactly cause im really looking for a place to smog my car non-legally but if thats all i have to do then let get that done. i know that the check engine light is part of the visual inspection part only so how else would it fail?
1996 zenki 240sx |
#79 | |
#80 | |
Trader Rating: (92)
![]() ![]() ![]() ![]() Feedback Score: 92 reviews
was wondering mine has a EP on it and mine is manual 93 ka24de is there anyway to confrim this ecu actin all wierd |
#81 |
Waddup? I have a 96 S14 that passed the emissions test but failed becuz the CEL wouldn't come on. The smog tech said that my ECU wasn't throwin any codes eithr so I though it was a burnt bulb. I then bought a bulb from Nissan and just swapped it out with the old one, and still no light. I unplugged the battery for a good several seconds and reconnected, but still no light. I also put the ECU in diagnostics mode and then had it reset, but still not light. Any ideas?
Also, some of the guys here wrote about rewiring it to the oil pressure light...can anyone tell me how u do that and which wires to rewire on the back of the instrument panel? I'll also be lookin it up in my manual in the meantime to try to figure it out. Thanks.
"Life is...Vuetiful!" |
#82 |
NVM...for some reason...it's now working. I'm not sure if this may be why, but I stuck a wire from the the oil pressure wire to the CEL wire and then it came on, and stayed on after i removed the wire...maybe it just needed a jumpstart..haha.
#84 | |
#86 |
![]() Join Date: Feb 2006
Trader Rating: (22)
My girls car...
91 S13. 95 KA-DE. New cat. Timing is perfect. Recently Seafoamed to clear the carbon deposits. New plugs, wires, cap and rotor. EGR works perfectly... Nox is STILL 6 times over the legal limit. Any ideas? |
#87 | |
![]() Join Date: Aug 2007
off topic new plugs and wires still misfiring gonna try a new cap n rotor tommrow too and i also need to check timming |
#89 | |
![]() Join Date: Jun 2006
Wurd. Good oil change? ^^ What did you fail at...
I pass well with. S14 95 KA Stock cat 3' exhaust AEM intake
#90 |
Mr smog tech.
I have a 97 honda civic witch just got approved for assistance with smog repair fees it failed for high Nox during the 15 mile per hour run any idea what it might be its a bone stock car |
