Old 03-03-2012, 03:22 PM   #1
nismojunkball
nismojunkball's Avatar
nismojunkball is an unknown quantity at this point
s14 HELP. Lost positive terminal! Where does this wire go!?
97 240sx se s13 blacktop
Ive searched and searched. i have a wiring specialties s13 blacktop into s14 harness. On the last instruction it states.
"Step 8 (Battery terminal)
Connect the Battery terminal to the positive side of the battery
and connect the two fuse box power feed wires into the red
terminal connector."
Would i be able to run a single 6 gague wire from the + to the far right connection on the fuse box?
I made this stupid drawing on paint. Any input helps. Sorry for such a newb question. I just want to make sure this is correct cuz i dont want to FSU.
Thanks a ton
nismojunkball is offline   Reply With Quote
Old 03-03-2012, 10:42 PM   #2
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
Fsm on nico. Maybe the alternator?
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
Old 03-04-2012, 01:14 AM   #3
mantas
mantas's Avatar
mantas is an unknown quantity at this point
If you are talking about the black/yellow on my car that is the alternator wire and its connected directly to the fuse box terminal, an the terminal connects to the battery. But i would not guess or else your could end up with a much bigger problem. As far as size is concerned i think 6 gauge is fine.
mantas is offline   Reply With Quote
Old 06-17-2018, 01:29 PM   #4
skywalkingsilvia
skywalkingsilvia's Avatar
skywalkingsilvia is an unknown quantity at this point
I'm running into this same issue with my 1998 240 to red top sr20. What in the world connects to the positive terminal on the wiring specialties conversion harness?
The older I get, nicer is more important than faster.
skywalkingsilvia is offline   Reply With Quote
Old 06-18-2018, 08:24 AM   #5
blkvrtswp
blkvrtswp's Avatar
blkvrtswp is an unknown quantity at this point
The answer is: Call in and speak to Wiring Specialties Tech Support. 860-799-6579 press 2
Also check the Install Guides here: https://www.wiringspecialties.com/in...-instructions/
blkvrtswp is offline   Reply With Quote
fuse block, fuse box, positive, terminal, wiring specialties
