![]() Join Date: Feb 2008
Coilover Removal Oddness. Help?
Ok, so my friend has a set of ksport coilovers on his s14 that we have to take off since they blew after 9k miles. But anyways, we get all 3 off and then we get to the front right coilover and it wont come off..
The top nut and bolt came right off. BUT heres some shit... i get the nut off of the bottom bolt, but the bolt is seized! I spent about an hour soaking it in penetrating oil, hammering at it, tryin to wedge it with a flathead, turning it(which it doesnt even turn), and I have no clue what to do now! This sounds like a dumbass question, but im an ASE mechanic and I dont know what to do. By the way im at my house garage with no air compressor or impact wrench. I have a sledgehammer, breaker bar, and a lot to work with. I need ideas! Its on there good. |
![]() Join Date: Mar 2003
unbolt the top camber plate from the car and let the coilover hang to ensure theres no load on the system. then go at it with the biggest hammer you can find.
or just cut the bracket apart... it's not like you're going to miss it. |
Same thing happened to me last weekend, the damn nut and bolt cross threaded and seized. I went at it with a wrench to keep it stationary, and on the other side I used a ratchet and a breaker bar. I kept going at it until it stripped off all the damn threads on the stud and it was out. I was tempted to go at it with a cutting wheel.
Edit: After rereading, it sounds like you just need your breaker bar and break it loose.
and i forgot to add that bolt is stripped. i tried jacking the car up buy the bolt and pushing down... that didnt work. and then I tried standing. this thing is seized. i think what happened is he used a low ass grade bolt, all the others were fine and oem.... any ideas now?
![]() Join Date: May 2005
cut it off.............
![]() parking lot pimpin... Seller Feedback here: http://www.zilvia.net/f/showthread.p...ight=pbcstylez |
#15 |
![]() Join Date: Oct 2005
well if both the wheels are in the air. the suspension is slouching down. try using a jack under the arm to lift it and ease pressure off the bolt. worked for me. get the other bolt and a hammer and wack, repeat process until pissed off. if that fails get the torch out. GL!
#16 |
![]() Join Date: Dec 2006
I had this happen I ended up breaking the the head off so I had to drill it out, if your lucky you can drill it half way and use a punch to knock it out
#17 |
![]() Join Date: May 2006
If you don't have a long pipe to attach to the breaker bar, use your tire iron (the cross wrench type) and attach it to the breaker bar. It should give you a foot or more of leverage.
#18 |
![]() Join Date: Dec 2002
I've had OE bolts seize in the spindle before just like that. Take the whole spindle off and beat it out with a sledge hammer. I actually had one frozen so bad that after breaking it loose it still wouldn't slide out because I crowned the end so badly it wouldn't fit through the hole in the strut. I ended up cutting it in half afterwards.
#20 |
![]() Join Date: Sep 2006
Are you talking about the 2 bolts that sit side by side in the bottom of the front?? put the other one back in so there is no pressure pinching it sideways. Snug it up, then try and break the problematic bolt.
I also had a stripped and siezed nut on my rear shock bottom before. i took a lil circle grinder and ground the nut down on two sides, oposite each other. as close as I could grind with out hitting the threads of the bolt. then I took a open ended wrench that best fit, and turned it. due to all the head from the grinder and the lack of having a thick metal wall, the thing came off like presto chango, done ![]() |
#21 |
so drilling this thing is taking hours and isnt really getting everywhere. I grinded down the top of the nut to try and split it, but thats not working....
so im stuck with a flat bolt still stuck. its amazing.... i really dont know what to do. i drill and drill and drill and drill, and no progress. ive gone through at least a dozen drill bits... now i have a circular cutter... will that help? im sooo fucked. its obviously not stuck on the threaded side. i can pry it and see it separate. but on the head side, it wont pry at all.. i wd40'd the crap out of it and still nothing.... the other thing is i could cut through the arm, but i cant really imagine how hard it would be finding another one.. help! |
#22 | |
![]() Join Date: Apr 2008
It took 4 people and 2 days to remove these 4 oversized bolts!!!! You'd thiink that "Cutting" and "Drilling" would work, but NOPE. It was hell. We took a Craftsman 28" 1/2 inch breaker bar plus an additional 36" solid steel tubing and we were basically using our entire body weight on it. Sometimes even sitting, stomping, and standing on the bar. It takes a while, but surely enought the 4 bolts came out and they were immediately thrown in the trash can. Went to the local junkyards and got new bolts off of an s13. If I knew this before, I would have slapped the previous owner of the car and tell him to never ever work on a 240sx again. Good luck!!! WD-40 and breaker bar + metal tubing!!!! |
#24 | |
Since you're already in this position. JUST remove the entire lower arm. Remove the knuckles, take it out, and hammer that sucker bolt out. That's your only option now. |
#26 |
i guess i worded that wrong..i dont have a nut to use a breaker bar on anymore! its just flat. it completley circled off, so i ended up grinding it down. basically all i have is this bolt that looks like a nail now. i just spent another hour drilling and killing more drill bits and no luck. more hammering, no luck. more wd, no luck. heated it up, no luck.....
Once again... HEEELLP! this is like a nightmare from hell! |
#27 | |
#28 |
![]() Join Date: Jul 2006
not on the direct problem but...
to prevent your coilovers from blowing try lowering it from the adjustable mount not by the perch.. i see a lot of people blowing struts by improper use.
95 SR Zenki | @ e_form daily - A34 Maxima | A36 Maxima |
#29 |
i wish i had a picture... i cant find my damn camera. i cant hammer it anymore.... its just a "nail" and the other end is cut off... so hammering isnt an option...
i can only drill on the nut end becuase the drill is too big to clear the head end.... i keep killin drill bits about 20 seconds in... why is that? there carbon steel! any other ideas? im thinking these options... -go out and buy some expensive ass drill bits, drill it out -take off the whole arm, which is a PITA, and take it to my shop and drill press it out, or something.. -or see what the zilvian's have to say.. |
#30 | |
Edit: Just take the spindle off man, its not that hard.
