#8913 |
Philosopher King
What he said.
G O L D E N B E A R R E P U B L I C |
#8915 |
![]() Feedback Score: 8 reviews
PROBLEM: i have a leak coming from my turbo banjo bolt that my dad put in after swapping the turbo but the problem is he started to thread it in wrong then continued doing it now it leaks a good amount of oil from that bolt.
MY QUESTION: if i take out the banjo bolt to replace it, will the thread on the block be effected or is the banjo bolt taking all the threading effect? |
#8918 |
![]() Join Date: May 2011
if you are going to look at one with a sunroof, check underneath the back side of the door and near the back tire there before the wheel well. they poorly designed the drain for the roof, and mine has terrible rust there as a result. my front frame rail is rusted a bit too, but that could be because its a Michigan car.
#8919 |
put the car in 5th gear then try to start it
theres a stop switch in the 5th gear trans that makes the locks engage 3 times if theres no prior CELs for the car 5 times if there is if nothing happens, that means te guy cut it out and its sketchy
street dancer. GLEAM |
#8921 |
![]() Join Date: Sep 2007
Trader Rating: (32)
![]() Feedback Score: 32 reviews
S13 hatchback
Okay, got my fortune auto coils installed. Fortune auto arms on the way. Running 16x8+20 right now, but will run 17x9+20 w/ 215/40. I'm trying to track down some form of modified alignment specs for the shop to use.. or some type of guidance. Ride height is set to minimal tire gap. |
#8923 |
![]() Join Date: Mar 2007
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
70+psi at FPR
I'm just about ready to crank my engine.(want to Roll over a few times 1st)
When Pump Primes..I get a reading of 70-80psi at the gauge on the Tomei regulator. What would cause That? I adjusted/tightened/lowered Regulator since Its new and never Set yet and Still Pretty damn High. I can only think that maybe I routed the feed/return Sections wrong??? Hardline Side??its Correct from rail and from Filter. anyone Have a pic showing correct "Body" Fuel Hardlines that go from and to??
z-tERty-2 |
#8924 |
![]() Join Date: Apr 2010
![]() Feedback Score: 7 reviews
ok, this connector stems out from the lower harness that goes to the starter. the positive and ground are in, but this plug (red outline) doesnt seem to go anywhere.
Zeeeeeeeee32 |
#8925 |
![]() Join Date: Dec 2010
searched, couldnt find a *definitive* answer. for those that have solid subframe bushings in your car, how bad was the ride after? i've ridden in one car, once, with them and didnt notice much but i plan to DD the car with pbm solid risers/bushings and dont want to go through all the trouble to find i absolutely hate it. car will see mostly track and comfort isnt the most important thing but it needs to be dd'able
#8926 |
so you're saying if i start the car in fifth the locks on the doors should engage three times?
#8927 |
im just trolling kid. search this shit, its been covered a million times by people like you
Question: How difficult is it to make a tube front? I've done fab work as far as building gokart frames and am currently building a supermilage racer, so I have a bit of experience, but never with a car.
#8929 |
i know
seriously though SEARCH FIRST it says it right in the title 240sx arent mystical cars, what ever people say for other cars are the same for this. Either way, you are most likely going to run into problems. These car's are like whores. Theyve been passed around so many times that youre lucky to find a stock one, and even then sometimes its been touched
#8933 |
![]() Join Date: Dec 2009
![]() Feedback Score: 21 reviews
Can someone explain how tie rod spacers work? I get that it pushes one tie rod out, but wouldn't you then have to thread the outer on more? Which doesn't make sense to me. I keep thinking that the tie rod would still be the same length. I'm just curious and for some reason I can't figure it out...
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
#8934 | |
#8935 | |||
![]() Join Date: Dec 2004
Trader Rating: (58)
You will need a new FLCA, or to get the Nismo style bushings with the sleeve. That's the only way. Much like I said in the first post and reply to your question.
When you disconnect the vacuum source, and key on, it should show 43.5 psi. Adjust accordingly. Quote:
It's all relative to your fab ability, and motavation.
#8937 | |
LOL.
#8938 |
ya spacers on both sides. if im not mistaken i believe the "one spacer" deal was because the rack was supposed to be able to move further out to one side (drivers?) so you'd put the spacer on the other side to even it out. i just pust spacers on both sides when i got my tein tie rods
#8939 |
![]() Join Date: Dec 2006
Who knows the Wire Functions to the S13 Speedo?
is one a ground and the other a Signal? Trying to wire up my S13 Speedo in my AE86. FSM is not being that helpful on this subject
1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit Last edited by Sileighty_85; 12-20-2011 at 06:28 PM.. |
