10-25-2007, 10:03 AM | #91 |
True enough on both counts
www.nissanroadracing.com |
10-25-2007, 10:36 AM | #92 | |
10-25-2007, 10:51 AM | #93 |
Man, I want to ride in someone's car that has this setup. I've only experienced Stance GR+3's that weren't even messed with really.
I've been looking into Topline Aragosta (since you can get custom springs and they provide the customized shock dyno afterward) but every time I read about the Koni setup I hear such great things about it. Oh and I can never go to the Moton site or I just drool.
10-25-2007, 10:55 AM | #94 |
R.I.P. Aya, always love
Trader Rating: (215)
Feedback Score: 215 reviews
Ok I stated it before and I will say it again I am going to do a Koni setup.
P.S. driftfreek is not me!
"Having a lot of tracks on a song is like putting stickers on a car to get more horsepower" New Video https://www.youtube.com/watch?v=uebV1OnbRsw Buy my mounts! http://zilvia.net/f/sale-items/51531...ns-mounts.html http://zilvia.net/f/tech-talk/317539...e-mouts-6.html |
10-25-2007, 10:56 AM | #95 |
I haven't driven a set of Zeals yet, and I can't say I've been extremely impressed from the shock dyno's i've seen either. They look a little better than most the JDM stuff, but I still wouldn't compare them to Koni, Penske, Bilstein, Moton, or Ohlins.
10-25-2007, 11:01 AM | #96 |
Subscribed!
It's just a matter of saving some money now and I'll be bugging some of you guys. Dave, can I have a ride in the Ohlins equipped car? Pretty please? |
10-25-2007, 12:28 PM | #97 | |
So, if anything, get Topline if you want a coilover. I'm still debating back and forth between them and the Koni setup, but I'd still eventually like to have Motons on my car.
10-25-2007, 12:33 PM | #98 | |
I've autocrossed his car on several occassions, rode and drove his car with all 4 of these setups and have my own opinions, which should be take with a grain of salt of course. I know it's not a S-chassis, so take it as you will... Ohlins - He's been running these for the past 1.5 years and has about 6K track miles on them. Riding in the car you can hardly even tell your on 7K/6K springs and it eats up the biggest bumps and railroad tracks without the need of a kidney belt or a mouth piece. I don't think he'll ever change from this setup... of course this was not cheap by any standard. Zeals - these killed the JIC's and stock struts, but seemed to have more compression built into them than Brian liked. On the track, coming out of lower speed corners at full boost his car would actually start oscillating... you could feel it as the passanger and see it from the side of the track. On the road it was stiffer than he wanted for the several long drives he takes with the car. Stock struts/GC hardware - Was fine, but the struts would start to fail on track after 15 minutes... they just weren't up to the task of track duty with stiffer springs. JIC - crap... bouncing headlights going down the road, that's all I need to say about them. |
10-25-2007, 01:31 PM | #99 |
Autox Technician
Koni 8611's are awesome. They're pretty much as good as it gets untill Moton/ Ohlins/ Koni 28's.
Spring perches set here: Sit here: (Crappy pic I'll try to get a better pic later... but long hours at work = I get home when it's dark
10-25-2007, 06:12 PM | #101 | |
Autox Technician
Yup, that's the "new" car. I bought it cheap with some minor rust and a lot of body damage, but I can deal with some dings since the rears will get over-fendered this time around.
10-25-2007, 06:24 PM | #102 | |
Thanks. |
10-25-2007, 08:06 PM | #103 |
I'm pretty sure PJ's referring to the bearing spacers he had to use... they are a 14mm I.D. (the thickness of the 86xx threaded shaft) to 16mm O.D. (I.D. of the bearing in his D2 camber plates) metal sleeve. The same goes for the rear...
10-25-2007, 11:51 PM | #106 |
Ground Control Sleeves with KYB AGX
Hello.
First off Hi, I browse this site a lot but post very little, just learning and keeping a low profile until I have some wisdom of my own to share. That being said, here's the noob question. Can I take a KYB AGX replacement strut (as in the whole strut assembly, not just an insert) and cut off the large conical section of the spring perch? Seems to me that the GC sleeve would then sit nicely on the remaining lip. See the pictures in http://cgi.ebay.ca/KYB-AGX-Shocks-St...QQcmdZViewItem for clarification, the 2nd one down gives the best view (for me). Thanks in advance. |
10-25-2007, 11:54 PM | #107 | |
Welcome to the blue Veilside.
