10-26-2007, 04:19 PM | #121 | |
I've been using the GC hardware (coil-over conversion kit as you call it) for the past 4 years on a few different sentra's, have completed nearly 15K track miles, and many many autocrosses, along with daily useage. Oh yeah, the GC hardware was used when I got it and is still in use with the current owner. So, do please explain... |
10-26-2007, 04:38 PM | #122 |
anyone look into the KW motorsports version?? I know they offer 2 styles.
I've seen JRZ in used before. But that's $$$
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!! formerly sideviewcivic Save a Horse. Drift This Cowboy. AirBag Club Member #0014 |
10-26-2007, 06:06 PM | #123 |
Spot on Monty, the housing is longer but the spring perch is in the same location on the tube. Only the strut itself is longer, but the spring would be the same length between them.
www.nissanroadracing.com |
10-26-2007, 06:50 PM | #124 | |
Oh yea hey Veilside180sx, are your housings solely for Koni 8611's and 8610s or can i put in a set of bilsteins in em? |
10-26-2007, 07:02 PM | #125 |
I have never tried to use a set of Bilstein dampers because most lack external adjusters for the damping.
PM me the specs on what you have and i'll let you know though.
10-26-2007, 07:07 PM | #126 | |
Autox Technician
I have the feeling KW uses a Koni insert in their shocks, although that's prety much solely based on the rebound adjuster looking a lot like the Koni tab.
Bilsteins are insanely upgradeable, too. If Wiisaas had an s-chassis Bilstein setup earlier I might've gone that route (with Penske or Bilstein resevoirs), but the modular design along with the ease of replacement with the Koni's being a standard part keeps me happy, along with them being double-adjustables from the get-go (Bilsteins are non-adjustable normally). Eventually I'll upgrade to something even more digressive than the Koni 86's. It'd be cool if they released performance FSD inserts (like something based on their F1 stuff), but I'll probably end up with Motons, or Ohlins if they aren't much more (than Motons, at least).
10-26-2007, 07:13 PM | #127 |
well damn it... coilovers may be getting tossed for this guy... I'm a grip minded driver and I doubt the D2s are gonna satisfy me, especially since on the shakedown run it jarred my balls loose... subscribed...
<------ Grumpy Old Asshole MY REVIEW THREAD: Ltdnismoracer4=DOOK http://www.zilvia.net/f/showthread.p...ltdnismoracer4 |
10-26-2007, 07:14 PM | #128 | |
Motons, Ohlins and all those are just overkill for what i want. I'm just a weekend road racer but i didn't want to buy into all those jdm coilover setups. Veilside180sx, you got a pm. -Jason |
10-26-2007, 08:57 PM | #129 |
Jason Rhodes ran 2817's, which are twice what the 8611 cost.
10-26-2007, 10:14 PM | #131 | |
"KW is proud to use Koni as a partner on a small number of Variant 2 applications in our ever-growing lineup of coilovers. These specially built, KW Tuned and valved, Koni Built dampers provide the perfect ride adjustable solution for their respective applications. " so it would not surprise me that they may have koni dampers in the variant 3 but i cannot say for sure. is there any build-it-yourself solutions that would allow me to lower the front close to 2.5" and rear close to 2" (about what the KW V3 would do)? i want a hybrid between lowering and handling IF POSSIBLE. if so, i might as well save some money by not going with the V3. |
10-26-2007, 10:45 PM | #132 |
Koni doesn't offer an external res. insert, so any of the external ones are not Koni. i would imagine they must use Bilstein for those inserts...
10-26-2007, 10:53 PM | #134 |
93SECoupe on here did not receive an external reservoir with his V3 and neither did some of the folks on Nasioc. so i'm thinking they made 2 different V3s...
10-26-2007, 11:55 PM | #135 |
10-26-2007, 11:58 PM | #136 |
If mine ever have...i can't tell.
The only time mine seperate like that is when it's jacked up off the ground.
10-27-2007, 12:01 AM | #137 |
on those who picked up the V3 was it the standard one or the motorsports version. Some of the guys in FormulaD are using KW V3 and they have external resevoirs.
