04-08-2020, 03:48 PM | #23131 | |
Another thing if you're not building any boost at all is that the actuator arm may have popped off the flap. It's held on with a tiny c-clip that can rust off. |
04-08-2020, 08:44 PM | #23132 |
There should be a check valve somewhere in the line between the engine manifold and the brake booster. The check valve is intended to hold enough vacuum for at least one power assisted brake application in case the engine dies while the vehicle is moving.
04-09-2020, 06:09 AM | #23133 | |
Thanks you so much anyway for reply !! |
04-09-2020, 06:10 AM | #23134 | |
I will check the actuator arm too. damn dem rust lol |
04-11-2020, 02:33 PM | #23135 |
What type of grease is this being used for the plastic gears? Trying to add some more of it to my intake door actuator so I can prevent the gears from going bad on this one.
Instagram: Nismo_Lk |
04-13-2020, 07:34 AM | #23136 |
CD009 Collins 2jz
Hello, I am swapping a 2jzgtevvti into an s13, using a collins adapter plate and a ACT clutch. I read somewhere (and cannot find that source again) that the input shaft needed to be cut 1/4 of an inch in order to not bottom out on the crank. After beveling a small amount off the input shaft and attempting to mate the engine and trans, the bellhousing is roughly 1/2 inch away from being flush with the engine. My concern is if I cut more off the input shaft, I could cut too small and if I dont cut more and tighten it up with the bellhousing bolts, it could mess up my crank.
Any suggestions or input? |
04-13-2020, 08:43 PM | #23137 |
Small Questions Thread (SEARCH FIRST! Use this instead of making NEW threads)
Hey guys I?ve been doing some searching on power steering fluid. I?ve got an S13 with a 2JZ in it and recently had my rack rebuilt by a local shop. They told me that I can?t run ATF in the rack or it would ruin the seals. Based on everything else I?ve found the 2JZ and OEM S13 rack used ATF. Opinions?
Right now it?s basically got a Mix of ATF and PS fluid because the remaining ATF wasn?t flushed. Pump is quiet and rack feels great. Wondering if I should flush and fill with either one?
04-13-2020, 11:03 PM | #23139 |
04-13-2020, 11:04 PM | #23140 | |
They said power steering fluid Sent from my iPhone using Tapatalk Pro
04-15-2020, 08:31 PM | #23141 | |
You could use honda compatable PS fluid if you want to try to follow their dumb advice, it's supposedly vaguely better than the "brown stuff". It's fun to fill everything with tractor fluid, with wimps watching. Last edited by mechanicalmoron; 04-15-2020 at 10:25 PM.. |
04-17-2020, 02:28 PM | #23143 |
Thanks guys I?m going to flush and fill with ATF this weekend. I did start to hear a faint whine from the pump that has me worried
04-19-2020, 04:46 PM | #23144 |
Anyone know how I can get these pads unstuck? The piston is compressed down. Ebrake is off...
Sent from my iPhone using Tapatalk |
04-19-2020, 05:42 PM | #23146 | |
Sounds like a seized caliper. Replace it Sent from my iPhone using Tapatalk Pro
04-20-2020, 09:24 PM | #23147 | |
Get the pads out, remove the piston, then you'll be able to see what you need to do to get it back in. you can have the brake off, but it's not, you need to turn the rear pistons. |
04-21-2020, 08:52 AM | #23148 |
Bought a manual transmission, fluid is leaking out of this hole on the rear passenger side. Can anyone help me identify what its for / what i should plug into it? Can't find anything about it in the FSM.
https://imgur.com/a/0w7fc4K FOUND IT: It was a speed sensor! Last edited by Das_Haifisch; 04-21-2020 at 10:19 AM.. |
04-21-2020, 01:33 PM | #23149 |
So just to be clear, the piston is rotational and not just a straight up push out? I figured wedging something in between the caliper and piston and just pushing it back into place.
