Old 12-18-2012, 02:05 AM   #1
roushman90
roushman90's Avatar
roushman90 is an unknown quantity at this point
CA My S13 FS Thread: (KA/SR/OEM&Aftermarket)
All parts are off the car and ready to be picked up. Willing to ship some items, but buyer covers costs. Prices are pretty firm, pick up available in Bay Area, CA. I am open to trades, check down below for my wanted parts list.
Contact:
510-566-5296
[email protected] (Paypal e-mail)
KA Parts:
KA SOHC/DOHC starter $40
KA DOHC EGR components ASK
SR/KA OEM Nissan injector "O" rings BRAND NEW $15
KA DOHC header $10
SOHC KA injectors $5 each
DOHC KA injectors $5 each
S13 Alternator fuse $5 each
S13 Relays $5 each
S13 KA lower trans harness (Auto converted to Manual) $40
S-13 Suspension & Steering:
S13 OEM USDM rear sway bar $10
S13 OEM RUCA (2) $10
S-13 Interior/Exterior parts:
Rear S13 OEM seatbelts $10
Passenger side manual window assembly w/ window $20
S13 fastback interior pieces ASK
Rear speaker brackets and covers $25
Weather stripping (all) ASK
S13 OEM tail lights, all cracked $5 each
Climate Control $40
Interior quarter window paneling $20
Center console $20
Gauge bezel $20
Exterior trim $10 each
Manual door panel, passenger side, black $20
Window cranks $5 each
Fuel hard lines front to back $50
Brake hard lines front to back $40
S13 gas pedal $25
SR parts:
Isis polished Intake Manifold (Used) $160/trade
Sr20det OEM IACV $40
SR OEM Intake Manifold (Bare, no iacv/tps) $20
SR OEM Throttle Body Pending
Random SR hotpipe, polished aluminum $20
PARTS I WILL CONSIDER TRADES FOR:
550cc sti yellow injectors
SAFC
Coolant reservoir
Boost, Oil temperature, water temperature, Oil pressure gauge
Boost controller
Tires/Rims, 15", 16", 16", 18"
Wideband
Zilvia part out by roushman90,
Clean S13 sun visors, gray SOLD
Engine Harness $100 SOLD
OEM S13 E-brake cables, still locked my rear up fine, not stretched out, never over tightened SOLD
OEM S13 e-brake assembly $10 SOLD
S14 seat belts(PAIR) $50 SOLD
Kazama inner AND outer tie rod setup $200 SOLD
Tein S13 super drift coilovers in good condition, no leaks. $1200OBO SOLD
Chassis Harness $100 SOLD
Plated weld R200 S13 diff $100 SOLD
Muteki tuner nuts w/ key $25 SOLD
Test pipe $20 SOLD
Rear subframe $80 SOLD
OEM traction rods $15 SOLD
OEM toe rods $15 SOLD
Shifter trim $15 SOLD
Hatch with glass $40 SOLD
BN Style pop up front bumper $100obo SOLD
Buddy Club super low rail, s13, driver side $125 SOLD
Walbro 255 fuel pump in S13 pump assembly $60 SOLD
Passenger seat $20 SOLD
N60 maf $40 SOLD
Buddy Club Spec II, tip was scraped, not perfect $200 SOLD
SR 370cc injectors $100 SOLD
S13 stock driver seat $10 SOLD
VIS carbon fiber vented S13 hood $25 SOLD
KA trans, rebuilt WITH receipts from this last year $200 SOLD
Axles $40/each both for $60 SOLD
Aftermarket RUCAs $40 SOLD
NRG short hub $40 SOLD
OEM cat (passed smog) $50 SOLD
Gauge cluster $30 SOLD
Manual brake pedal $20 SOLD
AutoMeter boost gauge $40 SOLD
KA24DE motor & clutch/flywheel stage 1 SOLD
B&M KA/SR short shifter $150 SOLD
KA DC sport header $125 SOLD
Rear bumper $20 SOLD
Pignose front bumper, silver, $25 SOLD
Glovebox $10 SOLD
SOHC dark gray "tweed" carpet $50 SOLD
Clutch Pedal $25 SOLD
Clutch master $10 SOLD
SS clutch line & slave $30 SOLD
Rear Overfenders $100 SOLD
S13 rear strut bar $25 SOLD
Front strut bar $25 SOLD
Rear c-pillar bar $25 SOLD
Trans crossmember $10 SOLD
Battery relocation wire with pos terminal $10 SOLD
Heater core, works, $20 PENDING
OEM ka intake $10 SOLD
White bunny KA clutch/flywheel setup $125 SOLD
Eibach Sportline springs on KYB GR-2 setup SOLD
roushman90 is offline   Reply With Quote
Old 12-18-2012, 02:22 AM   #2
shinnkv
shinnkv is an unknown quantity at this point
Do you have privacy cover or moon roof cover?
