Old 08-03-2016, 05:24 PM   #1
culaphid
culaphid is an unknown quantity at this point
Thumbs up Ls1/T56 Swapped 1986 Rx7 Fc
For sale is my 1986 rx7 fc for $5950 or best offer. This car was just built and has less than 100 miles on the freshly rebuilt motor. The motor and transmission are out of a 2000 F-Body, which has just over 75k on it to begin with, so the transmission has low miles. The car runs and drives great with no vibrations or funny noises. On to the specs.
1986 Rx7 Base Model, crank windows, hardtop.
Turbo II 5 lug conversion
Turbo II front 4 piston brake calipers
Turbo II Brake master
Turbo II clutch type LSD differential
Aftermarket steering wheel
Tanabe lowering springs with koni shocks
Battery re-located to rear properly
Mounted fire extinguisher
Whalbro 255LPH fuel pump
Corvette fuel pressure regulator
Wilwood clutch master cylinder with braided lines and remote bleeder
2000 5.7L Ls1 engine
Just Rebuilt including:
New main and rod bearings
New Melling oil pump
New piston rings
New valve stem seals
New head gasket
New gaskets everywhere
New water pump
2000 t56 transmission with no grinds, pop outs, or funny noises of any kind
Ronin speed works transmission and engine mounts
Custom harness done by Ronin
Ecu flash and tune by Ronin
Aluminum driveshaft
Monte Carlo radiator
Two stage fan controlled through ecu (never overheats)
Custom throttle cable and bracket
Oil catch can
Very nice custom dual exhaust settup, 2.5" from manifolds back to the x pipe, 3" dual from the x pipe to 2 magniflow glass packs, not the quietest settup but sounds amazing.
Autometer oil pressure guage
Autometer water temp guage
Autometer speedometer (working)
Factory tachometer and fuel guage working properly
I'm sure there's more I'm forgetting.
This car runs amazing and has a TON of power in a very light chassis. This car was built with the track in mind, so I don't have a title on the car. However, I will provide a bill of sale and I do have a bill of sale from the previous owner, as well as a California license plate for the car. The car does have some rust, nothing super crazy, I took pictures of everything I've seen on it. In my mind, this would be perfect to finish as a track car, or to re-shell your clean blown up fc. Of course it you were on a budget, you could register this chassis and have a fun and very fast street car. Pm, call, or text me with any questions.
Phone: 6618587027
Faq:
Q: Will you ship the car out of state?
A: Yes, you arrange shipping.
Q: Is it "BARD"?
A: No.
Q: Most other questions
A: Please read the add, it should answer most of your questions.
culaphid is offline   Reply With Quote
Old 08-04-2016, 01:59 PM   #2
culaphid
Bump for a price drop. We all know this is a steal!
Old 08-05-2016, 09:01 PM   #3
culaphid
Sold please lock
fc3s, fd3s, ls1, rx7, swap
