08-13-2007, 03:17 PM | #1 |
running a q45 ignitor? help me out
according to the sr20 fsm, the pins on the input side of the ignitor are supposed to have continuity with the ground (5th pin). now all the q45 ignitors i have found (there was 5-6 at my local junkyard), as well as a z32 unit all do not have this continuity, but they pass all the other sr20 tests. can someone with a known working q45 ignitor and a multimeter just check this for me real quick?
08-14-2007, 04:04 PM | #2 |
anyone? after doing a lot of things all at once (swap, rebuild, topmount setup + pfc) i have no spark and i really really dont want it to be my power fc that i got on ebay
08-14-2007, 07:27 PM | #3 |
im using a q45 ignitor mine works, i used the pinout from http://srownersclub.com/faq/faq_ignitor.asp
08-15-2007, 08:38 AM | #4 |
it could also be the multimeter you are using. I have a good one and when I try to check continuity on my ignitors they dont show (atleast the continuity function which give your the little beep), but when I check the ohm reading in between the prongs it shows up at around .8 ohms, and i know that this ignitor is good.
This is my clever and witty signature. |
08-15-2007, 03:01 PM | #5 | |
my multimeter's continuity function reads ohms, and they were all ~1 across the board, but from the ground pin on the input side to the other pins on the input side, its like 750. the proper SR20DET ignitor is supposed to have continuity there.... i got to test a known working one from my old car and its open as well. so my ignitor is good for sure. what else besides ignitor, coils (tested) and a wiring problem (100% confident my wiring is correct) will cause no spark? im going to test coil output voltage from the pfc as soon as i have a hand to crank it... |
