#361 | |
I have hybrid turbos built by GCG. They are garrett gt2860r -7 turbos with compressor housings machined to fit the bigger -5 wheel Not sure if I'll fit them yet, I don't feel like going through all the BS to make them fit right now.
#363 |
Endless BMC stopper
![]() ![]() ![]() New OEM rear hubs, wheel bearings, and pretty much every little nut, bolt, washer for rear suspension area. New OEM rear stabilizer links and brackets etc. I wanted to get a few more things, but they are discontinued so I'll likely just freshen them up with fresh coats of paint etc. ![]() Nismo GT L.S.D pro 1.5 adjustable rear diff and some Nismo air stem caps lol. ![]() ![]()
#366 |
Not that you need any more glorification on your builds, but truly an astounding job well done on both your GTR and S13. I like many aspects of where your build is going, the exhaust and original Nismo old school style, really shows the charter of the build and builde
#372 |
Ok got a few updates. Been busy with work etc, was out of country for a few months.
Reinik cam cover baffles ![]() Nismo carbon mirror cover ![]() Nismo floor bar ![]() Omori Factory shift and ebrake boots ![]() Subframe dropped for restore/updates ![]() Diff disassembled ![]() Parts cleaned and powdercoated ![]() Nismo bushings and hicas ball joints pressed in ![]() ![]() ![]() ![]() Nismo GT pro LSD put in. I need to get different shims, the backlash was at .002 mm. It calls for .005 - .007 ![]() Subframe reassembly with nismo arms and new OEM hardware. The 5 lug hubs I ordered were the wrong ones. I ordered NA hubs when I need turbo model hubs. The NA hubs are slightly smaller and wont fit into the new wheel bearings. Working on getting that straightened out. So the old bearings/hubs are in for now. ![]() ![]() ![]() ![]() ![]() Thats it for now, still more to do before getting the car back together.
#375 |
Ok have some more updates.
Used a new shim and the diff landed at .005 inch Thats the bare minimum but it will work. ![]() ![]() Then it was time to rebuild the rear axles with new boots and grease. Very messy job, so not many pics lol. OEM boot kits are great ![]() ![]() ![]() slopped in some new grease ![]() assemble ![]() ![]() Assembled the 1000 piece sway bar endlinks lol ![]() All back together. Bled the Attesa etc. ![]() ![]() ![]() back on the gound! Always a good feeling haha ![]() Its not completely done, still waiting on a few odds and ends. Lost some nuts, forgot some nuts haha. All on order. Little things tend to happen along the way. Got a new battery. Kind of hard shape and size to find over here in the USA. We have much bigger posts than the little japanese ones. But I managed to find a battery shop that carried something that will maintain OEM appearance with no work needed. Even though its a Chinese battery. But it seems more than adequate. I bought a nice new battery charger/tender also, so it should be ok. Very close to OEM size ![]() ![]() Also picked up a new washer bottle. Which happens to be a nismo heritage part. They only make the N1 bottle so it only has the front spray motor. But I dont use my wipers or washer fluid. So it didn't bother me much, I just wanted some new plastic. I already have the overflow reservoir and the old washer bottle was throwing off the look lol. ![]() Should have a few more random updates next week hopefully. Waiting on parts.
#376 |
![]() Join Date: Oct 2008
Trader Rating: (131)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 131 reviews
I don't know why I've never thought of looking into new OEM CV boots for my S13. Looks like they're still available too! Not sure I have the confidence to execute that though... but definitely going to look into doing that as I blow through old axles all of the time due to tearing the boots.
Looks amazing as always- nice progress sir! |
#378 | |
Im not sure on the full axle assemblies. But if they do, I'm sure they are pretty expensive. But then again, I looked at GTR axles which are much beefier than S-chassis. I can try and find out.
#379 |
Few more things while waiting for the other stuff to ship in.
