S13 Rear End Clunk. Help!
Hi everyone,
I know this is a common problem, but I have searched every single forum with no answer. I am experiencing a clunk/thud/noise coming from what I think is my rear end every time torque is sent back there. This could be from throttle blips, or releasing the clutch. This problem started happening after I did a rear end rebuild I guess you could say. I started with a completely stock S13 and the car made zero noises. I did energy poly bushing kit which replaces everything in the rear including the sub frame bushings, and I put in a J30 vlsd. The car clunked. I also hated that the diff put stress on my driveshaft so I swapped the vlsd into my open diff pumpkin. The car still clunked. So I took the diff to a shop thinking it was a backlash issue, it wasn't, they said it looked fine. Like I said, the car was stock and made zero noise before doing all of this. So it can't be the tranny, cant be the driveshaft, cant be the axles. I even have gone through and checked it with the diff out. The driveshaft has barely any play when in gear and makes a normal tranny noise when shook and there is no play in the axles. I'm dumb founded. My only guess is I got a crappy J30 diff from the scrap yard? What else could it be? |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() Feedback Score: 5 reviews
Put rubber bushings back in if you don't want to hear the clunk.
If had 3 s13s, all three made zero sound until I i added different bushings. One had poly, the other 2 had solids. It just fucking clunks.
![]() Join Date: Jan 2010
I can almost guarantee you that it's your axles, either that or your subframe is cracked. I had this same problem and chased it for almost a year before I just sourced some good condition used OEM ones. See thread on my struggles:
http://zilvia.net/f/showthread.php?t=593642
#5 | |
#6 |
I have the same clunk I think. When releasing clutch or giving quick throttle. Just swapped my diff and we will see this weekend if that was it. My second guess is subframe bushings. I know I have ES polys in the rear but they are almost 10years old. I have solids in hand and will be dropping my subframe next to install those. Hopefully its one of those.
#10 | |
In my research the closest thing to OEM bushings would be Megan Racing Poly bushings. Only because they have gaps and are shaped just like OEM. https://www.enjukuracing.com/product...-15-bnr32.html |
#11 |
ITS LISA'S FAULT!!!
![]() Join Date: Jun 2003
Trader Rating: (41)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 41 reviews
factory s13 rear diff doesnt have bushings... did you use the J30 housing and swap covers?
im guessing youre running the factory USDM s13 drive shaft? if so... might be time to change out that stupid hockey puck bushing as those tend to wear our (and will shred) rather quickly when you start abusing them given their age. its located at the front of your drive shaft after the first u-joint directly out of the tranny. i would HIGHLY recommend you find yourself a stock JDM S13 drive shaft as it only uses u-joints instead of u-joint to bushing to shaft. |
#12 | |
#13 | |
#15 |
240sx, clunk, diff, differential, j30 |
