#8251 | |
![]() Join Date: Dec 2010
Trader Rating: (42)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 42 reviews
#8252 |
What are my options as far as Rear Diffuser on S14?
So far ive seen/searched; Top Garage, Origin Raceline, and some custom looking stuff. What else is there out there? Is there a site i can choose a bunch of diffuser from and I can just cut my bumper up? thanks
#8253 |
Since tech threads are gone figured I would ask in here. I just bought another 240 and it has the sohc, i need to replace the tensioner bearing. Does anyone know the part number so i don't have to buy the whole tensioner?
#8254 |
![]() Join Date: Aug 2009
![]() Feedback Score: 27 reviews
i just did the nx1600 cluster swap. i'm not positive on all the wiring it was really my first time doing wiring and it works perfectly fine but my headlight fuses blew out and i'm not sure it was from the cluster cause it didn't happen right away. it happened after a few times driving my car. my question is could faulty wiring to the cluster have anything to do with the headlight fuses going out?
#8255 |
Im hearing mixed reviews about the pbm skid plate, I read people say they suck and aluminum is weak. Other say they are strong and amazing. Anyone honest review before I get one?
#8256 |
i am having an issue with my usdm climate control in my s13. I have all 4 speeds working properly but all of a sudden i cant select different vents(shit is stuck on the floor). first thing i did was replace the climate control unit with a forsure working unit, still the same. I searched an searched and still am not sure..... ANY IDEAS??? I am thinking that this has something to do with it, but i dont know what the hell it is??? sorry for shitty pic but im refrencing the black thing with the brown plug in it.
#8257 | |
Theyre rigid as fuck if you only bolt the rear two and the front middle. Only bit of advice is to use thread lock when putting the bolts in, mine came off on the highway and it was dragging. made a light show for traffic. IMO it was well worth the money, i would buy it over and over again solely based on the fact that it prevents big ass things from hitting my oil pan, cause you can't always avoid those shitty bumps that bulge in the middle |
#8261 |
Will any year q45 from 1990-1996 front caliper fit on a s13? I'm trying to buy new rotors from 88 rotors but they requested to specifically note the manufacturing year/date. Which led me to question if there's a change in caliper between 1990-1996? I don't know what year my q45 front calipers came off of but they bolt on perfectly fine. I just need new rotors! Do i just tell them i have q45 brakes and they've give me the appropriate rotor for my application?
#8262 |
![]() Join Date: Oct 2011
my steering wheel is hard to turn when the car is standing still like it has no power steering, and if im moving its easy to turn like power steering should be but i cant move the wheel back and forth (as if you would initiate a drift) theres alot of resistance, and normalyy if you take a turn you can let the steering wheels spin to straighten out, mine will not do that i have to always turn the wheel is this a bad pump? or could it be the steering rack and pinion? or just taking a shot in the dark here could it be my cut springs? they are all cut differently from previous owner
really would appreciate help for this |
#8263 |
my car will get up to 180*, but when i accelerate or downshift hard, my aftermarket and factory temp gauges will drop down below 140* and than slowly climb back up unless i really beat on the car, which than it drops all the way down on both gauges....thinking it has something to do with the thermostat and not so much with any wiring or anything since it happens in both gauges
info on car car is a 90 with an sr swap aftermarket gauge picks up right out of the motor before the top of the rad |
#8264 |
Small question to go along with that...
My electric fans are set to ALWAYS ON for my sr, does it need to be set to come on after a certain temp? Its getting cold here and my fans are always on and my car takes for ever to warm up. |
#8265 |
#8266 | |
but it also depends on your fan setup as i have altima fans and one is always running, and the other comes on at like 180-185 |
#8268 |
![]() Join Date: Jan 2011
Trader Rating: (26)
![]() Feedback Score: 26 reviews
Is anyone on here running a gt3076 or equivalent on an SR?
I don't even have an oil change on my 2871 and I kinda wanna jump up. I'm looking at a buddies 61 Mm turbo. It's not too big. I just wanna know what the response is like
IG/TikTok-ThatS14_Z06guy |
#8269 |
Trader Rating: (42)
This thread fucking blows. I've tried using it three times. All three bumping my question three times. For now on I'm just going to make more pointless threads for small questions
#8270 | |
![]() Join Date: Dec 2007
Trader Rating: (68)
![]() Feedback Score: 68 reviews
Maybe your differential covers have to do with having non hicas or hicas in your car? Abs or non abs? Open differential or vlsd? Making pointless threads or researching yourself? And I believe you should be fine with your subframe like that, just install your subframe risers. You can ask matts13vert on here to clear that up for you.. He also has a video on YouTube. But you can continue making more pointless threads for small questions!
Late Night Crew... #02 <3 Bought anything from me? Please leave me a review! ![]() http://zilvia.net/f/private-sellers/...meistah21.html |
#8272 | |
Trader Rating: (68)
Did you check if your taillight assemblies work yet?!?! I need them ASAP or else I'm gonna make pointless threads..
#8274 | |
got an sr w/ a 35r .64 an i have full boost at 4100! i really didnt notice a difference in lag between the 3076 and my 3564 turbos. |
#8275 | ||
pretty much, it was gay
i would say 575 max |
#8277 |
![]() Join Date: Apr 2009
Trader Rating: (25)
![]() Feedback Score: 25 reviews
i have these ARP headstuds that were marked CA18DET on the box but they definitely are not ca18det headstuds the pitch is completely off.
they are m12x1.25 pitch on both ends 127mm long, shank is like a 10mm diameter and approximately 78mm long. anyone know what these are for? |
#8279 |
![]() Join Date: Mar 2004
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
New head gasket arrived ever so slightly bent... replace or non-issue?
edit: nevermind, it's fucked. Last edited by Prime; 10-27-2011 at 12:19 AM.. Reason: solved the problem, sort of |