04-21-2020, 05:02 PM | #23150 |
need help on search of rear subframe parts
so i've decided to take my rear out of my 96 240 and change the oem bushing to polyurethane. In my journey of removing them i ended up cutting the last sleeve where the bushing sits on. i completely removed it and is in no use anymore. the reason i wanted to switch the bushing was due to wear and i dont want to go solid. i looked through here and on google and found nothing on the part i need. the sleeves that were cut out were the ones that sit furthest from the dif NOT the ones that hold the dif. can someone guide me to where i can get these sleeves ? because the bushing slip right in and that is a problem. Thanks in advance
04-21-2020, 09:56 PM | #23152 | |
In normal braking, it doesn't rotate, I believe it's so the parking brake can self adjust. You can probably turn or otherwise manipulate it from the other side, if you can't get the pads out, I totally forget how it's assembled. But if the caliper worked until that happened, it should be just fine, get seals if you feel the need and make sure to not score the bore or piston. A loaded caliper is easy, but unless you take absolutely all day to fix it, it's probably not economical, and reman quality is often absolutely not what you want on your car, you're better off taking your original part that hasen't been fuckered by everyone and their dog, and fixing it right, if it's possible. Reman means it got broken, used to the point that it no longer could be (at least once), someone who hated the car and part hacked it off, someone who hated the part and the buyer threw seals at it and hit it with krylon's cheapest offering, and someone who hates you and your car sold it to you, and will try to make it sound like it's your fault when their garbage is garbage. |
04-21-2020, 09:58 PM | #23153 |
Hey everyone. I?m new, so hopefully this is the right thread.
Currently going over wheel fitment. Will 18x9.5 +25 / 18x10.5 +18 fit? Guessing I?ll need a spacer in the front. 97? 240 with kouki front. I have bbk, extended studs and coil overs aswell |
04-22-2020, 10:26 AM | #23154 | |
Trader Rating: (130)
Feedback Score: 130 reviews
yes. this shit will fit, DEPENDING ON TIRE SIZE AND ALIGNMENT AND HOW MUCH FENDER WORK YOU DO. plenty of people have run these sizes OR more aggressive sizes, but if you throw a 295 in front, it aint gonna fit. If you have 0* camber and unrolled/unpulled fenders, it aint gonna fit. depending on what wheels and the spoke design, a +25 might not clear your calipers. there are a fuckload of variables here to consider. |
04-22-2020, 12:15 PM | #23155 |
I have the bushings that I need, but what I don?t have is the sleeve that sits inside the actual rear because I used a sawzaw and cut it out completely. Basically that metal lip that sits inside the rear I cut it out by mistake and I need that for the actual bushing to sit snug/tight because at the moment the new bushings sit with ALOT of play. I don?t know where I can buy the metal sleeve so if someone can direct me to where i can buy them it would be helpful.
04-22-2020, 12:25 PM | #23156 | |
Thanks for the rundown. Went at it last night with some pliers and everything?s good now [emoji106] Sent from my iPhone using Tapatalk |
04-22-2020, 12:56 PM | #23157 | |
then get another one and don't cut out the sleeve. |
04-22-2020, 04:50 PM | #23158 | |
I don't know how the s14 diff bushing is mounted, but most suspension bushings don't have a tube that the bushing goes into, just the sleeve that is actually part of the bushing. Get a rubber bushing, it will come in the proper metal sleeve, and install it right, as long as you didn't remove any metal that was welded to the frame. Presses are nice for gently installing the new parts, especially bearings and delicate stuff, but in removal, a ten pound hammer beats a 20 ton press, there's no reason to cut anything. *edit* and when you go to install it, anti-seize on BOTH surfaces, fully covering them (it will squeeze it off and entirely remove it such that it doesn't help if you only get one surface, in interference fits), find a short piece of pipe (or a socket that's not very special) that fits that sleeve (you can also use the old part or a piece of it, if enough is left, as an installation driver) such that it doesn't put pressure on the rubber and rip it, and get to hammering, it'll slip right in. Last edited by mechanicalmoron; 04-24-2020 at 10:56 PM.. |
04-26-2020, 09:20 AM | #23160 |
I am looking for push-mount cable tie holders that would snap into a 5mm hole. The S14s use these mounts all over the place to hold the harnesses. Looking on amazon and around the web I havent been able to find ones for 5mm specifically and have found various products for 6mm+ holes.
Does anyone with experience have anything they used that fit the 5mm holes for cable tie holders?
Skurr Skurr |
