Old 08-01-2019, 08:40 AM   #1
JagdStealth
JagdStealth is an unknown quantity at this point
Send a message via AIM to JagdStealth
Restored 1972 240Z RB25
A handful of other pictures located here: https://imgur.com/a/ZTWmMCw
Fully restored and modified '72 240Z in excellent shape. I have owned the car for the past 10 years and have rebuilt it from the ground up including a down to metal professional paint job. The car is turn key and ready to go for anything. Too much to list and receipts for almost everything going back to the 1970s with the original owner including log book, manual, warranty info, etc. The engine is a freshened up Series 2 RB25DET with just over 400HP with all supporting modifications (fuel, turbo, coils, etc.) new and professionally installed and tuned on a dyno with a PowerFC. Even the check engine light is functional. To recreate this build today would cost $65,000+
Suspension is a complete custom coil-over setup with all new urethane bushings, oversize disc brakes, MSA sway bars and OS Giken LSD. The chassis was stiffened and setup by the late John Coffey at Beta Motorsports.
Interior is custom two tone black/brown with Recaro SRD seats and a properly installed rollbar with DOT/FIA approved 4pt harnesses for both driver and passenger. Dash is redone and contains custom Speedhut gauges in all factory positions.
Car is located in Southern California and listed at $35,000 or best offer
Aside from below, during the build most bolts, tabs, etc. were replaced with new stainless.
Suspension/Brakes/Chassis:
Adjustable coilovers with full camber adjustment welded in
Wilwood oversize 4 piston front disc brakes with upgraded master cylinder and brake bias
Silvermine Motors 2 piston rear disc brakes with e-brake
Steel braided brake lines
Panasport 16x7 wheels with Bridgestone Potenza RE71R tires
MSA sway bars and urethane bushings all around
Solid poly engine and transmission mounts
Chassis setup by the late John Coffey at Beta Motorsports (known for building Zs)
Drivetrain:
Series 2 RB25DET with approx. 40k miles (custom install welded into factory locations)
Nismo single disc clutch kit and pressure plate in RB25DET 5spd transmission
OS Giken 2-way clutch LSD in upgraded R200 long nose differential with new half shafts
740cc Nismo injectors w/ Bosch 044 fuel pump
Super Spark coil packs
Upgraded factory housing turbo
Apex'i PowerFC and Greddy Profec B controller dyno tuned up to 370RWHP, but run at lower boost (325RWHP)
New OEM MAF and Apex'i intake
HKS Blow off valve
Oversize radiator and front mounted intercooler
200ZR oil pan
Functional check engine light
3" exhaust front to back
New half shafts
Interior:
New interior including OEM kick plates, door panels, etc.
Original dash with a fitted cap
Recaro SRD seats with custom leather inserts (driver seat fully adjusts, passenger fixed due to roll bar)
4pt harnesses on both sides
Properly installed Kirk Engineering roll bar
Speedhut custom gauges in factory locations (GPS speedometer which measures 0-60, 1/4mi, etc)
Modern fuse panel
Nardi steering wheel
Rear 6x9" speakers with bluetooth
Roll on sound deadening throughout
USB charging for accessories
Upgraded interior fan blower motor
Exterior:
No rust, any repair replaced with new metal. No bondo anywhere.
Complete bare metal paint job in PPG Ferrari Blu Chiaro paint (80s 328 color)
Custom carbon fiber panels and rear 432 style spoiler
Upgraded H4 headlights
MSA urethane front air damn
Carbon fiber bumpers
New front and rear glass
New rubber seals all around
-Mike
JagdStealth is offline
Old 08-01-2019, 10:00 AM   #2
StoobyMcDooby
StoobyMcDooby is a jewel in the roughStoobyMcDooby is a jewel in the roughStoobyMcDooby is a jewel in the roughStoobyMcDooby is a jewel in the roughStoobyMcDooby is a jewel in the roughStoobyMcDooby is a jewel in the roughStoobyMcDooby is a jewel in the rough
amazing car! Well written ad, nice pics. GLWS!
StoobyMcDooby is offline
Old 08-02-2019, 04:00 PM   #3
JagdStealth
Thanks! It's been a great car to drive the past few years, but got some changes in life coming up so time to move on.
-Mike
Old 08-03-2019, 10:27 AM   #4
zakira
zakira is an unknown quantity at this point
Coolness man!
zakira is offline
Old 08-14-2019, 10:54 AM   #5
crysis
crysis has a spectacular aura aboutcrysis has a spectacular aura aboutcrysis has a spectacular aura aboutcrysis has a spectacular aura aboutcrysis has a spectacular aura aboutcrysis has a spectacular aura about
wish I wasn't a peasant
GLWS
Plan Bait
Hack Outdoors
crysis is offline
Old 08-16-2019, 09:27 AM   #6
ZzZleeper
ZzZleeper is an unknown quantity at this point
Man, you have alot more than 35k into this build.. Beautiful car! Good luck with it, im sure i'll sell quick.
ZzZleeper is offline
Old 08-16-2019, 10:49 AM   #7
JagdStealth
Yes, much much more...but that's all part of it when you build something for yourself. Someone will get to enjoy a great car!
-Mike
Old 10-08-2019, 06:17 PM   #8
JagdStealth
Car is sold!
-Mike
Old 11-11-2019, 07:22 PM   #9
dmragecm
dmragecm's Avatar
dmragecm is a glorious beacon of lightdmragecm is a glorious beacon of lightdmragecm is a glorious beacon of lightdmragecm is a glorious beacon of lightdmragecm is a glorious beacon of lightdmragecm is a glorious beacon of lightdmragecm is a glorious beacon of lightdmragecm is a glorious beacon of lightdmragecm is a glorious beacon of lightdmragecm is a glorious beacon of lightdmragecm is a glorious beacon of light
Originally Posted by JagdStealth View Post
Car is sold!
if you don't mind me asking, how much did it sell for??
dmragecm is offline
Old 11-13-2019, 11:25 AM   #10
chentes14
chentes14 is an unknown quantity at this point
I want to know too, I have the same car same motor swap.
chentes14 is offline
Old 11-14-2019, 06:29 AM   #11
Edgar
Edgar's Avatar
Edgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfection
Send a message via AIM to Edgar
nice ride bump
Drift Indy
Edgar is offline
