Old 08-17-2017, 05:20 PM   #1
Drftwrkz89
Drftwrkz89 is an unknown quantity at this point
SR SR20det ID 850cc injectors
Hey guys I have a set of new Injector Dynamic 850cc injectors I need to sell. I decided on getting a different fuel rail for my set-up which require different injectors. 3 of the 4 injectors are still in the plastic, I took one out to measure and test fit. They do include the clips and pins also. I'm looking to get $400obo. thanks for checking them out.
Here are the Injector Specs:
Nominal Flow Rate 885cc/min @ 3.0 Bar (43.5 psi) Using Gasoline at 52 Degrees C (125 Degrees F)
Maximum Differential Fuel Pressure - 7.0 Bar (101.5 psi)
Fuel Compatibility - Compatible With All Known Fuels
Electrical Connector - USCAR
ID850 , for SR20DET RWD applications. Top feed only. 11mm (blue) adapter tops. Denso / 14mm lower o-ring. Set of 4.
Drftwrkz89 is offline   Reply With Quote
850cc, injector dynamics, injectors, sr20, sr20det
