07-08-2013, 10:56 PM | #14221 |
Why does all of my SOHC ECU's power up and none of my DOHC ECU's power up and its a New KA24DE swap and everything on the wiring was followed correctly. Have started the motor with an SOHC ECU but will not run right
07-08-2013, 11:23 PM | #14222 | |
Bandwagon.
He loves them. When i redo his pad/rotors again ill check the slide pins and MC. Thanks |
07-09-2013, 12:52 AM | #14225 |
Alright I'm new to this but heres my question im in dire need of help and want to order a maf tonight. I've got my 1989 240sx with the sr20det s13 redtop motor. I had the ka24de maf sensor which you can't run thus why it was running like shit. I'm not getting a z32 because I don't have the money to tune it right now. I'm going with a ka24e maf but will my ka24de clip fit this maf so i dont have to rewire it? I also am having trouble really finding any ka24e maf's or sr20det mafs even. I need help!!!
07-09-2013, 02:56 AM | #14226 | |
Trader Rating: (26)
Feedback Score: 26 reviews
I think it says search first. |
07-09-2013, 02:58 AM | #14227 |
They have shims under them, make sure you keep them with the lifter they came from. you may also need to check valve clearances and replace shims where necessary.
07-09-2013, 07:26 AM | #14228 | |
You may have to, yeah, you have to disassemble your head
07-09-2013, 08:12 AM | #14229 |
If lifters just pull out then I doubt that, its just a matter of getting a grip on the lifter to be able to pull hard enough to get it out
07-09-2013, 06:37 PM | #14232 |
code 11 and 21. 11 is CAS, 21 is ignition circuit. How do i go about fixing them? Car starts and drives ok, just suuuuper bogged down under load until it gets to about 5k. pretty annoying to deal with. last i checked timing was at 13* and all sensors checked out good, but that was about 8 months or so ago. Car has felt the same since then, just never really bothered to fix it until now. Will get it on a consult and write down all the numbers and whatnot to help, just seeing what suggestions people have
BustedS13: anything you can hide on your person is free. junkyard law. |
07-09-2013, 08:34 PM | #14233 |
I have a rhom tune ecu for my red top SR 550cc injectors t28 z maf and all that, but my ecu is tuned for all that plus 9:1 .020 bore pistons, my question is if I run that tune with a stock SR bottom is that a no go or will it still work properly??? Cause its tuned for that set up but the only difference will be stock bore and compression, I just don't know if that's enough of a difference to where I wouldn't be able to enjoy the car or possibly blow it up
07-09-2013, 09:17 PM | #14234 | |
Trader Rating: (58)
Feedback Score: 58 reviews
If the new setup is using the same injectors and MAF it should work just fine.
07-10-2013, 01:24 AM | #14235 |
ok so in this video what type of wire connectors is he using? male? female? SOMEONE PLEASE HELP! thanks!
240sx Sleepy Eye DIY - YouTube |
07-10-2013, 03:18 AM | #14236 |
Too much trouble just to get useless lights, cut the brown wire
If you insist, http://www.youtube.com/watch?v=4HLgIibASP8 |
07-10-2013, 03:40 AM | #14237 |
For the reply codyace, maf is always in the same position since the wiring is exactly the length. It's facing the right way, filter has a new green hks element. It feels better with the HKS but the lean condition scared me so I took it off. Not sure why it's so lean under boost.
07-10-2013, 06:20 AM | #14238 |
alright.. so ive been searching google for the answer to this question.. like ive stated earlier, ive decided to buy a sr20. NOW my question is can you stroke it and still boost it? or is it dangerous to do so? im just curious if stroking it increases compression ratio? i know that you cant have high compression with boosted motors.. any help would be awesome.. just putting a list together for when i get home from afghan for the motor im building.
07-10-2013, 06:37 AM | #14239 | |
Lifters: are NOT a part of this assembly As you can see, disassembling the head, ie removing the cams, allows shims and buckets(improperly labeled as lifters in the photo diagram) to be removed so valve springs retainers can be removed and valves can be removed. If you broke a 'bucket' that is under a shim, you are doing something wrong, or half assing the job by not taking the proper steps
07-10-2013, 07:39 AM | #14240 | |
07-10-2013, 07:40 AM | #14241 | |
07-10-2013, 09:43 AM | #14243 | |
I want to see pictures of you garage, just to see if it lives up to my imagination.
* S14SR22 * 9.0 c/r * GT3071R * |
07-10-2013, 11:18 AM | #14244 |
Can someone tell me where the factory plug for the a/c condenser fan is for an s13? I'm trying to wire up the high speed on my altima fans to the a/c circuit and have it cut on with the switch, but when I did my sr swap I tucked away the wiring somewhere and I don't know where I'm supposed to even look. Also if someone has a picture of the actual plug that would be helpful too.
07-10-2013, 01:29 PM | #14246 |
Where should I start car been sitting for years rats are up wiring I did a full gutting pulled off all dashes now going for the engine I want this baby running. I'm young and dumb help a brotha out with his s14
07-10-2013, 01:54 PM | #14247 | |
