02-22-2008, 11:06 AM | #151 |
I agree that the 3071R .63 will spool faster and make more power than the 2871R .86. I think the .86 housing is just restrictive. Ive always been curious of the GT2871R w/ .63 T3 housing. Might give the same top end power of the .86 with the spool that it lacks.
370cc can max out with only 10psi pending on the setup. When i dynoed my stock block w/ 2871R .86, Greddy IM, and HKS 264 Step 1 Cams, I was doing 315whp @ 14-15psi. INeedNewTires, i believe you can hit your 400hp goal if you get a new Intake Manifold and some kind of Tubular Manifold. I like my Ichiba Vers II Manifold. Same design as the Tomei but half the price.
1995 Nissan 240sx *RB25DET* |
02-22-2008, 11:07 AM | #152 |
377 HP and 320 ft/lbs of torque at 18 psi s14 SR V-mounted IC/rad w/ dual FAL fans larger s13 throttle body stock intake and exhaust manifolds stock bottom end w/ no head work done GT2871r .64 BC 264 in/exh cams BC spring and titanium retainers z32 maf Apex'i PFC L-Jetro exedy stage 2 fidanza flywheel Deatschwerks 600c injectors CS flat DP/elbow Apex GT Spec with JDM 3" gutted cat FYI, exedy Stage 2 clutches slip @ 320 ft-lbs of torque...hence the flatter torque curve.
v-mount ftmfw. |
02-22-2008, 11:15 AM | #153 |
^ Nice Torque curve!
Like Me on FaceBook ! |
02-22-2008, 11:17 AM | #154 |
Yeah HKS evc V. like I said It's not having problems untill I try and set it in the 18-20psi range which was making me think that the internal wastegate was the problem. I may try preloading the wastegate actuator a little more and see what it does.
Keeping it Godzira bishes. So I murdered another turbo |
02-23-2008, 10:12 AM | #155 |
only thing i know is that they centerline of the cams have been known to be off by a few degrees. basically saying the cams aren't timed correctly. Which can be fixed by adjustable cam gears.
02-25-2008, 12:12 PM | #156 | ||
Trader Rating: (58)
Feedback Score: 58 reviews
I've preloaded, un preloaded, done everything in the book. The solution (hopfully) is getting the external gate provision on my stock manifold (thanks to Enthalpy himself). Quote:
Not sure if the I/C is hurting any or not either...i'm not an intercooler master by any stretch....
02-25-2008, 03:38 PM | #157 | |
02-25-2008, 04:22 PM | #158 | |
Trader Rating: (58)
the greatest advantage IMO with that turbo is the stock manifold. It helps keep heat in the manifold, helping spool and torque. Not to mention OE is also divided/twin scroll sort to speak.
02-25-2008, 04:52 PM | #159 |
true, I've got my stocker in a box somewhere. may see about having a wastegate port added to it and coat it like yours is. ah well. other fish to fry on the current setup to handle first. like getting my timing dialed in lol
02-26-2008, 11:33 AM | #160 |
What fitting do you guys use for your circuit sports oil line. I know it needs a restrictor fitting (which came threaded in my turbo) but will not thread onto my new line. The circuit sport line came with a fitting that threads into the turbo and line but dosn't have the restrictor.
02-26-2008, 10:42 PM | #161 |
Trader Rating: (58)
/\ I have no clue. I bought the TAKA kit and restrictor.
02-29-2008, 09:36 AM | #163 |
Can someone that has a gt2871r .64 tell me the numbers on your wastegate actuator? (there is a little sticker on it) I bought one from jgycustoms and my receipt says for fwd gti-r. I just want to make sure its right.
02-29-2008, 09:53 AM | #164 | |
Moral: don't get caught up in numbers people. |
03-03-2008, 09:37 AM | #166 | |
Trader Rating: (58)
At 18 psi, I was trapping 118. My dyno's are all at 20.....full weight s14...so I'd say the dyno numbers I have are spot on (400whp)for the setup. Probabyl in the 440-460 range...
03-03-2008, 10:14 AM | #167 |
03-03-2008, 10:15 AM | #168 | |
Please Believe it.
03-03-2008, 10:25 AM | #169 |
Trader Rating: (58)
Hehe. I wouldn't care if the car made 350 whp, as long as it's faster than z06's and 997's on track is all I'm worried about
03-03-2008, 04:33 PM | #170 |
i have
BC 264 cams Gt2871r .64 Greddy intake manifold 740cc injectors enthalpy tuned ecu z32 MAF hoping for 400 hp around 19-20psi. just got to get her to fire up first. |
03-03-2008, 06:54 PM | #171 |
My S13 full weight, did 117.5mph in 1/4 mile and dynoed 353whp. 1/8 mile was 90mph i believe. New setup does 93mph in 1/8 mile. still waiting for weather to let me go to the track for 1/4 times/speeds.
03-03-2008, 07:42 PM | #172 | |
PROCEED Grip Gambler |
03-04-2008, 12:16 AM | #173 | |
Trader Rating: (58)
I need to get some place new...Island sucks. Talk about spinning all over....
03-04-2008, 07:11 AM | #174 |
Cecil County. I was gonna go this friday but it looks like rains moving in. Its like $15 to race on friday nights. Real relaxed tech inspection too. ive got an illegal mounted battery and they never check for it.
03-07-2008, 07:55 AM | #176 |
How come no one goes to Maple grove. Isn't that closer to you than Island Cody?
I miss Alabama. Midnight madness, $10 every Sat night starting at 12. I could get 10 runs in by 3. Usually left before they closed. |
03-07-2008, 02:35 PM | #177 | |||
Trader Rating: (58)
Then you must have spun the shit out of your tires.
03-08-2008, 08:17 AM | #178 |
^^ If anyone wants to go to Atco, I will probably be heading there next weekend.
The good thing about Atco, is they don't make you wear a fire-jacket or whatever. Last time I was at Englishtown, the guy let me by tech, but said that from now on, because it is an FI car that wasn't FI from the factory, I would have to wear a "fire-jacket" Fuck that, I just go to ATCO now.
Daily driven |
03-10-2008, 11:14 AM | #179 |
dammit. my 2871r bit the dust this weekend. out of nowhere i hear a whining noise. thought I suddenly picked up an alternator whine through the radio... but then i had 0 boost. checked couplers manifolds and everything. finally when it cooled down took the intake off the turbo and reached in. shaft play (side to side no front to back play) whining was the blades on the housing apparently.
