09-25-2006, 07:20 AM | #61 |
i think mines real funny. sometimes when my passengers have to open the door, the autobelts onnly move to top of the pillar, and they usually close the door and the belt will squeeze them to the seat. its all a funny action watching it
my friends s14 always has soem problem, like thebrake lights will sometimes not work. the radio will have to be reset if it get a little hot. other general fun stuff
お金も腕も、何も無い・ |
09-25-2006, 07:40 AM | #62 |
if i switch the hvac to #4, my compressor shuts off, but the fans still blow.
Also, if i leave the ignition on without starting the car for a little while, when i pull the key out the EGI relay under the hood stays buzzing, and it will kill the batt. unless i start the car and shut it off again. 0_o |
09-25-2006, 07:52 AM | #63 | |
09-25-2006, 09:24 AM | #64 | ||
09-25-2006, 02:39 PM | #65 |
Another wierd issue I had when I bought the car... the temp gauge looked like a boost gauge. It would go up with the revs until it hit the actual temp, stay there until I shifted, and then drop to C and start over again. I used to tell people I wired that to be my boost gauge until I fixed it by replacing the coolant temp sensor (stock na ka... lol)
09-25-2006, 03:24 PM | #66 |
my s14 isn't too bad. my wipers don't work and my door open indicator goes off and on while all the doors are closed shut.
my 200sx is on its death bed. odometer stoped working, max rpm on my tach is 3k. it will climb then just hold at 3k or drop back down. before my stereo got stolen i had to bust a fonz (punds on the juke box) to get it going. ayeeeh! |
09-25-2006, 08:27 PM | #67 | |
09-25-2006, 08:33 PM | #68 | |
'bout $20 new, cheaper used. quick fix. had the problem in both my 240 and G20. |
09-30-2006, 09:38 PM | #69 |
I found out what my problem was.
It was a shorted out battery ground cable. And now I have a new problem. Now everytime I open the door the clock goes away and I get no interior light. Everytime I go to replace that 10a fuse it will blow right away. There's a short somewhere in that circuit. |
10-01-2006, 02:29 AM | #70 |
were to start...
when any doors are open the clock disappears, then reappears when they shut at 1:00. when the car shuts off clock is done, start it up back at 1:00... Sometimes random unreal times 1:96. Push in the dome light, open door light on the cluster turns on. Auto belts wont move unless key is in the ON position. Electric door locks randomly unlock themselves after a period of time. Sometimes the guage cluster lights wont turn on. GOOD TIMES! |
10-01-2006, 04:47 AM | #71 |
defrost and hazard button lights burnt out
slider LED for hot/cold on climate control burnt out sometimes one cluster light is half lit, then turns on all the way after awhile also, u s14 guys should try this, its the "nissan wink" basically turn your headlight switch on verrrry slowly, and only one light turns on, works also if they are on and u start to turn them off very slowly, one will go out. i only did this once to see if my car was like my buddies (he showed me the "wink") and then I got HIDs, so I didnt want to mess them up. also works in my friends j30... |
10-01-2006, 05:01 AM | #72 |
haha my shits a mess. all the wiring leading back to the ecu has some plugged in and some just laying around and just grounding themself. here's a couple things i noticed:
1. no horn 2. one speed windshield wiper that you have to bust a quick reaction time to have it turn off when its completely down 3. one of my dash lights would always be on but i took out the bulb so it duznt bug me. i forgot what light it was lol. 4. a lot of things could be wrong since the harness is a mess so if anyone has a wiring harness prewired for an s14 sr20det in a s14 chassis let me knooow. i'll post this again in wtb
10-01-2006, 05:17 PM | #73 |
S14: speedometer would go out and my tachometer would start working or my tachometer would go out and the speedometer would work. rarely both would work ok at the same time.
also my tach. likes to bounce all over the place then just quit and not work |
10-01-2006, 05:26 PM | #74 |
I bet I've had more nightmares than anyone on here.
The positive connection to my alternator rotted out about 2 years ago and since then I've had one problem after another. It took me 2 weeks to realize that the wire was bad because the rotted part was in a plastic sheath. When I felt the sheath I hit a soft spot and when I opened it up powdered rusty wire came out. Ugh... I replaced it with a wire sealed with heatwrap at both ends. Now, though, my car eats positive battery terminals. I go through 1 a year. I bought a new terminal this year that has an LED readout and it shows that the voltage is like 13.25v when the car is on, which I think is normal. But no matter what I do it gets this nasty powder all over the place and the insides of the terminals rot out. Also my heater completely stopped working shortly after this all happened. I replaced the fuse (the one under the passengers side dash that looks like a card that screws in). Now the knob on the dash works (when I set it to on the engine idles harder so there's some kind of signal going on there) but the fan never comes on. Lets see... that's about it.
