Old 08-02-2008, 06:45 PM   #1
95Kouki
95Kouki's Avatar
95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough
s13 !!! - FS: S13 Fastback...The Works - !!!
Posting this car for a good friend of mine.
This is an 89' Nissan 240sx with 150 miles on complete build. The car was repainted Canteen Green from the US Version Nissan Xterra and Titan, which looks amazing! There was no motor, transmission or interior in the car and all sound tar had been removed when it was painted, so it allowed for a proper job. The front and rear fenders have been replaced (front)/rolled and pulled (rear) to 20mm (front)/1.25" (rear) to allow for the perfect fitment of the 9" and 10" low offset 5zigen wheels. The SR20 motor was hand picked form XS Engineering where it was Compression and Leak Down tested before leaving the shop. Every aspect of this vehicle has been taken into consideration and no expense has been spared on this project. This is the ultimate drift/show vehicle and has everything you could ever need!
Interior:
OEM Nissan S13 Radio Bezel: $99.95 (West Covina Nissan)
S14 Seatbelts: $50.00 (eBay)
OEM Nissan Pedal Set: $64.13 (A to Z Auto Salvage)
Taylor Battery Box: $159.95 (Summit Racing Equipment)
OEM Nissan S13 Dash: $250.00 (eBay)
Nismo GT Spec Shift Knob: $75.00 (Phase 2 Motortrend)
Circuit Sports Drift Knob: $14.25 (Phase 2 Motortrend)
3 Pod Gauge Bezel: $22.00 (Dave Reagan)
Powdercoat Gauge Bezel: $20.00 (Aries Blasting)
Bride® Seat Rail (L): $180.24 (West Covina Nissan)
OEM Nissan Shift Boot: $45.00 (Antelope Valley Nissan)
Carbon Fiber Sheet (Wet): $30.00 (Dream Sport)
Bride Zeta III (Red): $760.95 (Aspec)
Works Bell Short Boss Steering Hub: $150.00 (Aspec)
Works Bell Rapfix II Steering Wheel Quick Release: $298.00 (Aspec)
Works Bell Hub Lock: $120.00 (Aspec)
Auto Custom Carpet Front Floor Mats: $44.95 (Stock interiors)
Exterior:
89' Nissan 240sx Base Model Rolling Chassis: $700.00
180sx Position Lights: $145.70 (OptionImports.com)
5Zigen FN01RC (4/Bronze): $1013.00 (Bestway Autosports)
Federal 595SS 225/45/17 and 235/45/17 With 150 Street Miles
5Zigen Lug Nuts (Red): $100.00 (Bestway Autosports)
JDM Kouki Taillights: $499.95 (Phase 2 Motortrend)
OEM Nissan Headlight Assembly: $54.13 (A to Z Auto Salvage)
Version:SELECT 180sx Version III Front Bumper: $218.33 (Version:SELECT)
Version:SELECT 180sx Version I Rear Bumper: $218.33 (Version:SELECT)
Version:SELECT 180sx Front Fenders: $260.00 (Version:SELECT)
*(Body Kit Pricing Reflects Full Kit Pricing, Including Side Skirts)
180sx Quarter Glass: $250.00 (Bestway Autosports)
House of Kolor F14 Rainbow Flake: $45.67 (Antelope valley Auto Paint)
Rear Window Mouldings: $221.70 (Antelope Valley Nissan)
Paint and Body Work: $6,000.00 (Affordable Auto Body)
Painted Canteen Green From The US Xterra and Titan Models
Everything Was Removed When Painted; Including Motor
New Front Windshield: $235.00 (Antelope Valley Auto Glass)
Motor:
Nissan Red Top SR20: $1800.00 (XS Engineering)
Modification To Muffler: $60.00 (Eastside Muffler)
Greddyä Oil Block Sandwich Adapter: $56.00 (Options Auto Salon)
Greddyä Radiator Hose/Water Temp. Adapter: $23.25 (Options Auto Salon)
OEM Nissan Lower Radiator Mounts: $20.13 (Antelope Valley Nissan)
Circuit Sports Coolant Reserve Tank: $95.00 (Phase 2 Motortrend)
Nismo® Engine Mount (R): $75.00 (Phase 2 Motortrend)
Nismo® Engine Mount (L): $75.00 (Phase 2 Motortrend)
Nismo® Transmission Mount: $65.00 (Phase 2 Motortrend)
Circuit Sports Hood Damper: $99.00 (Phase 2 Motortrend)
Greddyä Type RS BOV: $200.00 (Garage Works)
Greddyä M-Spec Intercooler: $780.00 (Garage Works)
BOV Recirculation Kit: $20.00 (Garage Works)
AEM Filter Kit: $60.00 (Garage Works)
OEM Nissan Water Pump and Rear Main Seal: $80.00 (Garage Works)
OEM Nissan Z32 Fuel Filter: $20.00 (Garage Works)
Motor R&D: $1666.00 (Garage Works)
OEM Nissan Manual Cross Member: $20.00 (Garage Works)
Used SSP Driveshaft: $80.00 (Garage Works)
OEM Nissan Clutch Master Cylinder: $45.00 (Garage Works)
OEM Nissan Clutch Slave Cylinder: $30.00 (Garage Works)
OEM Nissan Power Steering Belt: $20.00 (Garage Works)
OEM Nissan SR20 Fan Shroud: $45.00 (Performance Nissan)
Samco Radiator Hose Kit: $85.00 (Option Imports)
5Zigen Border 304 Max Exhaust System: $598.99 (Phase 2 Motorsports)
XS Engineering Downpipe: $99.00 (Phase 2 Motorsports)