shinnkv is offline   Reply With Quote
Old 12-18-2012, 02:50 AM   #3
roushman90
roushman90's Avatar
No sir, no privacy cover and no moon roof cover as this was a non-sunroof model. Thanks for the inquiry!
Old 12-18-2012, 10:56 AM   #4
NorCal420sxDrifter
NorCal420sxDrifter is an unknown quantity at this point
How many miles on kade after rebuild? Might be intrested in engine and harness. Engine runs good no leaks, good compression?
NorCal420sxDrifter is offline   Reply With Quote
Old 12-18-2012, 11:23 AM   #5
roushman90
roushman90's Avatar
Honestly not sure how many miles, got the motor out of his car when he just went SR. I've driven a ton of KAs and this one is the strongest one I've ever came upon. No leaks besides valve cover, bring a compression tester as I don't have one to test but it was running when pulled, and I have video of it getting down last month like an SR and the last event I drifted. This motor is a local legend HAHA.
Old 12-18-2012, 11:26 AM   #6
NorCal420sxDrifter
Sounds good man....how long did u run it? U goin sr too?
Old 12-18-2012, 12:24 PM   #7
roushman90
roushman90's Avatar
Finally put the last nail in the coffin for this shell, moving on to new chassis new motor. I literally had it in my car like two months. Ran it with header, stock intake, and Walbro 255 and man it got DOWN.
Old 12-18-2012, 12:33 PM   #8
NorCal420sxDrifter
Cool man i think i want it.....where u located? Would there be alot of shit to do since im only single cam right now? Wireharness and ecu is all i can think of...oh and ps lines i heard are bigger.
Old 12-18-2012, 01:11 PM   #9
roushman90
roushman90's Avatar
I never had to deal with SOHC>DOHC swap, but here is a link:
Ka24E (SOHC) to Ka24DE (DOHC) F.A.Q.~ - Nissan 240SX Forums
I'm located in Hayward, and I'm sure I'd have everything you need to rock it out, motor is only missing distributor, clutch fan, p/s pump.
I think in addition to the motor, you would also need:
DOHC engine harness
DOHC coil
DOHC tach, throttle cable
DOHC maf
Old 12-18-2012, 01:25 PM   #10
NorCal420sxDrifter
Cool thanks for the link....well i gotta wait til friday when i get paid so if u havent sold it i will definity come take a look...most likely will buy. Thanks
Old 12-18-2012, 01:38 PM   #11
Gamma
Gamma is an unknown quantity at this point
yo load pix of manual door panels interested
Gamma is offline   Reply With Quote
Old 12-18-2012, 01:46 PM   #12
88Coupe
88Coupe's Avatar
88Coupe is an unknown quantity at this point
Still have the coils? Pm me if you do.
88Coupe is offline   Reply With Quote
Old 12-18-2012, 01:53 PM   #13
roushman90
roushman90's Avatar
For sure, this motor will not disappoint! It tandem'd with Matt Field, Ryan Bell, Calvin Wan and tons of others, never failed to keep me on their door!
Getting pics hopefully this afternoon, they are pretty clean. I think driver side has a little bit of small crack on top from sun, not sure though.
Still available, sending PM.
Also, general note, please don't ask me to hold parts UNLESS you paypal me the full price! I don't have time for flakes!