MMM, Dido.... 1997 240SX SE S15 SR20DET |
10-01-2006, 05:50 PM | #75 | |
I think all 90's nissans have the same type of highbeam switch & all do that... |
10-01-2006, 06:29 PM | #76 | |
when i press the brakes my dash lights and parking lights light up when I put the headlights on my brake lights are always on. WTF |
10-03-2006, 06:50 PM | #77 |
my driverside window is testy, it rolls up and down when it wants to, you can hear the relay click and you can roll it up and down, and it will click again and stop. my favorite gremlin is that you can't start my car unless you click on the corner lights. I had a chick steal my keys once and try to take my car, i laughed and said fine, you win take it. 15 minutes later, she gave up, came back in and threw my keys at me and told me i suck.
10-03-2006, 07:06 PM | #78 | |
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power. Looking for: JDM S13 OEM Sideskirts |
10-03-2006, 11:57 PM | #79 |
(S13) One day my wipers stopped working, but the way it happened I was sure it was the motor that went bad. They slowly came to a jerking stop and nerver worked again. I checked the fuse and it was perfectly fine. Being lazy I decided not to fix it (used rain x in the meanwhile). Then one day I was driving in the rain and they suddenly came on but the switch was in the off position. While that was occuring I noticed that the Cuise light on my cluster was on (the switch for that was also off). Then every bump I would hit the cruise light and the ABS (antilock) light would alternate. While one was on the other was off and vice versa. When the cruise light was on the wipers would be going but then hitting a bump the ABS light would come on and the wipers would be dead again. This went on for about three days then everything stopped (wipers stopped working again and cruise light went off) but the ABS light stayed on constant now. I drove with it like that for about a month then yesterday I decided to check all my fuses in the car again. Now the wiper fuse was blown so I replaced that and the ABS actuator relay fuse was blown too so I replaced that. (remember these fuses were all good when the problems were going on) Started the car and the ABS light was no longer on and now my wipers work perfectly with the switch. Now that is some weired shit. Now my only problem is that the car is always fogging up. The vent (or recirculation) button on the climate control works perfectly lighting up when pressed on and going on when pressed again but I don't think it's actually opening the little door or whatever it does. This obiously just started as soon as the other problems were fixed. Just my luck
10-04-2006, 09:39 AM | #80 |
Heh, I had a similar situation with my wipers acting up. One time it was because I had my e-fan ghetto wired and unfused. The other time was because the clamps for my battery terminals where loose and corroded.
10-04-2006, 10:53 AM | #82 |
my gas gauge doesn't work untill i got less than a 1/4 left
my wipers are weird. sometimes work fine, sometimes the delay doesn't work at all. if i touch the green box - they'll go on for a single swipe - every time!! I already replaced it with another one that I had from a car that it was working fine. his is still working fine (with my box) and mine is still fubared thinking about painless wiring |
10-04-2006, 12:17 PM | #83 | |
10-04-2006, 12:21 PM | #84 |
Location: VA.. And for those that keep PMing me asking what kit I have, it's Origin Stream.
Something is shorting out in my fuse panel behind the kickpanel. Sometimes my dash lights don't come on (which also includes my tail lights) when I turn on the headlights. If I kick on the kick panel or push on the fuse panel behind it, they will flicker and come on.
Also, highbeams are ghey. Used to be the passenger one would work sometimes, sometimes not. Now neither high beam works most of the time, but sometimes the drivers will... GHEY!
10-04-2006, 06:40 PM | #85 |
My problems in my '95 are not too bad but are annoying as hell
-drivers side window only goes up when it wants -temp gauge acts crazy unless I am in 5th gear around 3-3.5k -airbag light came on all of a sudden and hasn't shut off since -usual gas gauge not reading correctly Thats about it I think (I hope) if anyone can help me out with any of these problems let me know |
10-04-2006, 06:53 PM | #86 |
Power door locks kinda work. Driver side doesnt open or close passenger side. However passenger side opens driver side, but doesnt lock it.
Also the electronics in my hatch dont work ;_; |
10-04-2006, 06:58 PM | #87 | |
10-04-2006, 09:31 PM | #88 | |
-temp gauge: take the connector off the intake temp sensor near the intake manifold (by the upper radiator hose to the block), clean off the contact point and put it back -airbag light: there is a reset procedure... I think 240sx.org has it? something about pushing the door sensor 7 times with the key on acc also point to note: on my '95 the airbag light was blinking from the day I bought it... got into an accident a few months ago, and they deployed as they should anyway... -gas gauge: the sender in ur tank is misaligned or broken... need to dive into there from the plate on the hump between the back seats and trunk |
11-11-2006, 01:47 AM | #89 | |
got more stuff.
pass auto belt works when it wants to. when i press the brake..it blows the fuse. sometimes car doesnt want to start. ill let it roll and pop the clutch once(but engine doesnt start) then turn the key and maybe ill get lucky and the car will start. sometimes ill just wait it out and the car will start whenever. any help?
