Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Suspension
Old 02-12-2018, 12:57 PM   #1
Thmotorsports
Trader Rating: (28)
Thmotorsports is just really niceThmotorsports is just really niceThmotorsports is just really niceThmotorsports is just really niceThmotorsports is just really niceThmotorsports is just really niceThmotorsports is just really niceThmotorsports is just really nice
Feedback Score: 28 reviews
Scratch/dent HKS HIPERMAX IV GT S15/S14 $900 shipped
Fedex was a jerk and decided to dropkick some coilovers off their truck and damaged them... SO WE'VE GOT A DEAL FOR YOU! 900 shipped. All sales final, no returns.
The new Max IV sporty suspension. Awesome sporty drive with great control and comfortable ride in the street.
It's perfect for daily street drive with style and performance. You and your passenger can have a comfortable ride even with a low-down.
*Single Tube Damper Design*
Mono tube dampers allow for more accurate and stable control and adjustment of dampening. Lower ride height and centre of gravity gives a more stable ride.
*Dust Boot*
Protect the shaft from the flying stones.
*PNE Coating*
Using this special surface coating provides 5 times better durability over standard galvanising. This prevents build-up around the threads of the adjustment areas allowing for easier height adjustment.
*"M Shaft"*
With the new design of cylinder shaft since the HIPERMAX M-1, MAX IV increased the cylinder shaft size to have a firm damping even at a little stroke range because of the optimized oil pressure characteristic. We mainly adopted this to the rear damper that can have a better driving experience.
*New Design Needle*
Newly designed needle has been used to revise the very low speed and middle and high speed dampening which is key to a comfort ride.
*Reduction of Unsprung Weight*
In order to reduce unsprung weight, bracket, ride height adjusters and lock nuts are made from aluminium. (Not for all vehicles)
*30 Step Damping Force Adjustment*
30 levels of dampening adjustment allow fine tune adjustment for street or circuit.
Damping Force (Front): 211m/sec (Rebound) & 137m/sec (Compression)
Damping Force (Rear): 839m/sec (Rebound) & 382m/sec (Compression)
Front Upper Mount: Rubber
Lowering (Front): -47mm (From 0 to -81mm)
Lowering (Rear): -45mm (From 0 to -80mm)
Rear Upper Mount: Rubber
Spring Length (Front): 220mm(Barrel)
Spring Length (Rear): 250mm
Spring Rate (Front): 59N/mm (6kgf/mm)
Spring Rate (Rear): 49N/mm (5kgf/mm)
Thmotorsports is offline   Reply With Quote
Old 02-12-2018, 01:00 PM   #2
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
jesus, you need to resize those pix
jumpman2334 is offline   Reply With Quote
Old 02-12-2018, 02:19 PM   #3
Kviper52
Kviper52's Avatar
Kviper52 is an unknown quantity at this point
so all in all still functional though?
Kviper52 is offline   Reply With Quote
Old 02-12-2018, 02:43 PM   #4
Thmotorsports
Trader Rating: (28)
Yes, they still work.
Old 02-12-2018, 03:33 PM   #5
jedi03
looks like a dailyd set of coilovers...great deal!
Old 02-13-2018, 02:37 AM   #6
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
What a shame. I hope you guys had good insurance on those coils!
Old 02-20-2018, 11:18 AM   #7
Thmotorsports
Trader Rating: (28)
Even with the damage, this is a great deal, surely somebody wants to jump on this.
Old 03-06-2024, 04:22 AM   #8
ThraxNof
ThraxNof is a well-known jackass
Send a message via AIM to ThraxNof Send a message via Yahoo to ThraxNof
Could you provide more details about the deal, especially considering the mentioned damage to the coils?
ThraxNof is offline   Reply With Quote