Got to move the car to pull it on the lift. All I have to say is, the nismo LSD is very talkative. It pops, bangs, chirps etc. Probably will break it in and move onto some Motul fluid as I've been recommended. Need something with some friction modifier to quiet it down. But the diff definitely "works" lol. Like someone is trying to escape out of the trunk using a hammer. While up on the lift, the steering rack bushings and front sway bar endlinks were changed out. ![]() Nismo bushings on left, OEM on the right. They really weren't in bad shape at all, neither was most of the bushings etc I've replaced. Previous owner took care of this car pretty well or its just because he only put 49k miles on it in 25 years. The nismo bushings are definitely a lot stiffer though. ![]() While on the lift gave me time to snap a few pics of the rear. ![]() ![]() ![]() ![]() Then it was time to install the Nismo trunk floor support bar. Kind of a qwerky piece but interesting. Not sure on how much it really stiffens things up, but the R32 is a car that needs all the bracing it can get. I believe the R34 had these designed into them from the factory. I believe the late model r33 had some kind rear bracing and also the S15 silvia got an OEM rear trunk bar. So apparently they do a little something for stiffness. But anyways, here it is ![]() ![]() ![]() ![]() ![]() ![]() Kind of a cool little piece, Im happy with it after install. Had to trim the rear paneling and make holes for the bolts in the carpet to keep a clean install. Didn't turn out to bad
#381 | |
NISMO brace is really cool. This car is very inspirational to me right now. Love the approach and choice in parts. |
#383 |
Thanks guys. Yea i kind of took a different approach to this build as I did with the 240(also not a kid anymore lol). A 240 requires quite a bit to be somewhat fun, you are going into it already planning to swap or turbo the KA and getting adjustable arms etc. A stock silvia would be a different story. Where a GTR is already fun and is more of a historical/collector type car. I don't want to really take away to much from the car itself. Which is why I haven't gone to extreme on parts as some other GTR owners. Just a touch better than OEM. Probably why I'm a nismo fanboy. Just kind of keeping it clean yet effective. Making my own "Nismo 32" so to speak.
#384 |
finally received my last little tidbits of parts to go ahead and finish up.*
Got the right hubs for the new wheel bearings. ![]() little hicas nuts ![]() sway bar bolts ![]() New OEM hood moldings also ![]() I also intalled the Omori Factory shift boot and ebrake boot. Went ahead and put in the N1 radio delete pocket as well. Kind of sucks though because the previous owner installed tweeters by the side view mirrors and im pretty sure they have ruined the door panels underneath. So I left them on lol. At least that looks finished compared to random bad spot on the panel. They are kind of hidden from outside view anyways. ![]() Got a new house. Nice having my ride in my own garage so I can do whatever. Most of the time, just staring at it lol. ![]() Have my own little JDM parts dungeon, all s13 and r32 parts lol ![]() Also, obviously got to test drive! Car feels very nice. Very smooth and planted. The nismo diff is pretty sweet. Instant hookup. Car stays much straighter when breaking traction or launching hard etc. I used to get a smidge of torque steer when I would shift and chirp second etc. Not now, it still chirps but it just keeps going straight lol. The noise is a little shocking at first, always sounds broken etc. But it still needs to be broke in a bit. I've only put maybe 50 miles on it. Also, clutching in on tight slow turns takes all the popping away lol. Very fun car to drive, feel very confident in it.
#387 | |
Anyways, the ol' 240 got to see some daylight. Finally got in my garage. Now that I have to look at it everyday. I got that old familiar feeling back. I need to get this done, or at least driveable. So Im thinking about taking the loss on the rb25. To much shit to do for me to get it how I had planned (pre GTR lol). I just dont want to spend the money on making a high end rb25....when I have a rb26 parked literally 3 feet away lol. So I'm thinking just do a simple SR swap, mostly OEM and let it be. A nice clean driver car. Put my GTR brakes on the front, put my OEM GTR wheels on it to keep the advans minty, and just enjoy the car. A city cruiser/fun car so to speak so I dont have to drive my big ol diesel everywhere and can keep the GTR parked for the most part lol. I always get a little nervous driving it because of the amount of IDIOTS i see on the road. Just bring it out here and there and use the 240 as more of a cruiser for when you get that driving feeling. I cleaned up the car slightly, has years of dust on it lol. A nice thing to see when I open the garage doors. Nismo and ARC intercoolers peaking at me lol. ![]() Little dude wanted to help clean (he just likes playing with the hose haha) ![]() They still clean up nice. That blue looks crazy in the sun. ![]() Wiped the hood down also, you can tell what it looked like by looking at the windshield. Its dirty lol. ![]() Something about old nissans and advans. Just always been a fan. Same era of cars too. ![]()
#390 |
Damn its been a while lol. Honestly haven't been doing to much car stuff lately. Mostly house stuff. But, I have done some things that a few of you may appreciate more than GTR stuff. Lets see if I remember how to work an actual forum....and computer for that matter LOL.
