![]() Join Date: Mar 2002
high beam fix??
Hey, I remember reading awhile ago that someone asked why there passenger side high beam does not work and then someone told them it was just something that Nissan did on the S13 and I think other manufactuers did also.
Well my question is has anybody figured out a fix for this?? I think there is a kit you can buy from Nissan but its not that important to me but has anyone rewired it to work both?? It would be great to know cuz the high beam is crap. And please dont say get brighter headlights I know that would be better and will happen eventually but is there a fix?? Thanks
90 240sx Coupe |
Well, both high beams on my S13 work, so I don't think your condition is normal. More likely the high/low switch in the stalk isn't making proper contact and it's only tellling the driver's side to go high. Of course, that's a guess...
![]() Join Date: Dec 2002
When I first got my 92FB (a few months ago) the passanger side high beam wouldn't come on either. Then about a month after I had it, niether of them would work. Since then I've replaced my headlights with those cheapo "cool blue" sylvanias (I'm broke ok) and put in fogs. So between those two my low beams are more then bright enough.
On a side not however, since my high beams don't work now- when I push the lever forward my headlights simply cut out. In early December I was approacing a corner (at night) lifted up the turn signal, and in the process accidentally pushed it forward turning on my brights. Except they don't work, meaning I had no headlights. So I just waited untill I had cornered to fix the problem since there was plenty of street lighting, and my headlights were doing jacksquat anyways. But of course it happened to be my luck that a cop was sitting across from the corner and gave me a $90 ticket for not having my lights on, even though I explained to him what the problem was. ![]()
Gimme a "A"! Gimme a "P"! Gimme a "C"! What does that spell? CRAP! |
I think the combination switch may be screwed up. On my 89, I have the problem where I have no High Beam system, and when I move the switch forward or try to flash, it does nothing. Someone told me those combination switches used to break all the time on Nissans and I did recall having to change one on someone's old Sentra for the same reason. I'll try to change mine soon and let you guys know if that solves it...
Hey everyone!
I'm new to this forum, and i did do a search for my issue with my car. a lot of answers show up that is similar, but i've noticed one thing is that when i turn on my high beams, isn't there suppose to be some kind of blue light in the instrument panel that is suppose to be on letting you know that the high beam lights are on??? so thats part of my problem. the other is that my passenger high beam doesn't turn on at all. the driver side works but the passenger doesn't work. I had already checked the fuses but all the fuses seem to be ok. any suggestions that may solve this problem. Thanks! |
When I bought my 240 the high beams didn't work. I checked all the fuses and they were all good. I tried to look for the relay but couldn't find it. I then just decided to buy a new switch. Now my high beams work. I bought it at mynismo.com. Just go to the oem parts on the web site.
![]() Join Date: Jul 2012
bump.
when i try to turn my hi beams on, my lights just turn all the way off and my my turn signals don't work either the car was like this when i bought it 5 years ago and I never fixed it if my bulbs and fuses are good should I replace the lever and switch on the steering column? |
#9 | |
![]() Join Date: Mar 2009
