Old 10-12-2018, 01:10 PM   #661
TheRealSy90
TheRealSy90's Avatar
They're WAY stronger than sr20 gears.
Such a good signature.
Old 10-24-2018, 04:54 AM   #662
gmr
gmr is making a name for him/her selfgmr is making a name for him/her self
Hi guys
Thanks for all the input and advice in this thread. Ended up going with a new 370Z, Mazworx bellhousing and crossmember, and Serial9 shifter for my S15.
Gearbox bolts up high with zero hammering or cutting of the chassis. Am stoked.
gmr is offline   Reply With Quote
Old 10-24-2018, 02:17 PM   #663
slider2828
slider2828's Avatar
Very nice! Great pics too!!!
Turn and Burn!
Old 10-31-2018, 06:49 PM   #664
Kylepaschke
Kylepaschke is an unknown quantity at this point
@gmr that is awesome!
Kylepaschke is offline   Reply With Quote
Old 11-18-2018, 04:32 PM   #665
gmr
Thanks guys cheers.
Picked it up this weekend. First impressions:
- Serial 009 shifter is really good, very direct and engages well. It is very short. I've got a standard size shift knob and am going to get a longer one to extend the throw at my hand.
- The ratios of the CD009 box are great with 4.11 final for street driving. It's very punchy and gets up and goes. 100km/hr (about 60mph) the car sits at 2600rpm. This setup would be too short for the track where you'd be changing gears too often.
- The CD009 box is noisy. I bought a new 370Z box from Nissan and it chatters, grinds, gurgles lol. In fairness everything is solid mounted and I've got a twin plate clutch which makes as much noise. Reading 350z/370z forums they have the same issue once the dual mass flywheel is replaced. Their cars have a lot of insulation around the tunnel so I'm going to install some on my car too. In a track car it wouldn't be an issue, but it's a bit noisy for the street.
- I put new coilovers in the car at the same time, and with the ride height set I have about 80mm clearance from the ground. My car isn't low or sacked by any means. I'm going to make up a bash shield as the lip of the bellhousing could get caught.
All in all I'm very happy with the swap and would happily recommend the Mazworx and Serial009 setup.
Cheers
Old 11-25-2018, 09:30 PM   #666
slider2828
slider2828's Avatar
Quick question. I have a maxworx kit sr cd009. Which starter did you guys use? It seems like the bolts on the start is smaller than the bolts in the transmission.
Any help?
Turn and Burn!
Old 11-25-2018, 09:55 PM   #667
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Should be stock SR starter.
Old 11-25-2018, 09:57 PM   #668
slider2828
slider2828's Avatar
Yeah you are right. I was threading it the wrong way. I should have thread it through the bell housing into the starter vs the other way. LOL.
Turn and Burn!
Old 12-05-2018, 10:59 AM   #669
RalliartRsX
Trader Rating: (32)
For the folks running the HR or JK40/41 tranny and Mazworx bell housing kit, where does the tranny adapter ring install?? About to upgrade from my early CD001 to a HR 2008 gearbox and will need to swap things over (and buy the ring from Mazworx)
Thanks
Old 12-31-2018, 05:25 PM   #670
speedgod^s13
speedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond repute
Send a message via AIM to speedgod^s13
How does the gearing work with the z33 trans? In my case, I have an ATS 1.5 way, with stock gearing. If I were to go with the z33 trans, would that affect anything on the rear end, or would I have to change anything to do with my gearing? Or just slap the trans in and go?
speedgod^s13 is offline   Reply With Quote
Old 12-31-2018, 05:30 PM   #671
roninwon
roninwon's Avatar
roninwon is an unknown quantity at this point
Send a message via MSN to roninwon Send a message via Yahoo to roninwon
I have the stock 4.08 gearing and I don’t like it at freeway speeds. I’m going to swap my gears over the the s15 3.692 for some better rpms at those speeds.
roninwon is offline   Reply With Quote
Old 12-31-2018, 05:36 PM   #672
speedgod^s13
What are your rpm at 60mph?
