03-31-2008, 12:28 PM | #181 |
Just got my car dynoed. Made 379whp @ 19psi. It was dynoed at 21psi and there weren't any gains so we went back to 19psi.
2871R .86 w/ HKS actuator Blitz SBC-iD Apexi PFC (MAP based) HKS Step 1 HKS 740cc Cometic HG stock thickness GReddy IM Tomei TB Hybrid FMIC Electric fans JUN flywheel Spec Stage III GReddy elbow Megan DP Invidia exhaust Peak Performance Composite Intake Gasket BPi 6in velocity stack
04-01-2008, 10:11 AM | #183 |
nice numbers dreamer! like prodigy said, get some higher lift cams and you'll have some more top end. instead of dropping off like that at the end, it should keep going! get some step 2 264's and good springs and raise the rev limit to about 8k or so. that and you should probably be able to push a bit more boost through that turbo for even more power!
04-01-2008, 11:39 AM | #184 |
OMG Tomei Throttle Bodies??!?!?! I have almost the same setup except the TB, but is the HKS Wastegate so much better than the one that comes with the turbo?
Turn and Burn! |
04-03-2008, 08:15 AM | #185 |
S13DREAMER : I have those same injectors and map pfc and could not find the lag time for the injectors to save my life and was wondering what you put in for the lag time/correction.
Here is what I did .66 (which is nismo/tomei lag time) - .58 (stock injector lag time) so you have .66 -.58 = .08 I saw on another thread that you just guess for you sweet spot which they used .83 - .58 = .25 (which the pfc dosnt show .25) .24 or .26 I choose .26. I also did 370/740=.50% |
04-03-2008, 08:34 AM | #186 | ||
Torque is made with optimum lift and duration. I prefer between 260 and 264 max for intake and exhaust on an sr20det setup reving to 8k or under.
Like Me on FaceBook ! |
04-03-2008, 12:37 PM | #187 |
so i am runnigna .64 and 264 cams. the 64s go together lol.
actually ididnt even realize that until now. but i did alot of searching and i wanted cam that would be open the most during the turbos power band. with my tune and intjectors and cams whould put me right up near 400 rwhp |
04-08-2008, 10:23 AM | #188 |
higher lift will still help in the top end. the more the valve opens, the more air that gets shoved in there. Maybe, I'm wrong, but that makes sense to me.
04-08-2008, 11:17 AM | #189 |
your wrong.
Higher lift HELPS but duration is what actually "breathes" more at higher rpms. low duration with high lift equals a lot or torque, high duration with low lift equals more top end power. almost all the time. there are variables in tuning of course. There is also a law of deminishing returns with cam sizing. If you go too large on lift (over 12.-12.5 mm) you just are not getting any more efficiency out of the head (most nissans at least). 11.5-12.0 is the largest I would go with stock displacement and stock valve size.
04-09-2008, 12:29 PM | #191 |
fine then
04-09-2008, 02:26 PM | #193 |
Anyone ever use a T3 exhaust housing 2871r? Just curious because I just recently noticed it's an option. Is there any point, or would it be better to just go with a 3071r? I suck at turbos.
Steve? |
04-09-2008, 02:45 PM | #194 |
the T28 wheel is smaller, Housng flows more gas, you make a little more breathing room all over with the same wheel, good idea in theory.
Try it, could be better than the 3071R for certain things. Only worth it if your using a 38-44 mm external though
04-09-2008, 03:14 PM | #195 | |
Thanks. |
04-19-2008, 07:34 PM | #196 |
are there any videos out there of an sr with 2871 .64, cams, high teens boost or anything making around 360rwhp with that general setup
videos that show an actual car moving, would like to see the response and acceleration im in the middle of my motor build which includes the 2871, would like to see what I should be looking for, as in acceleration |
04-20-2008, 06:48 AM | #197 |
Just ran my 2871R .86 at the track friday night. Best time was a 12.06 @ 120.5mph, 1.9 60ft. Was trying to boost 24psi but spark kept blowing out anything over 20 so the time was @ 18psi. I think the problem is the spark plugs not being cold enough.
1995 Nissan 240sx *RB25DET* |
04-21-2008, 03:21 PM | #201 |
Yea some have but many cant. I fall into that category that cant. Anyways, mods are built block, P&P head, Tomei 270 Cams, Greddy Intake, Ichiba V.II Manifold, and Enthalpy Tune that isnt the best tune.
04-22-2008, 07:06 AM | #202 |
upgraded ignition system? and what plugs are you running?
with 20+psi of boost on that setup you should be able to do low 11's at 125 or so with a good launch |
04-22-2008, 04:00 PM | #203 |
^ yep... my car ran a 12.4 @ 307ish WHP...
I just dynoed my car and it made 330whp@ 15 psi.. then my EBC shit out on me... im guessing around 400whp at 22 psi on pump gas (93).. I have HKS 264 step2, but ill be happy with 375ish |
04-22-2008, 04:57 PM | #204 | |
I don't believe I am having this problem, but could someone enlighten me as to how you would know if this was happening....aka sypmtoms
Daily driven |
04-22-2008, 05:03 PM | #206 |
maybe .025 is too small of a gap. .03 should be enough. if the gap is too small there will be less atomized air fuel mixture being ignited. A smaller gap means less volume of A/F mixture and a smaller surface area of spark.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
04-22-2008, 05:11 PM | #207 | ||
Trader Rating: (58)
Feedback Score: 58 reviews
I'll try to get some video when my car is back out. It's kinda nutty with the 4.60's in it!
04-23-2008, 04:48 AM | #208 | |
well of course. thats why i said with a good 60'. and by good 60' i mean atleast a 1.6 |
04-23-2008, 04:50 AM | #209 |
I ran a 12.4 on a stock ecu, stock maf, stock injectors w/ a FP Big28 turbo lol. I dyno'd 330whp and ran an 11.59. But I was pulling very good 60' times
