#7531 | |
![]() Join Date: Nov 2007
![]() ![]() Feedback Score: 2 reviews
GKTech |
#7532 | |
![]() Join Date: Oct 2013
As for modifying the stock rcla, I assume stock s14 rlca do not bolt up to an s13? Now I'm curious if I should just upgrade to an s14 rear subframe due to the knuckles/anti squat benefits. |
#7533 |
#7535 |
Question Maybe MOTARY can shimmy in: I am looking into the GKTech knuckle adapters that provide 40mm of correction which should be more than enough with my current set up. I just have a few questions if anyone has any experience with these.
Do they raise the car when you bolt them up? Do I need longer (S14 maybe) inner tie rods? Do I need to move my steering rack forward with these? |
#7536 | |
![]() Join Date: Jan 2007
![]() ![]() Feedback Score: 9 reviews
2. Probably 3. Only if you're running extreme amounts of camber and or caster |
#7537 |
![]() Join Date: Mar 2011
![]() ![]() ![]() Feedback Score: 7 reviews
No. Wheel, hub, knuckle, coilover, and chassis all effectively remain the same relative to each other. Do I need longer (S14 maybe) inner tie rods? Yes, longer tie rods will likely be needed. Exact length will depend on which FLCA you're using. Do I need to move my steering rack forward with these? Eh, not exactly needed per se. But you will be more likely to overcenter at a lower steering angle with the standard rack location. If possible, it's not a bad idea to relocate the rack while you're at it. Edit, Greg beat me to it. When in doubt, trust his words over mine, lol
#7538 | ||
So would the gktech offset rack spacers that move the rack forward be the product I need to buy If I do the knuckle adapter mod ? Same thing as moving the rack forward? Any downside to these? Stress the rack too much maybe? Also any rack boot options out there for these? Last edited by da_crew10; 01-06-2018 at 04:55 PM.. |
#7540 | |
Seems like the last thing the last thing the S chassis would need would be a shorter more dynamic anti squat instant center. If you actually want less anti squat then lowering the front LCA pivot or raising the rear LCA pivot would be what you were looking for. Most of the benefit of lengthening the traction link would come from a slightly more consistent anti % |
#7541 | |
First off, they don't move the rack very far forward. Second, you're clamping smooth metal against smooth metal without crazy tight lateral tolerances, so the rack will actually slide back and forth when hitting lock hard. After hitting lock on a left corner, suddenly your steering wheel centers itself to the right. Then after a right corner, you're centered to the left. I had the x-member modified to relocate the rack and I switched back to rubber bushings, and the movement went away. In hindsight, I should have just done that from the beginning.
#7542 | |
https://www.polyperformance.com/susp...-tube-adapters
GKTech |
#7543 |
![]() Join Date: Feb 2013
![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
Jay is 100% on the pbm eccentric rack bushing are complete shit. 1 track day completely trashed a brand new remaned rack. I have gk tech now and the tolerance on them seem way better. Rack is not just moving left to right just like jay said. Time will tell. Next time I'm getting fraction motor sports subfame. Just was not in the budget at the time
#7544 |
Anybody running the Gktech grip knuckles yet?
I was looking at them the other day and I'd love to have the geometry correction they offer. I have no use for angle mods for what I do with my car. I can't imagine there are any downsides to these. Figured I'd ask because I couldn't find any reviews on them. |
#7545 | |
![]() Join Date: Nov 2005
#7546 |
Added sway bar options to the end of the steering angle post, with more pics coming later today.
Also, if anyone has the lengths for Z32 and Z33 tie rods, I'd like to add those to the list on post two.
#7547 |
#7549 | |
#7551 |
got an s13 subframe with spl solid bushings ,what can be done to increase traction ,using the car for drag racing so just need as much traction as possible ,will tilting the subframe be effective ,anyone with actual experience doing so ,and what other mods can i do other than using an s14/15 subframe ,is there a better solution or upgrade i can do to my current suspension
#7552 | ||
#7553 | |
#7554 | |
An easy solution is to run a spacer at the top of the strut. I'm not quite sure what you mean by you trying to email us? The grip knuckles are the same as the billet knuckles in the sense that the height has not been increased. Essentially the spindle has been raised but everything else remains. |
#7556 | |
That's odd. We've been receiving other messages via the website fine. Sorry about that. |
#7558 |