10-26-2007, 07:46 AM | #108 |
I want some Konis now too. I feel like the damping on set of Stance coilovers is mediocre. Grip just doesn't seem to be there compared to some cars I've been in with similar tires but nice DA Konis, etc. It's also kind of skittery over bumps, and I'd really like to gain some more compliance for rough tracks, bombing over gator strips, etc.
So nobody is running an 86 series in the rear yet? What is the problem, no off the shelf dampers with the proper length? |
10-26-2007, 09:06 AM | #109 |
Tsk Tsk...I just have to finish welding up the S13/S14 rears. I have everything made to use either 8610 or 8611's back there. The downside is that you have to run a Z32 spindle since that's all i've made brackets for thus far. (I know I know...heaven forbid you drop 8 lbs in the rear)
Still needs to be have the sleeve flange welded on and powdercoated, but here's a pic. Shorter=S13 Longer=S14
10-26-2007, 09:19 AM | #110 |
Here's another picture of Fromxter's setup to help visualize what the insert looks like next to the stock shortened housing.
10-26-2007, 11:42 AM | #111 |
This is bad, the wheels are turning now and I'm tempted to do this next summer. If I sell my Stances I can recoup a decent amount of cash I imagine.
Since the 8610 are just SA, how is the compression on them? I'm assuming its going to be pretty good for the target range of spring rates we're talking about here, say 350-650? The extra $450 for the 8611s seems like a lot to pay since frankly, I'm not skilled enough at this point to intelligently adjust DA dampers. Anyone want to throw out a guess as to decent spring rates for a S14 running sticky street tires or longer lasting R comps with a front progress bar, stock rear, bolt in 4 pt roll bar, and no significant weight reduction (full interior, radio, etc.)? |
10-26-2007, 11:59 AM | #112 |
Autox Technician
450F 375R would probably be a good start if you street drive it a lot, as it's slightly stiffer than the 8/6 rates that come on most coilovers. Otherwise, with minimal street driving, the 600/450 I'm running now works well (not sure if they'll be as good with 8610's, though). In either case, I'd ditch the rear swaybar.
10-26-2007, 12:00 PM | #113 |
I ditched, at 390-440 whp
it helps on exit.
Like Me on FaceBook ! |
10-26-2007, 01:22 PM | #115 |
I already have Stance coilovers, not too thrilled with them at this point.
I've heard that ditching the rear sway is a good idea many times now- I've got to try that. Thanks for the advice on rates. I don't have a second car, but I walk to school so I only drive intermittently. Still, with Chicago streets being akin to the surface of the moon, I might be better off with lower rates than those ideal for a smooth track. If I change to this setup I'll probably get a few extra sets of springs to mess with too. Do the front and rear springs have different lengths with the 8610 setup? |
10-26-2007, 01:32 PM | #116 |
^^^ For the front springs, your going to use a 6-7" (length) spring. The rears you can get away with a 7-8" length spring, well I'm not sure if there is a difference between the S13 and S14 on that one... PJ can best answer the S14 one.
10-26-2007, 01:40 PM | #117 |
I think rear S14 dampers are longer, as seen in the pics of Veilside180SX's rear housings for the S13 and S14. No idea if that would affect spring length though. I'd love it if I could just run 7" springs all around, it would be much easier to experiment with rates that way.
10-26-2007, 01:51 PM | #118 |
It all depends on your price range. Ground Control can set you up with a decent koni/eibach kit, they even offer some custom valved koni's for certain applications.
I would not recommend buying their coil-over conversion kit if you plan on participating in any real type of motor sports. The coil over conversion kits are good if you simply want to have a lower car and slightly stiffer ride. Of course some cars do not respond as well lowering, especially if the hardware doesn't permit usage of the threaded sleeves Ground Control uses. If you haven't yet, give them a call and see what they can offer you. Tell them what application you will be using the car for and they will come up with a set-up for you. |
10-26-2007, 01:52 PM | #119 | |
The S14 housings might be longer, but I think the collar (for where the sleeve will sit) will be in the same location, in relation to the top of the housing. Richard would probably know best since he's building my set of rear housings also |
10-26-2007, 03:36 PM | #120 | |
Autox Technician
Yeah.... I haven't heard of many people having bad experiences with GC's on decent shocks, unless their complaint was they couldn't touch pavement with their frame rails. Or maybe I'm just lucky and my car pulls 1.2g's on cold tires by chance?
