Old 06-01-2020, 09:15 PM   #1
Rico387er
Rico387er is an unknown quantity at this point
S13 KA24DE Sounds like a vacuum cleaner
I swapped this KA24DE into my s13 that had a single cam in it. Sometimes when I drive it there's this crazy vacuum sounding noise, it is most likely a crazy vacuum leak. I have having the car running and spraying around the engine with carb cleaner to see if the idle would change but I haven't had any luck finding any leaks that way. Anyone have any other ideas? Or common places for huge vacuum leaks? The car never dies on me either, always pushing strong, well as strong as it can. Also, excuse the IACV hose. Ive been meaning to change that but i cannot find the right hose thatll fit it. I may just be dumb and this sound is normal but i doubt it. https://youtu.be/PiltpCJRTSI
Rico387er is offline   Reply With Quote
Old 06-01-2020, 10:24 PM   #2
coupesallday!
coupesallday!'s Avatar
Trader Rating: (18)
coupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the rough
Feedback Score: 18 reviews
Send a message via MSN to coupesallday!
Sounds like your clutch fan
Throw some glitter flake and crazy glue in there.
coupesallday! is offline   Reply With Quote
Old 06-02-2020, 04:41 AM   #3
S14rebuild
What intake do u have?
Old 06-02-2020, 03:41 PM   #4
Rico387er
It only sometimes make that sound and it goes away with higher rpms.
Old 06-02-2020, 03:42 PM   #5
Rico387er
Stock s13 intake, egr deleted.
Old 06-02-2020, 04:43 PM   #6
S14rebuild
Open the air filter box when it does it, see if the noise comen from there
Old 06-03-2020, 11:12 AM   #7
Kingtal0n
Kingtal0n's Avatar
If you think there is a leak, do a pressure test. same as a boost leak test. You dont need a turbo to do a pressure test.
Old 06-25-2020, 06:14 PM   #8
Thursday7
Thursday7's Avatar
Your video is coming up as private for me