Old 12-18-2012, 02:13 PM   #14
ShadowDrifter
Trader Rating: (55)
ShadowDrifter is an unknown quantity at this point
Feedback Score: 55 reviews
(510)-566-5296 Text for more info, pics, etc.[/QUOTE]
No asking text for pics ect please read the rules
Drifters Do It Sideways
ShadowDrifter is offline   Reply With Quote
Old 12-18-2012, 09:45 PM   #15
roushman90
roushman90's Avatar
No asking text for pics ect please read the rules[/QUOTE]
Happy now? Pictures added.
Old 12-18-2012, 10:56 PM   #16
Lvnismo
Lvnismo's Avatar
Lvnismo is an unknown quantity at this point
still got the tranny?
Lvnismo is offline   Reply With Quote
Old 12-18-2012, 11:09 PM   #17
roushman90
roushman90's Avatar
Pending sale
Old 12-18-2012, 11:22 PM   #18
Dr.Nismo
Dr.Nismo's Avatar
Dr.Nismo is an unknown quantity at this point
still got the complete engine trans ecu what price r u looking for?
Dr.Nismo is offline   Reply With Quote
Old 12-18-2012, 11:34 PM   #19
roushman90
roushman90's Avatar
KA24DE motor, EGR delete, rebuilt,mild port&polished, unneccesary butterfly shit on back of motor deleted, with all accessories except p/s & dizzy. Comes with Stage 1 Exedy clutch kit, good life left $500
KA trans, rebuilt WITH receipts from this last year $200 PENDING
Auto s13 ECU $40
$740. Transmission is pending sale, complete motor and ECU still up for grabs.
Old 12-18-2012, 11:43 PM   #20
flatout
flatout's Avatar
flatout is an unknown quantity at this point
How old is that shifter it looks like its in good shape
Sent from my Galaxy Nexus using Tapatalk 2
flatout is offline   Reply With Quote
Old 12-19-2012, 12:03 AM   #21
1jzjoey
1jzjoey's Avatar
1jzjoey is an unknown quantity at this point
i need center vent for dash and also defroster vents, got them?
Originally Posted by 180 drifter View Post
2700 for a non running crashed up car. sounds like a steal.
1jzjoey is offline   Reply With Quote
Old 12-19-2012, 06:06 AM   #22
Zeppelinrok75
Zeppelinrok75 is an unknown quantity at this point
How much for the light assembly that goes over the rear license plate shipped to 22901 if you still have it?
Zeppelinrok75 is offline   Reply With Quote
Old 12-19-2012, 10:21 AM   #23
roushman90
roushman90's Avatar
Used probably 5k miles, but kept it in good condition.
I believe so, but what do you mean by defroster vents?
$15, but I'd have to get a shipping quote
Old 12-19-2012, 10:35 AM   #24
ersus
ersus's Avatar
ersus is an unknown quantity at this point
Send a message via MSN to ersus
How much for the shifter trim shipped to DORAL, FLORIDA 33126
ersus is offline   Reply With Quote
Old 12-19-2012, 11:50 AM   #25
roushman90
roushman90's Avatar
Sold msglngthhhh
Old 12-19-2012, 12:34 PM   #26
Wanabe
Wanabe's Avatar
Wanabe is an unknown quantity at this point
Hey it's Palmer are you going to winter jam? I might want that walbro.
Wanabe is offline   Reply With Quote
Old 12-19-2012, 12:38 PM   #27
roushman90
roushman90's Avatar
What's up man! I don't think I'm going to Winter Jam, but I could possibly try to get someone that's going to deliver it! LOL
Old 12-19-2012, 01:40 PM   #28
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
bump up top for fellow local driver
legit seller can vouch
Old 12-19-2012, 03:32 PM   #29
retrograde.
retrograde. is an unknown quantity at this point
Mileage on engine? Any cons?
retrograde. is offline   Reply With Quote
Old 12-19-2012, 03:45 PM   #30
Bambi
Bambi's Avatar
Bambi is an unknown quantity at this point
still have the nismo pipe?
How difficult is to get good at drifting?
Originally Posted by Frank_Jaeger View Post
It's impossible because I tried once. Took out 4 telephone polls and a girl scout concession stand. All the thin mints and samoas couldn't even be salvaged.
Bambi is offline   Reply With Quote
buddy club, coilovers, coils, part out, s13
