Old 10-23-2013, 09:12 AM   #1
joe_nismo
joe_nismo is an unknown quantity at this point
93 240sx from Shell to Silvia SR20 GT3076r
Purchased the shell when I lived in TN back in 2008. Delayed for budget constraints, Iraq Deployment, etc. Looking good now.
93 240sx from shell to Silvia SR20 GT3076r - Imgur
Redtop sr20det
XTD 13lb Flywheel CarbonKevlar clutch
Garret GT3076r
3inch downpipe, test pipe, cat back, and knockoff N1 muffler
JGY Fuel Rail and 72lb Injectors
Walbro 255 fuel pump
JWT ECU
FMIC
Short shifter
Alum Radiator
One Piece Driveshaft
r200vlsd
17X8 Wheels
1 inch rear wheel spacers
Wide front and rear fenders
Full body kit
KYB AGX Struts w/ H&R springs
Evo leather Recaro seats on bride rails, modified of course
5 point camlok seat harness'
I might be missing some things, but I think that's it.
Shooting for 450whp....may be high but we shall see soon.
JWT ECU comes in today, will test it out and see how it all goes. Check the imgur gallery for details of the build process.
Thanks for all those who posted to this forum and other forums. I used forums and google as my technical assistant the entire way.
joe_nismo is offline   Reply With Quote
Old 10-23-2013, 12:54 PM   #2
joe_nismo
Thanks for the move! I was looking for this type of thread...general...chat...build. Learning the forum structure the hard way
Old 10-23-2013, 12:59 PM   #3
Big Zee
Big Zee's Avatar
Big Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choices
looks good, why did you opt to stay bottom mount vs top mount with that turbo ?
how is it for response ?, or is it power at the top ?
Two-Tone owner#011509-Lightly Modded
Old 10-23-2013, 01:14 PM   #4
joe_nismo
I opted for bottom mount for cost mostly...and because I had yet to find anyone who kept the factory manifold. Maybe a reason for that. I'll find out tonight when I fire her up for the first time since the upgrade. JWT ecu comes in today!! I'll let you know the response and such. Also my friend who provided the vlsd's has a dyno, so i hope to get initial numbers running it at 15psi.(wastegate is set at 15, once I'm comfortable, I'll throw a controller on there and take it up)
Old 10-24-2013, 06:00 AM   #5
joe_nismo
Test last night was a no go... Fuel pressure regulator was leaking fuel from where the flange meets the rail....Not quite sure why. I sent an email to JGY to ask if they have seen this issue using the factory fpr on their rails... I might go for some Permashield and dress the flange.
Old 10-28-2013, 07:28 AM   #6
joe_nismo
New an improved O-ring for that regulator fixed the fuel leak. She fired up and test drove. Took a little while for it to stop stalling, guessing the ecu was learning the atmospheric bov again. It did this when I first did the swap for about a day.
Only issue I am having is exceeding my clutch.... I didn't realize the stage 2 I had in there was rated so low (250hp). I'm shopping for a 6puck now. The clutch slips around 13psi in all gears. Even so, the car still feels great, pulls hard and if I half throttle it I can get a 2nd gear pull. I'll update when I get a better clutch in there.
Old 10-31-2013, 10:12 AM   #7
joe_nismo
Spec Stage 3 ordered. Rated for 515tq. Going to attempt an install over the weekend. While I'm at it, hopefully install my vlsd and one piece driveshaft.
Old 11-06-2013, 08:46 AM   #8
joe_nismo
Spec installed and broke in! Pulling hard and no clutch slipping!!!!!! I hit 5psi at 3100rpm and full boost (15psi) by 3800rpm. This turbo is pretty sweet! Although, I've never ran a 2871 so I cant really compare with my 3076.
240 240sx, 400 hp, gt3076r, s13, silvia conversion
