09-12-2011, 08:59 AM | #7651 |
What about them?
09-12-2011, 09:12 AM | #7652 | |
Trader Rating: (26)
Feedback Score: 26 reviews
By a wastegate with a vband flange, send your oem manifold in with the flange to have it welded on, then put it on. When you buy the wastegate they have different options for the springs/psi. Tial MVS 38mm are great for the oem manifold. They are tiny, compared to other wastegates. Edit, don't forget to weld the internal gate shut Haha.
IG/TikTok-ThatS14_Z06guy |
09-12-2011, 09:27 AM | #7653 | ||||
Trader Rating: (58)
Feedback Score: 58 reviews
With that said, I don't have any experience doing the R32 setup, but the E brakes are kinda clunky for sure. If you do find out let a moderator know so they could update a faq as more solid info is what this place needs for sure. Quote:
Many do, what is your question?
09-13-2011, 12:35 AM | #7655 |
Im getting new rotors and im wondering what is better for track and drifting, drilled and slotted or dimpled and slotted? Also are password jdm rotors any good?
09-13-2011, 04:19 AM | #7657 |
Have a belt squeal on start up. It also does it if I turn on the heater and the lights or the rear defroster with the lights or the heater with the rear defroster.
Went and tightened the alternator belt and the squealing got ALOT worse and lasted longer. Plus the alternator pulley was burning hot. I'm lost.
KILL!KILL!KILL!KILL!KILL!KILL!KILL!KILL! |
09-13-2011, 09:53 AM | #7658 | |
Trader Rating: (25)
Feedback Score: 25 reviews
09-13-2011, 06:27 PM | #7659 | |
street dancer. GLEAM |
09-13-2011, 07:00 PM | #7660 | |
So yes if you could get me the light bulb size that would be great as i would love to get the right type!
09-13-2011, 07:04 PM | #7661 |
Why do my gauge light and left turn signal, turn on when i step on the brakes? Lights are off. S13 BTW.
http://thatistupid.tumblr.com/ |
09-13-2011, 09:04 PM | #7662 |
is it a terrible idea to make my own gasket for my turbo inlet/outlet? t25 on a redtop.. i have this gray gasket maker material and i'm just wondering if its worth using, or if i should get some gaskets from a 300zx.. obviously i'd rather not spend money if i dont have to
09-13-2011, 09:12 PM | #7664 |
Trader Rating: (58)
just get the cheapest rotors you can, that are solid and vented. no need for cross drill or slots
09-13-2011, 11:09 PM | #7667 | |
Trader Rating: (25)
if you have access to machining tools or have the dimensions ready then you shouldnt have a hard time getting a machine shop to make one for you. |
09-14-2011, 12:38 AM | #7668 |
Trader Rating: (25)
does the signal wire for the maf go TO the ecu or does it come FROM the ecu?
not sure if i should check at the maf or right near the ecu to make sure the wiring is ok. |
09-14-2011, 04:53 AM | #7669 | |
Anyone happen to have the dimensions ? I can head to a shop today for one to be made.
09-14-2011, 07:51 AM | #7670 | |
Trader Rating: (58)
EC section, FSM. I'd sooner just buy it to have it done, then buy the material, setting up the machine cutting it etc etc. Unless it's ALL free
09-14-2011, 12:01 PM | #7671 |
Got a tranny fluid leak where the transmission meets the engine block.
Is this an easy fix or something I'm gonna just have to deal with.
09-14-2011, 03:27 PM | #7673 | |
Trader Rating: (58)
Aside from the rear valve cover leaking, any other fix requires dropping the transmission.
09-15-2011, 03:38 AM | #7676 |
Looks like someone dropped my intake manifold off the workbench. Dent in the side, and the rise from it is on the mating surface. Hit it with the dremel and a good flat block with 400 grit. This is on the upper plenum where the runners bolt to the lower. Looks good to me, but I do have a spare.
Swap or trust the gasket to seal? |
09-15-2011, 12:42 PM | #7677 |
Q's: Type Xspoilers!<----
I have seen the 180sx type X spoiler but recently seen a hatch with a bigger on?,is there actually a big one? anyone knows where to find a big type x spoiler for the 180sx? If so get back at me! need more info, tell me what you know!
09-15-2011, 12:52 PM | #7678 | |