Old 12-31-2018, 08:16 PM   #673
roninwon
roninwon's Avatar
Not sure cause speedo isn’t set up yet but I’m hitting about 3800 rpm at freeway speeds
Old 12-31-2018, 11:11 PM   #674
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
The over-drive gear isn't much taller than the 5 speed. .79 on the Z33 vs .84 on s14. So don't expect low cruising rpm just because you have an extra gear. The difference is in the 2-3-4 gears.
Can plug the ratios into a gear speed calculator and see if you'll need to change up the final drive. Or drive it and make a decision later.
Old 01-15-2019, 06:30 PM   #675
dreaMervaj
Trader Rating: (18)
dreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-known
Originally Posted by D-Clem View Post
Ok guys, I have the factory speedo working in the S14. I tried to use some of this info on mine but he is using a SGI-5c and I believe that’s just the older model as the newer model SCI-5e does not have dip switches and is all electronic options and adjustments. After playing with it some, I’ve got my settings that worked for me. I’m sure there’s a few ways to set it up but here is what I did. Intellitronix box setup just like his, to the 16,000ppm output. You do not need the VSS signal ground to have the speedo work. All you need is the Red/yel wire that feeds the VSS signal to the speedo. Couple of places to grab it, either directly from the back of the cluster or down the line closer to the lower harness. I spliced it right at the cluster because it wasn’t was just easier for me at the time. So take that and use it for the Dakota output 1. Use the white wire off the intellitronix for the input to the Dakota obviously and with this setup, mine was defaulted to the L-L or low to low setting already but if yours isn’t, follow the instructions and change it to this. You just hold the set button while powering up to see which program it’s on. Once all this is wired, and program is selected you can set your gain, or whatever it’s called. The “calibration” of the Dakota box. It shows you in the instructions but basically there is just a + and - button and you adjust the correction factor. With a 235/40/18 and using a gps speed app on my phone, I ended up at .512 with the above settings and it is absolutely dead on at all speeds. I really hope this helps someone because it was difficult to find any info for me on the stock cluster input and all that but here you go.
So in summary, all you need is
Intellitronix GPS Speed sensor and the Dakota SGI-5e, the above settings for Lou is using an older SGI-5c unit with dip switches, and the ones sold now are digital and do not have that, just to clear up confusion. I was confused so I thought I’d share that.
So intellitronix only needs power and ground.
Setup the dip switches to 16,000ppm which in what Lou posted, but it’s in the paper that comes with the unit and there are two options for 16,000, either should work.
Dakota Digital SGI-5e:
Power
Ground
Signal in- white wire from intellitronix unit
Out 1- Red/Yellow wire at cluster (VSS Signal)
THIS IS ALL YOU NEED FOR SPEED OUTPUT ON THE CLUSTER. You do not need VSS ground or anything else hooked up to the unit.
Settings- Low-Low and calibration .512 with a 235/40/18 but set it around here and fine tune for your car using a GPS speed app. I too used Speedbox for iOS
I messaged DClem but didn't get a response. Has anyone used this setup? My speed or rpm is not working at the moment. Does the above setup fix both the speed AND rpm?
dreaMervaj is offline   Reply With Quote
Old 01-15-2019, 10:14 PM   #676
slider2828
slider2828's Avatar
RPM is not part of the tranny readout. RPM's come from the CAS sensor I believe.
Turn and Burn!
Old 01-16-2019, 11:23 AM   #677
dreaMervaj
Trader Rating: (18)
Is there any way to get the RPMs to work on a KA setup?
Old 01-16-2019, 01:00 PM   #678
LoSt180
LoSt180's Avatar
Trader Rating: (18)
The cluster gets the RPM feed from the ECU. So check your wiring, or you might have a bad cluster.
Speedo feed comes from an external sensor (in trans for S13/S14 or from ABS controller for S15), then the cluster passes a speed signal to the ECU. The setup you quoted is instructions to connect a different external speed sensor since the CD0 trans doesn't have a speed sensor built in.
Probably need to make a new thread, or chime in on the Small Questions Thread if you're having other issues not related to a CD009 trans swap.
