Old 07-22-2009, 12:32 PM   #1
neukin
neukin's Avatar
neukin is just really niceneukin is just really niceneukin is just really niceneukin is just really niceneukin is just really niceneukin is just really niceneukin is just really niceneukin is just really nice
Send a message via AIM to neukin
Thumbs up Race S13 Partout S14 ka Kaaz Megan vmount neukin manifold downpipe aluminum exhaust
Everything has about 1k miles on it... like NEW.
Need this car gone, buy now for $2800, top her off and get drifting 2010 style!
Chassis
Neukin Tig Welded Roll cage chassis with ARP studs and 5lug new rotors and hwak pads 1.75 DOM tube .120 THE SAFEST out there
Custom cut gussets on drivers side tie cage into chassis for a ridged setup.
-Padding for impact safety and if you drive on street with no helmet
Muteki blk open wheel lugs and key
Walbro 255 intake fuel pump
hood with louver for vmount
Key for both doors, not used for start tho.. just switches for start
lock bolt in wheel is illegal for TTU race
classClear title and steetable
Odyssey PC680 battery (11 pounds!)
6 switch bank (used right now: fuel pump, fan 1, fan 2)
Two main switch near cluster (ign, and start)
Was a automatic so the chassis was setup and 5speed setup installed with correct pedals ect so you cant really tell but thought id toss that outthere.
THE LACK OF RUST IS GREAT, was not fixed.. it really has no major rust on chassis or frame rails.Has some small dents and such, i was never worried about looks since its a racecar. Would be easy to clean her up and put a kit or paint on.New slave and master for the clutch, new hardline and stainless flex line.
stock springs and shocks
-Megan Front Roll Center Adjuster ball joints $100 (after you lower car these help flatten the lower control arms so Nissan designed suspension goes closer to intended geometry)
-Megan front steering S13 Rack Ends add more steering angle
-Megan Tie Rod End
-Megan Front Pillow Tension Rods
-Megan Rear Lower Toe Arms
-Megan Rear Lower Traction Rods
-Megan Rear Upper Control Arms
Russell stainless brake lines
Neukin welded diff in pumpkin with blasted cover and black painted bolts
Steel one piece drive shaft was like $200 removes rotational weight and sends power to rear wheels for a clean snappy feel.
ready for s13 obd2 96 higher power S14 motor/ecu/trans has the ecu you can put Nistune on for a fully programable chip which id highly recommend to get this car to the next stage
Custom Wire harness from Nissan Wire Specialist and low miles clutch from center force Brand new alternator Neukin stainless Oil feed and stainless oil drain for turbo lube and cool system
Had the Neukin vmount setup, but its not turbo now, just a stock radiator and cold air intake, has metal bracket and hood for vmount. 3" exhaust for turbo.
-Stock hood lightened and louvered perfect for the intercooler core.
-Sparco hood pins/latch system from Italy
3" stainless exhaust system Neukin Mid Pipe Vband inlet and outlet with clamps
or
3" aluminum race exhaust downpipe back with custom mounts and hangers saves 20lbs and sounds good
NRG short hub, quick release wheel 2.5 and "Race" leather wheel w red stitch
One set of SportMax 17x8 with pretty much brand new fuzion zRi for daily or running to a event brand new (great in the rear for drifting)
4) 10mm aluminum wheel spacers on the 4 corners for better wheel spacing.
S14 cluster and two of the needed three plugs $80
Neukin Motor Development llc 399 River Bend CT Fort Wayne IN 46803
-->Neukin Store<-- -->DRIFT Clutch Store<--
neukin is offline   Reply With Quote
Old 07-22-2009, 03:44 PM   #2
Gorilla Unit 33
Gorilla Unit 33 is an unknown quantity at this point
Pics of Neukin power steering relocation? i cant see it on that pic
Gorilla Unit 33 is offline   Reply With Quote
Old 07-23-2009, 12:21 PM   #3
neukin
neukin's Avatar
ummm here are a few at two angles the bottom one is the kit you would get.
Old 07-23-2009, 12:50 PM   #4
spartanmisfit
spartanmisfit's Avatar
Trader Rating: (18)
spartanmisfit is an unknown quantity at this point
Feedback Score: 18 reviews
that shit's nice man
bizump!!!!
spartanmisfit is offline   Reply With Quote
Old 07-23-2009, 07:31 PM   #5
nics fairlady
nics fairlady's Avatar
nics fairlady is an unknown quantity at this point
how much are you asking for the motor? and how much would shipping to 95834 be?
nics fairlady is offline   Reply With Quote
Old 07-23-2009, 08:04 PM   #6
the.rise
the.rise is an unknown quantity at this point
would you do 70 shipped on the maf to 01923?
the.rise is offline   Reply With Quote
Old 07-24-2009, 08:39 AM   #7
chris300zr
chris300zr is on the path to ruinchris300zr is on the path to ruin
neukin intercooler kit require any cutting? looks like you cut the rad support out on that hatch? very interested but not looking to get rid of my support.
chris300zr is offline   Reply With Quote
Old 07-24-2009, 09:06 AM   #8
neukin
neukin's Avatar
Ya the hood latch support needs cut, its well worth it. You can always get another one and put it back to stock later. Its a few spot rivits and you can get that section of meny junk s13ers. Id just do it.. for super sexy vmount action you must get nasty with a cut off wheel.
