06-18-2010, 12:23 PM | #1951 |
to sirfallsalot243
Yeah i guess you are right man, i've inspected all the suspension parts and stuff and surprisingly everything is ok, not the best but ok... well for the miles it has, the previous and first owner was in his late 60's when i bought the car of him which was about 6 months ago so i know he didnt where out parts by trying to drift or stuff like that. As for the engine, hardcore maintenance has been done to it, but not completely been taking apart or anything like that, but all the "outside" stuff is pretty legit, im surprised it pushes pretty strong for the miles it has, i wonder how long it'll last me lol but thanks man i'll do as u said baby it till a swap is ready. Thanks! |
06-18-2010, 12:30 PM | #1952 | |
One of my favorite mods ive done is a Circuit Sports V2 short shifter... got it for $80 and it makes the car so much more pleasurable to drive. Plus it works on KA and SR, so you can keep it when you swap (if you go SR). |
06-18-2010, 01:33 PM | #1955 | |
06-18-2010, 09:15 PM | #1956 |
okay got a questions for you guys..okay bought some wheels..the wheels didnt come with hub centric rings...was wondering how would i find out the info on the inner rim bored sized..i know nissan used a 66.2 hub centric but need the find out the rim centric size..if you guys know what i mean..fyi the rims are call ruff racing r280..lmk if you guys have any idea..and no lost contact with the seller...so cant go there..
06-19-2010, 06:57 AM | #1957 |
I never rub hub rings cause they are retarded accept in certain situations. If you live near a Discount Tire they should have a ton of different hub rings in stock and ask um for some. it would be easy for them to just test and see if some fit. Most likely like 73.something mm's like most aftermarket wheels turn out to be.
06-19-2010, 09:22 AM | #1958 | ||
06-19-2010, 10:48 AM | #1959 |
STOCK blacktop s13 SR w/ bolt-ons, new garbage bb t28 bolted on w/ 13-14psi wastegate, will i put holes in my pistons if i hit full boost?
IG - @24deee |
06-19-2010, 01:37 PM | #1961 |
2 quick ones.
- if I stick to my stock shocks/struts and get lowering springs is 17x8 (around 20-25 offst) w/ 235/45 tires a good size all around w/o pulling fenders? S14 I just wanna get rid of wheel gap, have a healthy drop, and sit flush. - what should I use to repair my cracked SE lip. any tutorials? |
06-20-2010, 03:52 PM | #1962 |
Trader Rating: (22)
Feedback Score: 22 reviews
Quick question, I read that when you're swapping an auto to a 5-speed (in my case, my 1996 S14) you need to match the manual ECU year with the car year? Is this correct?
i.e. Since I have a 1996 S14, I need a 1996 5-Speed ECU? I already bought all the parts I need, which most came from a 1997 S14. I was wondering if the 1997 5-Speed ECU will work fine with my 1996? Thanks guys!
06-21-2010, 03:10 AM | #1963 | |
Just learned something new Sent from my iPhone using Tapatalk
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap. |
06-21-2010, 03:26 AM | #1964 |
i forgot the owners name on youtube, what is it again? this is my dream right here
JS4HATERS |
06-21-2010, 08:34 AM | #1965 | |
not giving a fuck
Trader Rating: (104)
Feedback Score: 104 reviews
last i checked 96-98 are interchangable...so you should be find there...im never sure with 95 ecu...so let someone else answer that part...
LOL 240... whats better than 1? 5 1's ...lol PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r |
06-21-2010, 01:22 PM | #1966 |
ok guys so my passenger door has been stuck shut for like 2 weeks on my 97 kouki. is seems that the metal "coat hanger" part has come loose from the lock end of it. now if i could get the door panel off i could just fix it up but i cant get it off w/ door shut!! ive tried a bunch of things w/ no luck gertting it unlocked.....any ideas would be appreciated.
can i get the a/c vent/trim off w/ door shut? it doesnt seem so...
@UpshiftEngineering |
06-21-2010, 03:00 PM | #1967 |
Okay, I've done some searching and I've got some conflicting information. I got a 93 240 with a sr20det redtop. I want a/c. Now I've got the compressors from the sr20 and the original motor. I've got the a/c braket from a sr20. I know custom lines have to be made, but what is there to do as far as mounting everything up? Do I have to have the KA lines switched over to the sr20 compressor for it to work? I just need a little info and any would be much appreciated. Thanks in advance.
06-21-2010, 04:40 PM | #1969 |
Someone was selling stock radiator overflow tanks for like 45$ a while ago. does anyone know who that was because i want one?
JFAB "BIGGEST GUNS WEST OF THE MISSISSIPPI" |
06-21-2010, 05:18 PM | #1972 |
i think the place is called g-tech or something like that out of australia. i ordered one from them. im gonna see if i can find the box.
06-21-2010, 07:46 PM | #1973 |
Is my J30 diff going out? I've been getting stuck going up/down driveways beause when it 3 wheels, The diff will power the wheel that's in the air and the one that's on the ground does nothing.
Also, it doesn't lock in 1st gear. I can drift 2nd/3rd gear all day, but if I try to do anything in 1st gear, it's a 1 tire fire.... |
06-22-2010, 04:58 PM | #1974 |
I have a s13. I want to put some lowering springs on it and drop it about 2.25 inches all around. Will all the stock linkages be able to adjust the alignment back to factory specs?(about 0 degrees of camber and 0 degrees of toe in back is what I am most concerned about.)
06-22-2010, 11:47 PM | #1976 |
does anyone know anywhere that sells the gt1 kit for s13 silvia (S13 "coupe")?
RHDJAPAN had it last month but they took it off, so I am looking for somewhere else that sells it |
06-23-2010, 06:27 AM | #1979 | |
