#1231 | |
Also, in case if PMB don't have lower bracket for z32 upright, can I buy stance z32 lower bracket and screw it on PMB coil? is the diameter b/t PBM and Stance the same? thanks |
#1232 | |
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
#1234 | ||||
![]() Quote:
![]() I have not personally tested it with those, but the factory shroud works so there should be the same compatability with your fans as other radiators. Quote:
All the way from Japan and installed in 1 week thats pretty cool!
#1236 |
^^^^^^^^^^^^Not in stock right now but I can order it. Theres no extra charge (if ordered as part of a set of coilovers) & you give me time to ocean freight it here.
#1238 |
![]() Join Date: Nov 2005
quick question, who here has the S14 RUCA powered by max, i heard it needs spacer because it might rub with the coilovers, is this true and for what coilovers?
#1239 |
^^ good question, because I'm also thinking of getting S14 RUCA, any comment?
Dan, I already have a S14 PBM coilover but now I'm switching to z32 spindle so I'd like to buy the z32 rear lower bracket alone w/o the coil. So how much is it to ocean shipped to 98008? and how long does it take? thanks Dan. |
#1242 | |||
$220 shipped. Drifting of course! ![]() [ame]http://www.youtube.com/watch?v=T2r5B0tAS1g[/ame]
#1244 |
sorry to post so much but I just want to make sure, so the z32 rear lower bracket is available separately and can be put on S14?
how come this option is not available on poweredbymax.net? |
#1245 |
Yes Z32 rear lower mounts are available seperately upon special order. 15 days lead time to produce them. $175 shipped via air from the factory, $120 shipped once we have them in stock from our next ocean freight, and $0 extra to build them into a coilover purchase from our next shipment. They can be put on S chassis coilovers. Its not online because we dont make MAX Z32 coilovers...yet.
#1246 |
WARNING - Dont let improperly threaded adjusters ruin your multilink parts, your car, or your health. - DANGER!
A customer called us today and said that his RUCA snapped so we asked him to send pictures so we could determine what happened. He said it happened on the freeway when he ran something over. He almost smashed into a guard rail! He sent this picture. I marked it with comments and arrows to warn everyone not to make the same mistake: ![]() Here is the RUCA taken apart to show the different thread lengths in each side / part of the adjuster. The pillow ball has 50mm of threads and the adjuster has 35mm of threads. ![]() Here is what it looks like when the large adjuster is threaded into the arm 14 turns and the pillow ball is threaded into the adjuster the same 14 turns. It is important to thread them equally upon install before you adjust the overall length required for your desired alignment. Note that an equal number of turns leaves an unequal number of exposed threads. ![]() Finally we see why the pillow ball threads are longer than the adjuster - all three parts can overlap inside the arm for strength. ![]() Its a pretty obvious concept to use a reasonable number of turns in each component during assembly and install, but its not fool proof. The RUCA ships with the arms and adjusters packed seperately. Therefore it is up to you or your automotive / alignment shop to put it together with a safe number of threads connecting all sides of all components. We will include this warning in all adjustable multilink parts from now on. Improper adjustment is not warrantied, but because I understand we need to warn customers and their shops I replaced the damaged RUCA completely free of charge, and will include a warning in all future shipments. Parts Shop MAX is here because we love the sport, and want to contribute and see that it grows. We certainly dont want to see our customers break their parts, cars, and themselves in the process. We're not perfect, and neither are enthusiasts & service shops but we'll do our part to constantly improve. So do your part and double check that your adjustmnets are safe (no matter what brand you have) and if there is any questions you have when installing a part dont hesitate to give us a call.
#1247 |
I'm not trying to be a pain in the b*** but how come it's so expensive for the just z32 lower bracket? usually like stance or other coil, it's only 70 for a shipped z32 bracket. Just want to know the reason why. Thanks Dan.
#1249 | |
I didn't order them air freight, didnt think its worth it, we'll get some later via ocean.
#1250 | |
![]() Join Date: Feb 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
![]() Quote:
poop mama... |
#1251 |
![]() Join Date: May 2005
Originally Posted by burgerwitfry quick question, who here has the S14 RUCA powered by max, i heard it needs spacer because it might rub with the coilovers, is this true and for what coilovers? its true for 17x9.5+15~17 in the front Dan, Im confused this is a ruca how does this rub the front coilover? im very confused on where the rubbing is occuring
![]() parking lot pimpin... Seller Feedback here: http://www.zilvia.net/f/showthread.p...ight=pbcstylez |
#1252 |
pls quote me for s14 ruca, rear toe shipped to 94089 business addy
#1254 | |
poop mama... |
#1259 |
![]() Join Date: Dec 2007
Trader Rating: (38)
![]() Feedback Score: 38 reviews
i want the Oil Catch Tank
how much can you do for pick up or shipped to 92220? email me [email protected] |