Just the motor, um not sure like $450, it has topfeed injectors and rail on it for easy tuning and injector choices. Rail has a gauge on it too. Runs great vac, no smoke adn it runs and starts like a F-ing champ. That way i can sell the trans for $400 with the newish centerforce clutch. Im sure shipping would be about $130 to massachusetts on pallet.
Few things sold and i didnt update list.
Old 07-30-2009, 12:06 PM   #9
neukin
neukin's Avatar
coilovers pending for sale fri/sat.... we will see.
still have the kaaz 2WAY!!! shoot a price 700 installed in there ready to rock with low miles and 3 fluid changes already with kaaz fluid. best condition used kaaz evvva
Old 08-06-2009, 07:03 PM   #10
haggard240
haggard240's Avatar
haggard240 is an unknown quantity at this point
coils are amazing going to the track sunday to really test them out!! oh and they were UBER CLEAN!!
haggard240 is offline   Reply With Quote
Old 08-10-2009, 04:00 PM   #11
neukin
neukin's Avatar
Thanks, coilovers sold. Need this KAAZ sold, someone pick this up its a deal!! 2 way super low use and fresh fluid. Installed in pumpkin already. 700 plus ship
Old 08-10-2009, 09:44 PM   #12
240_fun
240_fun's Avatar
240_fun is an unknown quantity at this point
toe and traction arms to 08534?
240_fun is offline   Reply With Quote
Old 08-11-2009, 01:49 AM   #13
aoiken3
aoiken3's Avatar
aoiken3 is an unknown quantity at this point
do u still have the odyssey battery? and if so, how much shipped to 93901?
pm me plz
おれのシルビア大好きだよ!!!
aoiken3 is offline   Reply With Quote
Old 08-11-2009, 05:26 AM   #14
slow92
slow92's Avatar
slow92 is an unknown quantity at this point
I know this is an old thread but do you still have the rucas??
Sr22 in the works
slow92 is offline   Reply With Quote
Old 08-11-2009, 10:40 AM   #15
g-via
g-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of lightg-via is a glorious beacon of light
this isn't an old thread, there has been discussion in it recently
How much for the steering wheel setup shipped?
"I'm a rage-aholic, I just can't live with rage-ahol!!!"
g-via is offline   Reply With Quote
Old 09-09-2009, 04:15 PM   #16
neukin
neukin's Avatar
Have this KAAZ out and ready to sell with final drive gear on it still all locktight'd n tq to spec ready to drop in....
(Can do Close to $700 shipped for most 48state guys west coast add $15) 2-WAY two way... very low use, two kaaz gear oil changes already three if you count the shit gear break in fluid it first had for break in. lmk need this gone!
Old 01-07-2010, 08:08 AM   #17
neukin
neukin's Avatar
Still have this car but not turbo/vmounted and no coilover, welded diff no kaaz want $2800 for it now
Old 01-07-2010, 01:26 PM   #18
a-s-silvia
a-s-silvia's Avatar
a-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymore
Send a message via AIM to a-s-silvia
Ps lower pump bracket if you still havehow much shipped to 81007 co 719-250-4468
[SIGPIC][/SIGPIC]
a-s-silvia is offline   Reply With Quote
Old 01-07-2010, 01:35 PM   #19
skyvia686
skyvia686's Avatar
skyvia686 is an unknown quantity at this point
that roll cage welded in? or just bolted lmk im interested
skyvia686 is offline   Reply With Quote
Old 01-10-2010, 04:22 PM   #20
matt11145
matt11145 is an unknown quantity at this point
is the one piece drive shaft for an S14? please PM me, thank you.
matt11145 is offline   Reply With Quote
Old 01-28-2010, 05:33 AM   #21
projekt_s13
projekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfection
Send a message via AIM to projekt_s13
How much for just the quick release?
projekt_s13 is offline   Reply With Quote
Old 01-28-2010, 05:36 PM   #22
monaS14.5
monaS14.5's Avatar
monaS14.5 is an unknown quantity at this point
did you sell tha kaaz LSD?
monaS14.5 is offline   Reply With Quote
Old 01-28-2010, 05:48 PM   #23
Black240Ct
Black240Ct will become famous soon enoughBlack240Ct will become famous soon enoughBlack240Ct will become famous soon enough
Send a message via AIM to Black240Ct
how much for the drive shaft shipped to 06050
and is it for abs or no abs?
Black240Ct is offline   Reply With Quote
Old 02-01-2010, 12:00 PM   #24
clv5045
clv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymore
how much for the fuel pump shipped to 07421?
91 240 cpe w/ sr SOLD
96 240 w/ sr
clv5045 is offline   Reply With Quote
coilovers, kaaz, neukin, s13, s14