Old 01-26-2019, 06:44 PM   #679
RalliartRsX
Trader Rating: (32)
Question for anyone running the Mazworx kit. Need some help with this issue (will send Mazworx an email on Monday)
My setup
Comp Clutch White Bunny
Sr20VET
Mazworx Bell housing
Comp Clutch TOB and SR sleeve
Two setups:
1) Z33 fork, Z33 pivot ball, SR TOB sleeve, Comp Clutch TOB. The issue is, when I go to install, the TOB and clutch fork comes into contact with the PP before the tranny is fully seated. Essentially, the clutch fork is fully against the front part of the opening, which means the Fork/TOB sits too far forward on the center housing
2) If I use the Z33 pivot ball (shorter pivot ball), but SR fork, SR TOB sleeve and Comp Clutch TOB, the tranny will completely sit flush with engine and the clutch fork sits perfectly center in the opening (which makes no sense). However 2 issues
a) I have no idea what the distance between the TOB to the PP should be (no mention of it in the FSM)
b) Clutch Fork specs (what distance should it be in the opening, distance for the clutch arm to move, etc). No specs on Clutch fork in FSM either
It almost seems like the bell housing boss used to mount the pivot ball, is too tall.
Old 01-26-2019, 09:50 PM   #680
Yellow4g63
My setup
Sr20VET
Two setups:
I thought you were supposed to use the Sr clutch stuff with the mazworxs kit.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Old 01-26-2019, 10:12 PM   #681
RalliartRsX
Trader Rating: (32)
That is exactly what I did. SR pivot, clutch fork and TOB/sleeve. Same issue of not having enough play in the system to allow for the gearbox to be mounted onto the engine. Basically the TOB is right up against the clutch fingers with about an 1/8" gap from tranny to engine.
So far, the only thing that "seems" to work is Z33 pivot ball, SR cluch fork, SR TOB/sleeve
Old 01-27-2019, 07:05 AM   #682
TheRealSy90
The Mazworx bellhousing is designed to be used with the all of the sr20 clutch components. Don't use any of the z33 stuff. It's possible that the COMP components are different enough from oem to cause the issue. Try all OEM sr20 components.
Old 01-27-2019, 08:40 AM   #683
RalliartRsX
Trader Rating: (32)
As I mentioned in the post prior to yours, I used all SR components and the issue is still present.
The only combination which seemingly works is the Z33 pivot ball, SR TOB/sleeve/fork.
But yeah, I am wondering if the comp clutch is the issue
I think I am going to just send it and see how it goes
Old 01-27-2019, 09:37 AM   #684
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
Ka24de and sr basically same transmissions , I posted a couple pages back on what you need exactly , down to the smallest bolt
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
Old 01-27-2019, 06:23 PM   #685
RalliartRsX
Trader Rating: (32)
Unfortunately, a taller carrier will exacerbate the issue I am experiencing by pulling the TOB 4mm closer to the clutch PP than where it's at currently........which is it hits the PP prior to the gearbox being fully seated.
I am going to take a height measurement of the pivot ball and use that as a basis for the proper carrier bearing height
Old 01-28-2019, 12:43 AM   #686
slider2828
slider2828's Avatar
Ralliart, how much clearance are you supposed to have from PP fingers to TOB? I am running a ORC dual plate and have no reference.
Turn and Burn!
Old 01-29-2019, 07:46 AM   #687
TheRealSy90
I used an OsGiken twin disc with my Mazworx setup. I used the specific carrier sleeve that OsGiken recommends for the sr20 with their twin disc clutch, I believe it was shorter than the oem sleeve. Everything worked perfectly.
Old 01-29-2019, 04:24 PM   #688
slider2828
slider2828's Avatar
Cool... Yeah its a shorty Koyo TOB.... You can get it a Z1 motorsports. Cool.... Thanks!
Turn and Burn!
Old 01-30-2019, 02:26 AM   #689
TheRealSy90
I meant the bearing sleeve itself. I had to use a shorter bearing sleeve, along with the smaller diameter OsGiken tob.
Old 01-31-2019, 11:03 AM   #690
slider2828
slider2828's Avatar
Oh Sorry misread. I have an ORC, not OSGiken....
Ogura only change is just the TOB and not the carrier, but I used the carrier that was supplied anyways.... But yeah a little different
Turn and Burn!