10-27-2007, 12:11 AM | #138 |
10-27-2007, 12:13 AM | #139 |
It's not necessary, the o-rings between the sleeve and the strut tube hold it in place (they also keep it from rotating). In addition the sleeve will not slip over the top of the gland nut, so either way it is not going anywhere.
10-27-2007, 05:35 AM | #141 |
I have the Techno Toy Tuning top-hats and they seem to take up the least space (shock travel) of any of the other camber plates that I've seen in person. The only negative I have with the T3 hats is the cheap bolts that are included. Just replace them with stronger ones before installing.
Jason '95 240sx SE |
10-27-2007, 05:47 AM | #142 | |||
Autox Technician
10-27-2007, 04:11 PM | #144 | ||||||||||||
Been busy the past couple days, so get ready for a long one. Sorry, but it will be full of good information.
But there's a lot, or there should be a lot, that goes into selecting a spring rate. It has to do with sprung weight, unsprung weight, geometry, intended use, tires, wheels, power, sway bars, cg height, wheelbase, etc. It's a lot and it's not the easiest to explain. If you really want to figure it out on your own, start studying spring-mass-damper vibrations models and natural frequencies and all of that fun stuff. But even after that, it's a lot more complicated, it depends on what natural frequency range you want to be in, the ratio of front to rear, and then you have to look at lateral loading and roll and weight transfer and understeer/oversteer balance and it's just a lot. Usually you can pick a good starting point and then fine tune from there. After you get the spring rates, then you look at the dampers. It depends what damper you're going to use, how adjustable, are they revalvable, do you have dyno plots, depending on the answers to all of these, you can pick a damper. If it's revalveable then you can just revalve it to suit your spring rate and mass. If it's not, but it's adjustable enough and consistent, then you can just adjust until you get it right. Or if you have dyno plots, you can calculate a range of springs that will work, then compare it to your other numbers, and then pick the best compromise. I know, it sounds complicated and a lot of people won't go through all this trouble and they will eventually get to where they want to be. But I like to run all the numbers, do all the calcs, so then I know what to expect and since i have verified the model I use, I know it is relatively accurate as long as any assumptions I had to make were accurate. Quote:
I wish I had that Bilstein setup done earlier because then I would have more time to test it. But things should be getting dynoed next week, so at least I'll have some sweet dyno plots and know what I'm starting with. We never finished that FSD discussion we started in another thread like this. I'm still not sure if it's as cool as it sounds, I mean it sounds pretty good and if they're using it on F1 cars, it probably does something. But then again, F1 is all about aero right now, but I do have a couple articles about FSD and they kind of tell you how it works. I remember thinking it was kind of just like a blow off valve for the damping, but most blow off valves are on the piston, but the FSD is part of the foot valve. So it seems like it's a blow off valve but it's for the change in volume in the shock due to the shaft coming in. So the amount it opens is based on the entry of the shaft. Quote:
But even if they did extend quicker or it was a gas charged shock will which extend quicker, you could just use a help spring which will keep things connected. Alright, I think that's it. Hopefully it wasn't too much. Tim |
10-27-2007, 04:35 PM | #145 | |
10-27-2007, 05:23 PM | #146 | ||||
Tim |
10-27-2007, 11:55 PM | #147 |
I'm so excited that we're actually discussing proper suspension setups finally for our cars! Lots of great info here.
Tim, I can't wait to get my Bilsteins overhauled by you and hit the track. I'll try to get as much feedback as possible with a real driver behind the wheel as I have little experience road racing. I'll be throwing Matt aka turbomx5 on supraforums behind the wheel! heh To others interested, you CAN find used Bilsteins from japan as i did most recently! Took me more than 5 months of searching though. -Jason |
10-28-2007, 05:43 AM | #148 |
FWIW, Bilstein will revalve all 4 shocks for around $275. They did a good job at getting the valving to match the rates that I'm using, and they did it with a 3 week turn around time.
10-28-2007, 06:20 AM | #149 |
here's a picture of how I lowered mine in the stock housing. This isn't complete because I don't have the spring perch sitting that low.
10-28-2007, 10:58 AM | #150 | |
Yea that's the main reason why I wanted to go with Bilsteins. But i'm going to have Tim do some special work to mine |
