05-05-2005, 01:19 PM | #1 |
Idle at 1200rpm with TPS unhooked
Tried to check my timing last night... with the TPS unplugged my car idles very high.. around 1200rpm... and when i check the timing its at 30-35 since the idle is so high... I tried adjusting the idle control.. i turned it all the way clockwise till it stopped and it did pretty much nothing.....
just wondering if anybody else had this problem... and any suggestions on how to solve it..
Sfourteen |
05-05-2005, 01:21 PM | #2 |
if it's a dohc KA then set the timing at 20 btdc and use the idler screw to get the idle to around 650 plus or minus 50. If it won't, check for vacuum leaks and check your AIV.
CA18DET t25, 440CC injectors, Greddy FMIC, Greddy Hot Pipe, Greddy Type RS Bov ,Greddy Turbo Outlet, Trust DP, Motoria 3" Catback , XS Tubular Manifold, Nismo AFPR ,Nismo Engine and Transmission Mounts ,Apex'i SAFC 2 Walbro 255lph, LSD, SPL Subframe Collars, Tein S Tech Springs, Tein Tie Rods, Upper Front and Rear Strut Tower Braces. Black 180sx wheels. |
