08-21-2010, 06:41 PM | #2581 |
not too hard, its a few bolts that mount the headunit to the double din bracket, slide it in and ur done
street dancer. GLEAM |
08-21-2010, 06:43 PM | #2582 |
does anyone know if the light in the ash tray for s13's can be unplugged? i want to change it with a brighter one, LED, but i cant get it to come off
08-22-2010, 12:23 PM | #2583 |
Ok so I'm driving home on the freeway and I notice a sound from my fan. I keep driving and my car is getting hotter. Before I had a chance to pull off my car dies and I coast to a parking lot. My coolant was boiling so I left it there for a few hours. I was only about a mile from home so I figured I can drive it home. When I go to start it it doesn't pop only two sputters and I cranked it maybe 5 times. Any ideas? I would have searched but for some reason it's not working.
08-22-2010, 01:48 PM | #2585 |
Trader Rating: (38)
Feedback Score: 38 reviews
Does anybody know the brand that sells antennas that are like mini sharkfin antennas for S13's but they're just little stubs...
I believe the brand name starts with a "F" I've been searching google but I'm finding stubby antennas that are 3", the antenna I'm looking for is like an inch (possibly?) they kind of look like this: |
08-22-2010, 01:49 PM | #2586 | |
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap. |
08-22-2010, 02:16 PM | #2587 |
Why can i not clear the code for IAT sensor w/ an obdII scan tool on my 97? other codes will clear though this will not.
I assume there must be an issue in wiring harness, the loop is not closed hence the issue. please correct me if not.
@UpshiftEngineering |
08-23-2010, 09:04 AM | #2591 |
S13 SR20 Blacktop:
What size and thread pitch is the PVC valve that threads into the valve cover? I am looking to buy an aluminum plug to eliminate the PVC valve and want to know what size I need.
Daily driven |
08-23-2010, 09:10 AM | #2592 |
Trader Rating: (22)
Feedback Score: 22 reviews
I know this sounds retarded but I tried to google it to find any answers but have no luck. Is there any fan setups with a push and pull running at the same time? Effective? Or counter effective? Links? Thank you.
Driftphreak87 |
08-23-2010, 12:55 PM | #2594 | |
08-23-2010, 12:57 PM | #2595 |
pro's - easier to work with shit in the front (almost nothing)
cons - car will overheat eventually - you will need an electric fan - you have to remember to turn fan on - fan wont be as effective
08-23-2010, 01:02 PM | #2596 | |
I prefer the clutch fan. The extra working space and minimal power gains are negligible compared to the extra hassle. |
08-23-2010, 01:12 PM | #2597 | |
Trader Rating: (38)
I got a better picture for you guys, found this on google, it linked me to a '09 zilvia fs thread, that isn't the antenna but it definitely looks like that stub above the hatch wing... |
08-23-2010, 01:30 PM | #2598 |
uh isnt that a wiper fluid sprayer for the rear window wiper that comes on hatches?
S.P.P.S. Member #00 **CoUpe LOve** Member #00 |
08-23-2010, 03:37 PM | #2601 |
I have a pair of silvia dual projector headlights, the mounting bracket on them are broken, Anyone have an alternative way on mounting them on the headlights brackets? Pics? links?
Any help and advice will be appreciated, thanks.
91 S13 Ka-t |
08-23-2010, 06:56 PM | #2603 |
So I am a somewhat of a suspension noob, however I am attempting to learn. I want to do the 5 lug swap on the S13, I found a z32 I can get the hubs and whatever else I need from it.
I know from the rear all I need is the hubs and of course the brakes and rotors. But as far as the front go Im confused as to what they are talking about when they say the "upright". What is this part? And what else from the front suspension of the z32 will I need to complete the 5 lug swap? |
08-23-2010, 07:01 PM | #2604 |
Trader Rating: (26)
Feedback Score: 26 reviews
Z32 front hubs do not work on any S-chassis. You have to run either ;
s14 5lug hubs along with the spindle and lower control arm (correct me if im wrong). After-market 5lug hubs Some infinity 5lug front hubs with modification. |
08-23-2010, 07:15 PM | #2605 |
08-23-2010, 07:45 PM | #2606 | |
How hard is it to press in the S14 ball joint into S13 LCA? |
08-23-2010, 09:51 PM | #2608 | |
i have been without a fan of either kind all summer in alabama (hot as shit) and it only overheats when it idles for like 20 minutes. nismo thermostat btw.
08-23-2010, 11:12 PM | #2609 | |
roof racks won't, some offer trunk racks. they won't work because the design is made so it has arms that put pressure on the bottom of the trunk, or something near that, and has these clips that are straps that connect to the top and tighten. Hatches don't have a gap between the glass and the lid so you cant latch the clips.
it most likely will, cause there wont be anything cooling the motor.
08-23-2010, 11:18 PM | #2610 |
has anyone tried this kit. GP Zero Body Kit | 3DR | S13 [AFB002,ASS002,ARB002] - $399.00 : Chaser Aerodynamics, LLC.
im curious on the fitment. its it good?