So GTR stuff first, not much really. Just enjoying it for the most part as is. Been more focused on 240 stuff recently. Platinum Racing Products VR38 coil pack kit, new plugs, OEM panel filter. Car had HKS plugs and HKS panel filter in it when I changed them. I didn't know HKS made panel filters lol. But I may switch back when its time for a new filter since they are replaceable. ![]() OEM setup compared to PRP setup, really nice setup they offer. ![]() Fits right in ![]() Can maintain OEM look ![]() I also went ahead and installed the new OEM front lip. Looks way better! ![]() ![]() Ok now for the 240 stuff. A friend randomly messaged me one day asking what it would take for me to let go of my entire RB25 setup, full race kit, fuel system, raw brokerage mani, cams etc. I gave him a number and he said yes. Still lost my ass a little, but recouped roughly 10k. So.....now I had a 240 with no engine or trans. Then another buddy randomly asked me one day if I knew anybody looking for a complete turn key SR20 swap. I said yea, me....maybe lol. I've never been a SR guy before, but at this point, I dont care lol. It fits the car perfect and is fun enough stockish. So I ended up buying it. Pretty OEMish, with a pulsar GTI-R turbo, turbo outlet pipe and a blitz downpipe. I went ahead and bought new OEM injectors and OEM maf, few random OEM lines, clips, fan and shroud, Koyo type S radiator (stock looking), Z1 silicone radiator hoses, OEM clutch slave, various little wiring specialties pigtails, Z1 driveshaft and I'm sure a few other little things I cant remember just to get it driveable. I still had my ARC FMIC, a tial QR recirc BOV and KTS titianium exhaust to finish it all off. ![]() Another problem is I had no brakes on the front of the car since I took the Greddy BBK off and put it on my GTR. So since I already bought OEM GTR rear calipers like 15 years ago, I just put my OEM GTR front setup onto the s13. Also got a new z32 BMC. Also had the new carpet, new floormats, Recaro seats, bride and a recaro seat rail lol, new armrest lid, wiper/turn signal stalks, all the DEFI gauges/sensors hooked up, also tried out the old school Tomei AF meter lol. Had to use translator to figure it out, but I think it works pretty accurately for the most part. Seems to cruise around 14 ish and WOT is 11-12 at .8-ish bar on the pulsar t28 So I feel like its working how it should. Better than nothing I guess. ![]() ![]() So then came the fact that the falken tires that were on the super advans were from 2006! lol. Definitely not safe and easily spun through 1st and 2nd gear when hammering it down. So I went ahead and got some Nitto NT05 in 275/40 rear and 255/40 front and I must say, I like the way looks much better. Got an alignment also so the car feels awesome right now. ![]() ![]() ![]() Now, the bad part is I'm 99.9% positive the turbo seals are starting to go on the pulsar t28. Smokes pretty heavy at an idle at stop lights etc, but disappears when driving. Doesn't over heat, no oil in coolant or vice versa. I pulled the intake to see any shaft play but there is none. So it has to be the seals as far as I'm concerned. So as of now, since I'm not chasing any kind of power trip or over the top setup, I'm planning on just doing a standard Spec R s15 dual ball bearing turbo, 550cc injectors, Z32 MAF and then some kind of tune, either nistune or JWT or something. Just want a fun, responsive, DRIVEABLE car lol. I figure around 300 hp would be a more than enough for an enjoyable streetcar that is OEM internal safe etc. I will include a list of whats on the car as of how it sits today, since it can probably get quite confusing reading through this thread from the beginning. Engine: SR20DET pulsar turbo koyo type S radiator ARC intercooller Blitz downpipe KTS titanium 3" exhaust Tomei titanium 3" test pipe Tial QR recirc bov random new OEM clips, hoses, grommets suspension: Old ass squeaky shit lol tein type flex coilovers (bought these new in 2003 lol) SPL tension rods (type 2 i believe) SPL tie rod ends SPL aluminum subframe bushings Z32 tie rods Auto Refine Co (ARC) front rear sway bars Nismo front lower control arms Nismo rear lower control arms Nismo powerbrace Nismo rear strut bar Okuyama Carbing aluminum front strut bar Cusco rear upper camber arms Cusco traction rods Cusco rear toe adjustment rods Drivetrain: 5 lug conversion OS Giken superlock 1.5 way LSD (very nice and quiet) SPL aluminum diff bushings Z1 motorsports platinum drive shaft New OEM diff seals/gaskets New OEM axle seals/bolts Brakes: R32 GTR front and rear calipers Dixcel rotors/pads Z32 master cylinder GK tech front lines SPL rear lines Body: S13 sivlia front end conversion OEM brick headlights Silvia K's aero front bumper JUN silvia hood Wheels: Super Advan Racing version 2 in metallic blue 17x8.5 +27 front Nitto NT05 255/40 17x9.5 +35 rear Nitto NT05 275/40 Interior: Defi Advance BF boost, oil temp, oil pressure Defi Advance link box Defi VSDX headsup display Broadfield custom steering column cover Broadfield 60mm vent cluster OEM JDM digital climate control Nismo black butt plug shift knob Nismo yellow killswitch fashion lighter Works Bell "splash" short hub Works Bell "splash" quick release Tomei steering wheel Tomei A/F meter New OEM ignition switch New OEM headlight/turn stalk New OEM windshield wiper stalk New OEM arm rest lid ACC carpet ACC floormats Recaro Crayola SR seats Bride and Recaro seat rails lol I think thats it for now, I still have the OEM silvia aero sideskirts, rear valences and JUN grille to put on. But I think I will wait until I get it painted do add all that stuff. Car needs to be gone over fully to fix random dents etc. But its well enough for me to enjoy for a bit lol. So until next time!
