#2493 |
#2494 |
I have a 90 s13 coupe with factory pop ups hatch front. Can I do the TRA Kyoto (rocket bunny) widebody front for the hatch and the widebody rear for the coupe? Anyones thoughts on how it would look because the front would have bubble overs and the back is a whole pannel. Thanks!
#2496 |
#2497 |
who rebarells wheels? got vs-xx 18x9 (2) , and 18x10 (2) all plus 30 offset with small lips. I want to have maximum lip and lower offset while staying the same width. how am i able to achieve that goal?
JS4HATERS |
#2499 |
![]() Ok, I'm really sorry if this has been answered before, but I tried searching within and out of this forum and still couldn't find a solid answer.
I have a '91 240 with a red top SR20DET swapped in. Runs kind of crappy... When I start it up, it idles just fine, but after it warm up, or when I put it in neutral when about to stop it idles REALLY low. Pretty much almost stalling out (and has stalled before once or twice). THEN... It has some slight hesitation when revving up. Almost like a "burp". And lastly, and quite possibly THE MOST ANNOYING THING EVER... Is when I launch, the car takes off relatively nice, but then breaks up in the higher RPMs. Starts at about 3-4k RPM. What gives?? Is it a fuel issue?? This is the biggest issue that I'm concerned with. Cause that crackle or breakup just doesn't sound good at all. (I take my foot off immediately when it does that... which doesn't leave too much throttle to play with). *sigh* Thanks! |
#2500 | |
#2501 |
^ You need some fuel adjustments, you got a motor at a particularly high or low sea level and your current altitude is vice versa. Your running too lean or too rich. That is all
#2502 |
![]() Cool! thanks for the tips! I'm glad that I at least have a starting point. lol
Now I just need to get some cash. *sigh* But as for dyno availability/ air-fuel diagnostics, I have no access to. I might have to invest in a wideband. Oh and I guess last Q... What are the best cheap parts out there to help my fuel issue? Money is tight... as always. haha I mean, if someone wants to fund my project, I have some 96-98 Civic EK Seibon carbon fiber fenders. lol Brand spankin new, never opened! I'll trade for some parts! haha |
#2503 |
![]() Join Date: May 2009
![]() Feedback Score: 19 reviews
ok i have 3 small question
![]() ![]() !st what is this? 2nd how does it affect my sr 3rd how can i fix it? could this be the main reason i get shitty mpg? btw im getting 10 to the gallon. wtf
My Daily Driver |
#2504 | |
#2505 | |||||
one way is to keep the SR AC pump and have an AC place splice the KA lines and recharge the system. best way is to keep your AC system but in order to do so you'll need a modified AC bracket. Codyace makes one, PM him. Quote:
depends on the mileage, abuse, etc, etc you got coolant in your oil or oil in your coolant? blowby hose Quote:
#2506 |
the headgasket has been done almost 10 months ago and i was getting coolant in the oil. bout 5-6 months later i was getting oil in the coolant. car never has over heated, and before i bought her she driven close to never. oh and i baby her like crazy..
#2509 |
![]() Join Date: Sep 2008
ok so ive just finished building my KA24E it was bored alittle bit to fit the new pistons. My question is what type of plug should i use ? i looked on all data for 3 diff plug numbers for hot, normal, and cold.. Some one told me cold plugs are the best to use for after market turbo cars. also im running 370 cc injectors. Thanks !
1994 toyota supra...... n-a D= 1992 nissan 240sx KA24E-T fully Built =D |
#2510 | |
improper surface prepping prior to new HG warped head cracked block... I would advice swapping in a different KA, maybe going DOHC |
#2511 |
Question - I have a KA-t and i think my thermostat is going bad, why?
The upper radiator hose is getting hot while the engine is warm and the lower radiator hoes is cold, Thermostat correct? I'll appreicate any advice given...
91 S13 Ka-t ![]() |
#2512 |
Can someone post a pic of what an a/t pilot bearing looks like from a dual cam ka? I am doing a 5 speed swap and just want to know what to remove so I don't damage my crank. Thanks in advance.
#2513 | |
![]() Join Date: Jul 2007
![]() Feedback Score: 8 reviews
![]() one of these. you are obviously only going to see the outside edge of it while its still in the engine. do you know what you are doing to get it out? PM me if you have any questions, i did the swap like a year ago. |
#2514 |
Mano negra
ive tried shoving the blowby hose back in but keeps comming off. is there sopose to be a gasket there or something.
My Daily Driver |
#2516 |
![]() Join Date: Oct 2008
Trader Rating: (31)
![]() Feedback Score: 31 reviews
question: anybody know of anyone that rebuilds rack and pinions in so cal LA area?
ive searched but keep getting out of town people. thanks. i will continue searching.... |
#2518 | |
![]() Join Date: Nov 2006
Trader Rating: (56)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 56 reviews
Your best bet now would be to thread the hole and put a AN fitting in it.