Koyo S13 SR20 Aluminum Radiator: $285.00 (Phase 2 Motorsports)
Walbro G35341 255lph Fuel Pump: $99.95 (Phase 2 Motorsports)
Suspension:
Circuit Sports Aluminum Subframe Spacers: $71.25 (Phase 2 Motortrend)
Orange Tree (Battle Version) "RUCA": $229.00 (Phase 2 Motortrend)
Stance GR+ Pro Coilovers: $1,200.00 (Stance USA)
Drivetrain:
Ichiba 5 Lug Conversion (Front): $275.00 (Phase 2 Motortrend)
Ichiba 5 Lug Conversion (Rear): $275.00 (Phase 2 Motortrend)
Resurface Flywheel: $80.00 (ACT)
ACT Heavy Duty Clutch Kit: $389.95 (ACT)
OEM Nissan Z32 Brake Conversion (Front) With Steel Braided Lines (4): $450.00
OEM Nissan Z32 or Other Brake Master Cylinder Will Be A Necessary Upgrade In Order To Achieve Maximum Performance From These Brakes
S14 VLSD: $250 (Not Installed)
Electronics:
Apexi Turbo Timer: $103.00 (Option Imports)
S13 Turbo Timer Harness: $16.15 (Option Imports)
Defi BF Boost Gauge: $217.60 (Option Imports)
Defi BF Water Temp Gauge: $190.40 (Option Imports)
Defi BF Oil Temp Gauge: $190.40 (Option Imports)
Defi Control Unit (Version 2): $103.00 (Option Imports)
Energizerä Battery: $69.99 (Pepboys Auto)
Miscellaneous:
Miscellaneous Bolts, Clips, Fasteners, Etc: $31.52 (Antelope Valley Nissan)
Additional Labor: $3,250
Asking Price 17,500 OBO
People will always be haters...can't change that...just out drive them
95Kouki is offline
Old 08-03-2008, 02:25 AM   #2
driftJDM
driftJDM's Avatar
driftJDM is an unknown quantity at this point
HOT damn gimee a couple days so i can go rob a bank and buy this
driftJDM is offline
Old 08-03-2008, 03:14 AM   #3
1989rps13
1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute
Send a message via AIM to 1989rps13
This is the kind of direction i want to go with my car when i get a career to be able to affford it....that 240 is just done well i love everything about it
1989rps13 is offline
Old 08-03-2008, 07:52 AM   #4
qwikspool
qwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfection
Send a message via AIM to qwikspool
nice car
i like the paint job.
glws
qwikspool is offline
Old 08-03-2008, 09:17 AM   #5
kouki_pants
kouki_pants's Avatar
kouki_pants will become famous soon enoughkouki_pants will become famous soon enoughkouki_pants will become famous soon enoughkouki_pants will become famous soon enoughkouki_pants will become famous soon enough
bump for the pantie droppin' disco flake
glws
kouki_pants is offline
Old 08-03-2008, 10:26 AM   #6
arlocks13
arlocks13 is a well-known jackass
Absolutely BEAUTIFUL! Any chance shes single?
Coil Overs- $1200+
Full s13 to s15 Conversion $2500+
1989 stock s13 Fastback with gutted backseats and ghetto rigged home sterio speakers - priceless
arlocks13 is offline
Old 08-03-2008, 11:57 AM   #7
Dominic Axelson
Dominic Axelson's Avatar
Dominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfection
Send a message via AIM to Dominic Axelson
what the hell are you talking about bro?
nice car glws.
Dominic Axelson is offline
Old 08-03-2008, 01:25 PM   #8
jdmstatuS13
jdmstatuS13 has a spectacular aura aboutjdmstatuS13 has a spectacular aura aboutjdmstatuS13 has a spectacular aura aboutjdmstatuS13 has a spectacular aura aboutjdmstatuS13 has a spectacular aura aboutjdmstatuS13 has a spectacular aura about
hah dayamn !! i usually dislike hatches, but this one makes me wanna sell my coupe !!
jdmstatuS13 is offline
Old 08-04-2008, 01:13 AM   #9
95Kouki
95Kouki's Avatar
bump...bump...bump!
95Kouki is offline
Old 08-04-2008, 12:21 PM   #10
rb26man
rb26man's Avatar
rb26man has a spectacular aura aboutrb26man has a spectacular aura aboutrb26man has a spectacular aura aboutrb26man has a spectacular aura aboutrb26man has a spectacular aura aboutrb26man has a spectacular aura about
Send a message via AIM to rb26man Send a message via Yahoo to rb26man
damn thats one sick as hatch...makes me want to get rid of my 14 glws
rb26man is offline
Old 08-04-2008, 01:33 PM   #11
ifj
ifj is on the path to ruinifj is on the path to ruinifj is on the path to ruin
bump for a very creative looking hatchback. i've never seen a hatch like that one b4~
ifj is offline
Old 08-06-2008, 02:48 PM   #12
95Kouki
95Kouki's Avatar
to the top?!?!?
95Kouki is offline
Old 08-06-2008, 03:10 PM   #13
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Damn this car is super nice! I really like it.
FaLKoN240 is offline
