Old 01-14-2018, 06:19 PM   #1
Adam88
Adam88 is an unknown quantity at this point
Send a message via ICQ to Adam88 Send a message via AIM to Adam88 Send a message via Yahoo to Adam88
s14 1998 240sx sr20det 400hp
Project kouki Fully built SR20DET +400hp on 91 Octane .
Price $12k
Trade must be 2014+
ENGINE:
Zenki S14 black top SR20DET
Carrillo H-beam rods
CP 87mm Pistons
ARP Head studs
ARP Main bolts
ACL race bearings
1.5mm Tomei Head gasket
1mm Oversized valves
Tomei 270 camshaft
Supertech dual valve springs
Circuit sports rocker arm stopper
Tomei Oil pan
Garrett GTX 3076R Twin Scroll
Full Race Twin Scroll manifold
Full Race Downpipe
Biltz 3" Nuerspec exhaust
Greddy Intake manifold
Greddy top feed fuel rail
ID 1000CC injectors
Tomei N15 70mm Throttle body
Tial Wastegate
ATI Crank dampener
Synapse BOV
Walbro 255 intake pump
Wiring Specialties Pro Engine Tranny Harness
Nismo Thermostat
Circuit sports FPR
Tomei coil cover and oil cap
GodSpeed Radiator with Nismo cap
GodSpeed Intercooler
Mishimoto oil cooler
Mishimoto dual Electric fans with custom switch panel + OEM clutch fan
ChaseBays coolant overflow tank
Real Street performance-10 Billet Baffled Catch Can
Odyssey Dry cell battery installed in the trunk
ENGINE MANAGEMENT:
AEM EMS w/ map sensor
AEM Failsafe AFR with Boost Gauge
MAC Boost Solenoid
TRANSMISSION:
2006 Nissan 350Z CD009 transmission W/ custom bellhousing
Transmission adapter plate
Spec Clutch Mini Twin Disc
ChaseBays clutch line
Solid transmission mount
One-piece aluminum driveshaft
Kaaz 2way LSD
Greddy Diff cover
SUSPENSION:
326 power D1 spec Coilovers
Megan racing- Front and Rear control arms
Megan Rear lower toe arms
Megan Rear upper control arm
Megan Rear traction arms
Megan steering bushing kit
Megan Front and Rear sway bars
SPL S14 outer tie rods
Z33 inner tie rods
Spare Megan outer and inner tie rods
Rebuild power steering rack
ISR Stainless Steel Power Steering Rack Lines
ChaseBays Power steering system kit
Nismo power brace
Greddy front and rear strut tower braces
SPL solid subframe bushings
SPL Solid Diff bushings
Solid engine mounts
BRAKES:
R33 front and rear
R33 master cylinder
P2M master cylinder heat shield
Project mu D1 spec rear shoes
Front and Rear Stainless-steel brake lines
ChaseBays brake lines relocation kit
INTERIOR:
2 Bride Vios Low Max seats
2 Bride seat rails
2 G-force 6-point harness+ OEM seat belts
Cusco Safety 21 6-point bolt in roll cage
Sparco R215 suede steering wheel
NRG Hub and Quick release
NRG 3 pieces cooling panel
Speedhut water temp and fuel level gauges
Custom A/C trim gauge pod
Uncracked dashboard
EXTERIOR:
2 set 5zigen 5-FN01R-C (17X9 +15 with federal tires)
2 set 5zigen 5-FN01R-C (17X10 +12 with federal tires)
HID Headlights
Front JDM bumper
Rear JDM bumper
Rear JDM valances
JDM wing
**Salvage CA title
**Both front and rear OEM bumpers will be included
**Deleted A/C. Deleted heater. Deleted sound deadening and rear seat. Cracked windshield.
**Stock body with some dents, dings and oxidized paint.
Adam88 is offline
240sx, drift, nissan, sr20
